Old 09-07-2011, 09:21 PM
Boubou's Avatar
Boubou Boubou is offline
Vehicle: 2010 Dodge Ram QC 4X4 Hemi
Trim Level: 4X4 SLT Hemi
Color: Light greystone
Rep:54
Boubou will become famous soon enough
Default Towing tires
I have a 2010 RAM and the original 20" Wrangler tires.
I'm towing a 7000 lbs travel trailer. Should I "worry" about the tires or are the tires safe to tow?
Old 09-08-2011, 11:57 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:355
I would think those tires are fine for towing your trailer....especially as long as your are not exceeding the manufacturer's tow rating for your truck in which case you would probably be asking for trouble anyway, lol.
Most owners dislike the stock Goodyears and get rid of them as soon as possible primarily because they have crappy road manners compared to other available tires. They don't handle well normally and handle even worse in the rain.
If you pull the trailer a lot then you would probably be happier in the long run and get better service out of a different tire (like Cooper Zeons which are extra load rated or maybe even a true E-load rated tire). The Goodyears don't compare well to other available and popular tires for these trucks but I don't think you need to worry about imminent catastrophic failure from them.
Old 09-08-2011, 12:47 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I agree with starquest, if you're are within your tow rating then your tires aren't going to fail (shouldn't anyway), but when you get new tires you may look into ones with a higher load rating (I also have the zeons and love them, although I hardly ever tow...)
Sean
Old 09-08-2011, 05:05 PM
Check the "Load Index" rating of your stock tires. It should be right on the sidewall. Then, compare that with this:
Load Index
P195/60R15 87S - The load index (87) is the tire size's assigned numerical value used to compare relative load carrying capabilities. In the case of our example the 87 identifies the tires ability to carry approximately 1,201 pounds.
The higher the tire's load index number, the greater its load carrying capacity.
89 = 1,279 pounds
88 = 1,235 pounds
87 = 1,201 pounds
86 = 1,168 pounds
85 = 1,135 pounds
A tire with a higher load index than that of the Original Equipment tire indicates an increase in load capacity. A tire with a load index equal to that of the Original Equipment tire indicates an equivalent load capacity. A tire with a lower load index than the Original Equipment tire indicates the tire does not equal the load capacity of the original.
Typically, the load indexes of the tires used on passenger cars and light trucks range from 70 to 110. A load index is a rating for each tire. So, multiply the load index by 4. For instance, a 96 Load Index tire gives you 1,609 pounds per tire X 4 = 6436 pounds
Load Index Pounds
71 761
72 783
73 805
74 827
75 853
76 882
77 908
78 937
79 963
80 992
81 1019
82 1047
83 1074
84 1102
85 1135
86 1168
87 1201
88 1235
89 1279
90 1323
91 1356
92 1389
93 1433
94 1477
95 1521
96 1565
97 1609
98 1653
99 1709
100 1764
101 1819
102 1874
103 1929
104 1984
105 2039
106 2094
107 2149
108 2205
109 2271
110 2337
Tire Load Range and Maximum Load
A tire's maximum load is the most weight the tire is designed to carry. Since a tire's load carrying capacity is related to the tire's size and how much inflation pressure is actually used, maximum loads are rated with the tire inflated to an industry assigned inflation pressure.
LT-Metric and Flotation Light Truck Tires Max Load Pressure
Load Range B (LRB) 35 psi (240 kPa)***
Load Range C (LRC) 50 psi (350 kPa)***
Load Range D (LRD) 65 psi (450 kPa)***
Load Range E (LRE) 80 psi (550 kPa)***
Load Range F (LRF) 95 psi (650 kPa)***
So, identify your tire load range, note the maximum PSI you can put in it & find your tire load index number on the sidewall.
Remember, a load index rating is what the tire can support at the industry standard inflation index above. And it is a rating to determine load carrying capacity. You can't just multiply the load index by 4 (the number of tires on your truck ) to get the proper tire. You'll end up with more tire than you need. What is needed, though, is the weight of your truck at the front axle and the back axle (truck is loaded with fuel, people and cargo + the trailer is hooked to it) to see if your front and rear tires support the axle weight. (Load index X 2 [you have two tires per axle])
It's complicated. So, if you can post the load index on your tire and the load range (both of which should be on your tire sidewall), we can figure it out from there.
Old 09-08-2011, 06:06 PM
Rep:355
A Goodyear Wrangler HP tire in 275/60/20 has a load index of 114 (max load 2601 pounds) and load range SL (max load at 35psi) even though the max inflation pressure for the tire is 44 psi.
So at 35 psi the max load his tires are designed to handle is 5202 pounds per axle, right? The front is obviously nowhere near that and would likely be even less with a trailer attached but how could we possible hope to determine the weight of the rear axle from the truck and trailer combined? We could likely determine how much weight the truck is putting on the rear axle by finding the total weight and the front/rear split but how to we determine how much extra weight the trailer is adding to the truck versus how much it's own tires are supporting?
Old 09-08-2011, 06:09 PM
You can do the front to rear weight bias calculation and guess but since BouBou is running about 700 pounds of tongue weight, depending on how loaded the trailer is, we can determine what's needed at the back by actually weighing the truck front axle, then the rear axle; with the loaded trailer hooked to it and the truck loaded with fuel, people and cargo; as I noted at the bottom of my post.
Old 09-09-2011, 10:29 AM
Rep:355
Sorry, I must have missed the part about weighing the front and rear axles of the truck.
According to this site...
http://www.dodge.com/bodybuilder/201...ammlup1500.pdf
His truck weighs 5362 pounds containing all needed fluids and fuel and is split 3113 front/2249 rear which you would expect from a pickup truck. So if you take the 2249 pound rear axle weight and add the max payload weight (1310 pounds) and the max trailer tongue weight for the class IV hitch (1045 pounds) you still only have 4604 pounds, well within the load carrying ability of the stock tires.
And just for your info Boubou....if you have the 3.55 rear axle ratio your max towing weight is 8450 pounds and if you have the 3.92 it is raised to 9950 although you should keep in mind the 1045 pound max tongue weight for a class IV hitch.
Old 10-12-2011, 07:21 AM
Boubou's Avatar
Rep:54
so truck and trailer specs
steer axle: 3320
drive axle: 3460
trailer axle: 5140
gross weight: 11920
that's loaded and ready to go
Truck by itself, passengers, dogs and fuel
Steer axle 3440
drive axle 2600
gross weight 6040 (I think need to remove about 40 lbs cuz I forgot to remove the ball hitch and it's pretty heavy)
Old 10-12-2011, 09:26 AM
pupdawg pupdawg is offline
Vehicle: 2012 Dodge Ram
Rep:45
pupdawg is on a distinguished road
I have a good friend who owns a tire shop and he advised me to do a tire swap immediately...he knows the trailer I pull. he said they might run fine but do you want that sitting in the back of your mind running down the I-state at 70-75 mph with yer trailer...or have to deal with a failure... Just my ramblings on this...
Old 10-12-2011, 09:59 AM
Rep:355
Those truck only numbers are very close to the factory specs posted on the site I linked. As I suspected, the loaded trailer putting pressure on the rear of the truck actually takes a little weight off of the front axle and obviously adds quite a bit to the rear. So basically you are putting about 3460 pounds of load on your rear axle where your stock tires are rated to handle a max of 5202 pounds per axle. Your loaded weight on the rear axle is actually extremely close to the unloaded weight that your truck is carrying on the front axle everyday. I don't think you have anything to worry about.
That being said, the stock Goodyears still suck. Doesn't seem like you need to be in any great hurry to get rid of them to me but if it's in your budget it would likely be a worthwhile upgrade. As previously noted, you will probably experience better performance and longer tire life with a heavier load rated tire.
tires, towing, trailer
Official Off-Road tire thread!!!! RamCountry Dodge Ram Wheels And Tires 86 07-20-2014 09:44 PM
Rain + stock tires = new tires tan brule Dodge Ram Wheels And Tires 7 08-13-2011 10:43 AM
Towing Tires NORFLA71 Towing 5 07-22-2011 10:44 PM
SS/T or Indy Rims + tires? 98sst Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 1 03-12-2011 06:15 PM
20 inch tires for towing CPRAM Dodge Ram Wheels And Tires 3 01-27-2011 02:30 AM
