Where to tap? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 09-07-2011, 10:19 PM
sonocativo's Avatar
sonocativo sonocativo is offline
Vehicle: 99 Ram Sport 1500 4x4 Quad
Rep:227
sonocativo has a spectacular aura aboutsonocativo has a spectacular aura aboutsonocativo has a spectacular aura about
Default Where to tap?
I installed my air horns and I am running a relay for power to the compressor that way there is a direct draw from the battery. I dont know what to tap into for "SWITCHED" power? It draws very little power so it wont blow a fuse since it is only to switch the relay for the direct draw from the battery, what wire do I need to tap into under the dash that will be "OFF" with ignition off and "ON" in the run position? Thanks for your help guys.
I Am Groot !
Old 09-09-2011, 01:35 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Check your cig lighter/power-port. Some are keyed with the ignition.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 09-09-2011, 11:10 AM
sonocativo's Avatar
Rep:227
After pulling the dash panels to install the switches, found that several wires had T-Taps on them... must have been and aftermarket alarm system on it at one time. there was a T-tap on the main ignition wire ( blue ) so I just installed a spade connector and plugged into it. Everything works and I am now Loud N Proud ! lol
I Am Groot !
Old 09-09-2011, 11:26 AM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
Air horns are great. Used to have a set on my old truck. Was always great to see the looks on people's faces when you lay on them.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
