Old 09-08-2011, 11:57 AM
BadHazard's Avatar
BadHazard BadHazard is offline
Vehicle: 2006 QCSB, 1500
Color: Inferno Red
BadHazard is on a distinguished road
Default MotoBlue GEN X Underdrive pulley
Has anyone ever ran one of these? Any increases? hp, mpg?
http://www.rpmoutlet.com/ramhemiasp.htm
Worth the 145$
06 QCSB, 1500, Laramie, 4x4 50k. 18" Rockstars, K&N Drop in Filter, Muffler Delete, SuperChip
Old 09-08-2011, 12:07 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
I haven't personally run one but I am planning on getting an underdrive pulley in the next month or two. From the reading I have done it seems like guys have been gaining a few hp at the wheels and the engine spins up more quickly than with stock.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 09-08-2011, 12:22 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Underdrive pulleys do help. They do not increase the power output of the engine, but free up some power by taking away some of the parasitic loss on the engine accessories. It takes some power to turn the accessories, so if you use an underdrive pulley you will pick up a couple hp. They are usually lighter as well which helps this same concept. Some people that use them and have large electrical demands (audio or video...) also need an overdrive alternator pulley to keep up with the electrical demand. Most companies that sell underdrive crank pulleys sell matching overdrive alternator pulleys. Be careful and do some research on the company, some people have run no name underdrive pulleys/harmonic balancers and ruin their engines. The harmonic balancer/dampener is a vital part of the engine, it soaks up harsh imbalances(harmonics) that would otherwise destroy the internals if it weren't there. I've seen a guy take all accessories off his engine including the crank pulley/balancer, and didn't even make it one pass down the track before his engine blew...
That price seems a little cheap from other prices I've seen, but if you find others using the same product from the same company for some period of time without any damage, it's probably fine. One of the biggest names in quality dampeners is ATI just FYI maybe you could compare...
Sean
Old 09-08-2011, 12:25 PM
TheSatinPumpkin's Avatar
Color: Satin Orange
Rep:627
There were quite a few threads years ago that motorblu/asp underdrives that were pulley first and harmonic damper second which caused toner rings to blow.
Haven't read recent cases so maybe its all good.
I would avoid purchasing anything from rpmoutlet.
Old 09-08-2011, 12:26 PM
ORT's Avatar
ORT ORT is offline
Rep:184
The original motoblue was blowing a lot of hemis back when they first came out. Not sure if the new one's are any good but I personally am leery of motoblue after what happened with their original attempt at an underdrive.
Old 09-08-2011, 01:07 PM
snrusnak's Avatar
Rep:1385
Yeah I would invest in a better known brand, I think some use the summit brand with good results.
Sean
Old 09-08-2011, 01:53 PM
BadHazard's Avatar
Color: Inferno Red
alright, well def think this is a to do on my mod list. Ill look into other brands. Thanks guys.
Old 09-08-2011, 01:58 PM
snrusnak's Avatar
Rep:1385
Good luck, post back with results on what brand you go with, more info on these would be great to have
Sean
Old 09-08-2011, 02:07 PM
BadHazard's Avatar
Color: Inferno Red
will do, might be a while. I just got a SC and my next mod will prolly be some pacesetter LT's
Old 09-08-2011, 10:05 PM
05ram's Avatar
05ram 05ram is offline
Vehicle: 2004 VW .:R32, 3.2l AWD V6
Trim Level: .:R
Color: UGM
Rep:145
05ram will become famous soon enough05ram will become famous soon enough
I'm using the summit that cost $215 so that $145 is tempting, I dont know anything about them but it looks just like my summit one. Keep us posted.
2008 VW .:R32, 3.2l, AWD, V6, #2952/5000
ASP Underdrive Pulley Silver04Ram Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 31 01-06-2012 10:23 AM
Fan pulley not aligned pbdupre 5.2L V8 Specific Topics 3 01-15-2011 11:08 PM
Motoblue Pulley Help! ScatPak07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 6 06-11-2010 01:45 AM
Which belt for underdrive pulley kit? 345CI Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 1 09-25-2009 02:30 AM
Electric fan and underdrive pulley 03ramhemi Dodge Ram General Discussion 5 07-13-2009 05:16 AM
