Better Mileage! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.7-liter V6 engine - 210 horsepower, 235 lb-ft of torque.
Old 02-15-2011, 10:25 PM
dirty dodge dirty dodge is offline
dirty dodge is on a distinguished road
Default Better Mileage!
my girlfriend has an 03 liberty with a 3.7. im pretty sure its the same motor as the ram. anyways, she drives it like a grandma and only gets about 13 mpg and it dont run very smooth. kind of shakey idle... it only has 65xxx miles on it. i recently put plugs in it, fixed a vacuum leak, cleaned out the throttle body, and changed the air filter. is there anything o can do to make it better on gas? what kind of mileage are you guys getting??? thanks
Old 02-15-2011, 10:42 PM
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
Rep:4376
I have the 3.7L and average 15 mpg, mixed driving, mostly highway though. I don't race it lol, but I don't granny it, either. Does she have any mods on it? IMO, and I'm no mechanic, but I run a bottle of fuel injector cleaner in mine every oil change, too, but I'm sure others here will have some advice for you.
Old 02-15-2011, 11:00 PM
the only mods are the camo seat covers and the air freshener hanging from the rear view mirror. i forgot to mention the injector cleaner. i usually use tecron or lucas about every other month in it.
Old 02-15-2011, 11:47 PM
Rep:1915
The mileage won't get much better. The rough idle is likely from a buildup of carbon on the intake valves. Get a can of Mopar combustion chamber cleaner (the kind in the spray can) or Sea Foam and follow the directions on the can.
Old 02-16-2011, 12:00 AM
i was thinkingabout sea foam but didnt know if it could mess anything up..
Old 02-16-2011, 12:08 AM
Rep:1915
After you run the Sea Foam through, you need to drive it for a few miles and really twist it's balls. Run it over 4500 rpm for about 15 seconds and then let it idle. Repeat this about 6 times and then cruise it for a few more miles.
Old 02-16-2011, 12:14 AM
hmm ok ill have to give that a shot
Old 09-13-2011, 02:46 AM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
Default fuel systen cleaning additives
What is an effective cleaner for both injector and carb fed systems that won't leave a cloud of smoke behind me? My new Ram won't need it for years from now, but my older autos could likely benefit from a dose every so often.
I"ve used Techron before and it doesn't leave an embarrasing trail of smoke, but friends say Seafoam does the best job of cleaning, but does smoke.
Whats a girl to do? Don't want sneers for driving an eco damaging smoke bomb, but cleanliness and effeciency would be so nice. What do you more experienced folks use?
Old 09-13-2011, 03:16 PM
chambers chambers is offline
Vehicle: 2004 Dodge Ram 1500
Rep:29
chambers is on a distinguished road
Gumout regane or marvel mystery oil are also good products for cleaning fuel systems.
Old 09-13-2011, 04:00 PM
Rep:1388
^ I put some marvel mystery oil in the tank every so many fill ups (whenever I think of it). Also sea foam every 50k miles or so in oil and gas. I put some marvel mystery oil in everything from time to time (mowers, motorcycle, etc....) as fuel anymore doesn't have as much lubricant as it used to.
Tune Up = Worse Gas Mileage? gain11 5.7L (345 cu in) HEMI V8 Specific Topics 19 01-13-2012 01:13 PM
Fuel mileage Redlongbed Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 11 09-11-2011 10:40 PM
EVIC and mileage numbers ram4x4 2009 Dodge Ram Forum 8 04-08-2011 11:36 AM
Stock Mileage and how to increase it? yzracer Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 13 04-03-2011 12:26 PM
Huge gas mileage leap.......maybe Otterdriver Dodge Ram MPG Zone 32 11-17-2010 09:48 AM
