Old 09-08-2011, 02:53 PM
EWC88 EWC88 is offline
Vehicle: 2002 Dodge Ram 1500
Rep:25
EWC88 is on a distinguished road
Default Windshield wipers issue?
I have a 02 ram 1500 with the 4.7l engine in it. Just recently the wipers started acting funky. If I put it on the low speed it'll not kick on right away and then when it works it will get stuck and times and freeze. What can this issue be? Only times it works with no problems is usually at high speed.
Old 09-08-2011, 10:19 PM
GreatTiger's Avatar
GreatTiger GreatTiger is offline
Vehicle: 2011 Ram 1500 SLT
Rep:31
GreatTiger is on a distinguished road
wiper switch would be my first guess but first check the connector at the wiper motor.
Old 09-09-2011, 10:41 AM
Rep:25
Were is the wiper motor located?
Old 09-09-2011, 10:13 PM
GreatTiger's Avatar
Rep:31
The wiper motor is located under the plastic cowl panel under the wipers, and the bolts for it are inside the engine compartment near the brake cylinder booster unit.
Did some googling and apparently it can be one of the linkages seizing half way with through a rotation cycle or the motor going bad. Might take some thorough trouble shooting just to give you a heads up.
Make sure all nuts and bolts for the wiper system are actually there and make sure the linkages have grease.
With the plastic cover off, put you wipers on and observe their behaviour and listen for grinding or a the motor straining real hard. If you hear grinding coming from the linkages then theres probably a lack lube for good movement.
In addition to the above mentioned, the lack of may have put enough strain on the motor itself to weaken the motor but first try lubricating linkages.
Hope this helps.
Old 02-20-2013, 08:30 AM
ram shaker's Avatar
ram shaker ram shaker is offline
Vehicle: 1998 Dodge Ram with 01 front
ram shaker is on a distinguished road
i know this is an older thread but did this fix the issue? if not what did it turn out to be? I am having the same issue with my 98 ram
Old 02-20-2013, 08:49 AM
Rep:25
To be honest with you I never did what was suggested because it stopped acting weird and I forgot all about that issue. I would give it a try though.
Old 02-20-2013, 12:49 PM
Trim Level: sport
Color: green
Rep:663
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
check the switch or replace the wiper motor.
Windshield Wipers Will Not Return To Park Bobmorr Electrical 1 06-01-2011 09:52 PM
Windshield Wiper Help!! BigHornRam2006 Electrical 7 05-24-2011 04:02 PM
2010 Ram; Windshield wiper safety issue Tanker67 2010 Dodge Ram Forum 51 02-11-2011 09:55 AM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-12-2011 11:30 PM
Windshield Wiper Help! Buffy Electrical 4 12-20-2008 12:49 AM
