tonneaucovered.com
Old 09-20-2011, 12:52 AM
Rep:2731
the noise happens on flat ground, whether i use the parking brake or not
it sounds just like someone with a standard stick trying to shift, with the clutch adjustment being out of whack
I'll drive it until it doesn't work any more, i keep a folder on Everything that the dealer does,
if it grenades, i'll set the shoe box full of paperwork on the service managers desk
Old 09-20-2011, 11:32 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Mine makes this noise sometimes. My truck was a rental in previous life, so I'm sure people just threw it and park and never used the parking brake (this is very bad for the trans if you did not know this, you should always apply the parking brake BEFORE putting the vehicle in park, to keep from straining the transmisison). Since I have had the truck it seems to make the noise less and less as I drive it. Also have noticed if I put it in gear with the parking brake on the noise is louder, if I hold the brake then release the parking brake and then put in gear, the noise almost never occurs, this leads me to believe it's just noise from the rear brakes/parking brake assembly....could be a different noise though, but sounds like exactly what you described, a clutchless manual trans shift.
Sean
Bang In Reverse Noise And Hard Shift BIUBigPimpin 5.7L V8 Specific Topics 11 07-13-2015 06:54 PM
Noise in reverse after leveling kit Pav Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 04-16-2010 05:03 PM
reverse lights on a 2009 glamontagne Custom Dodge Ram Interior and Exterior Lighting 12 03-30-2010 08:12 PM
Loud noise under truck only when in reverse Smazz Suspension 3 01-01-2010 02:53 PM
Makes a weird noise turning left?! r3d47 Suspension 11 06-22-2009 08:08 PM
