Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8
Place your Ad Here!
Old 09-08-2011, 08:17 PM
mudjoe mudjoe is offline
Vehicle: 1997 dodge ram 1500 4x4
mudjoe is on a distinguished road
Default Want to atleast bark my tires
Got a 97 Ram 4x4 1500,33in tires,volant cold air intake whole kit,throttle body spacer,hypertech high voltage coil, flowmaster. Has great torque after take off but that's after u hit about 15mph. Wont even burn out in gravel like it should. Was thinking of getting hypertech programmer cause that's all I can find for this year truck? Was thinking 4:10 gears, but guy at offroad shop said I would lose alot of gas mileage and shouldn't do it. I also don't like the way it shifts down everytime I go up a slight hill. Flat road she flys though! Lol. Any advice would help. Thanks
Old 09-08-2011, 08:33 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
On my old 2001 ram I had 4.10's and the gas mileage wasn't bad. Also, I had a good bump in performance by installing some 1.7 rr's.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 09-08-2011, 09:47 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
What gears do you have now? What is the transmission on that truck do you know? If you can tell me I can look up gear ratios and give you an idea on gas mileage. I'm guessing gearing is your issue since you have 33" tires.... Assume it's maybe lifted too?
Sean
Old 09-08-2011, 09:56 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
If you do gears, it'll be two sets since it's 4wd, so, for starters, and much less money, I'd get a high stall torque converter.....something around 2000-2200 rpm.
Old 09-08-2011, 10:00 PM
snrusnak's Avatar
Rep:1388
Aren't stock stall converters around like 1,600 or 1,800 so going to 2,000 wouldn't be much change....I'd go a little higher like 2,400 or 2,600.....but then again I'm not real familiar with that engine/trans.
Good point about the 4wd gear changing being expensive...
Sean
Old 09-08-2011, 10:05 PM
It's stock height,3:55 gears and auto overdrive tranny. Not sure witch one. Lol. I just know it cost 2000$ to rebuild it. Lol.
Old 09-08-2011, 10:15 PM
Drake371's Avatar
Drake371 Drake371 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:83
Drake371 will become famous soon enough
I would take out the TB spacer ... adds un needed noise with no benifits....unless you tapped to add nos.
Superchips Cortex, K&N CAI 63-1529, Sprayed in Bedliner, ARE cover, Flowmaster exhaust kit ... more to come
Old 09-08-2011, 10:16 PM
mr.lopar's Avatar
mr.lopar mr.lopar is offline
Vehicle: 1999 dodge ram 1500
Trim Level: baja/prerunner
Rep:192
not sure how much itll help but you can always do the kegger mod and tb mod,port and polish your heads, do a tune up; new plugs, cap, rotor, and bigger plug wires
Old 09-08-2011, 10:19 PM
snrusnak's Avatar
Rep:1388
3.55 isn't terrible, so it probably isn't worth the $ for a gear swap....I agree the TB spacer does nothing. I'd agree a higher stall torque converter would probably be beneficial to you....anything else you probably won't notice any difference.
Sean
Old 09-09-2011, 12:29 AM
Rep:99
Weeeell I tend to be a bit conservative on things, but one thing must be considered. Take my Shelby Dakota for example. 2000 stall, 3600lbs, 3.90 gears. Stomp it and the tach would flash to around 2k to 2100 immediately. Put that same 2k rpm converter in a 5000 lb truck with 3.55 gears and despite the rating, off the line at full throttle the converter will run to a higher rpm before it digs in, easily 200-300 rpm more than the rating. Taken the other way, an 1800 lb rod with 4.56 gears simply won't load the converter enough to get more than say, 1800 stall on a converter rated for 2000 stall. So, that's where I draw my suggestion. Also, at 2600 stall, you're gonna be in a pickle with 3.55's and 33 inch tires. What rpm do you plan on the converter locking up, and do you realize how fast the truck will be going? Just trying to strike a reasonable compromise.
Official Off-Road tire thread!!!! RamCountry Dodge Ram 4x4 - Offroad Discussion 108 06-18-2017 11:19 AM
Getting new 35" tires - which to get? rclipic Dodge Ram 4x4 - Offroad Discussion 41 03-25-2013 10:05 AM
Rain + stock tires = new tires tan brule Dodge Ram Wheels And Tires 7 08-13-2011 10:43 AM
Wrangler stock tires GraceMartha Dodge Ram Wheels And Tires 14 07-17-2011 05:22 PM
SS/T or Indy Rims + tires? 98sst Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 1 03-12-2011 07:15 PM
