Tail Lights / Reverse lights - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 09-08-2011, 10:56 PM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
Default Tail Lights / Reverse lights
I picked up a '99 Dodge Ram Sport today. Been looking it over some and found a few issues. Thought I'd post in the electrical section about my tail lights, reverse lights and turn signals. When I turn on the right turn signal, the left and right reverse lights will flash in alternating sequence with the turn signal light. What could the issue be? What should I check out first? When I turn on the left turn signal, everything seems to operate as it should. Thank ya
Old 09-09-2011, 12:57 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Sounds like you may have a ground short. I'd start by looking for some pinched wires or evidence where someone has tampered with the factory wiring (possibly wiring in an extra set of reverse lights). I'd start at the lights and work your way forward.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 09-09-2011, 01:09 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Look at the back of the frame rail near the rear bumper on the drivers side for a splice connection with about 7 black wires (One of them is thicker than the remaining 6). There is likely a problem with it.
brad
Interested in one of my mods?
Old 09-09-2011, 10:03 AM
I will check that out when I get off work this evening.
I noticed a few other possible electrical issues. Not much is operation inside the cab. The dome lights don't come on (either with doors open or with the dimmer switch control), the power mirrors don't work, the driver nor passenger personal map lights don't work either. Are these devices on the same circuit? Possibly related to the tail light issue? Where are the fuses located for those circuits. I quickly pulled off the fuse panel in the door jam, but didn't see anything labeled with those devices.
Thank y'all.
Old 09-13-2011, 12:09 PM
I also noticed this while checking things out. When I put the transmission into reverse, the reverse light on the right (passenger) side is dim compared to the left (driver) side. Is the passenger turn signal and passenger reverse light grounded in the same location; possibly causing this electrical phenomenon?
Old 09-15-2011, 09:01 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Have you a trailer connector? That may be your tail/turnsignal prob... It plugs in - line behind the drivers tailight assy. My reverse light failure was a sensor on the trans, one light, corrosion at the bulb to get the other one up to full brightness on the other side, (after changing the trans sensor)
Old 09-16-2011, 12:31 AM
Yes, there is a trailer light connector. Which sensor on the transmission are you referring to? I haven't noticed any corrosion on either of the reverse light bulbs.
Old 09-18-2011, 11:56 PM
brad12kx's Avatar
Rep:2581
There is one connector that I think is worth checking out. It is below the right tail light.
Connector has 4 wires -
Black/Yellow
Black
Brown/Red
Violet/Black
Start by disconnecting this connector and re-connecting it....about 6 times to cycle the contacts.
brad
Old 09-19-2011, 02:27 AM
I disconnected the plug just as you said to no avail. The lights still repeated the issue. I found a hard plastic-type harness with lots of electrical tape around it and several exposed wires, but none of them seemed damaged. Here is a picture of that harness. It is located just above the driver's side rear strut.
I did notice a wire that was sticking out of the harness. It's probably not the source of my problem, but I am curious as to where it should go. It has a label sticking off of it that says "CHMSL". In the picture below, that harness at the bottom leads to the trailer light connector.
Old 09-19-2011, 10:07 AM
brad12kx's Avatar
Rep:2581
This is an auxillary 'Brake Light' wire. CHMSL = Cab High Mounted Stop Light.
brad
LED Reverse Lights and License Plate Lights jcasey10 Custom Dodge Ram Interior and Exterior Lighting 10 12-27-2010 12:07 AM
Reverse lights not working robmaed Electrical 4 10-27-2010 07:41 AM
need 08 tail lights greendaze Custom Dodge Ram Interior and Exterior Lighting 15 07-03-2010 12:25 PM
HELP GUYS conversion 08 to 05 tail lights Steven Custom Dodge Ram Interior and Exterior Lighting 0 01-20-2010 08:06 PM
Changing tail lights from 06 to 08 need help hausbldr Custom Dodge Ram Interior and Exterior Lighting 1 02-23-2009 12:44 PM
