Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 09-26-2011, 12:08 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I don't in your case think yhat you need to screw around with your trans sensor, seeing as you actually have a reverse light that works as commanded, I do however believe that you have a grounding issue. these are ugly ones to shoot down. Have you got voltage issues at the trailer plug? pull it out of the harness and see what you've got, you can always reconnect it, but get some antioxidant grease for it's connection points before you reconnect it. if someone didn't use the 30 dollar inline adapter to wire up the trailer plug, and simply hacked into the harness without solder and heatshrink, I'd suspect problems... Wish I was certain how the ground works, on these units, but they can be a real circle j@rk on GM products to troubleshoot, I havent had the pleasure on these Dodges of mine - yet...
Old 09-26-2011, 12:40 PM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
Turns out that the issue was with the splice connection with the ground wires in it that was mounted on the driver's side rear frame rail.
LED Reverse Lights and License Plate Lights jcasey10 Custom Dodge Ram Interior and Exterior Lighting 10 12-27-2010 12:07 AM
Reverse lights not working robmaed Electrical 4 10-27-2010 08:41 AM
need 08 tail lights greendaze Custom Dodge Ram Interior and Exterior Lighting 15 07-03-2010 01:25 PM
HELP GUYS conversion 08 to 05 tail lights Steven Custom Dodge Ram Interior and Exterior Lighting 0 01-20-2010 08:06 PM
Changing tail lights from 06 to 08 need help hausbldr Custom Dodge Ram Interior and Exterior Lighting 1 02-23-2009 12:44 PM
