Old 09-08-2011, 11:34 PM
SportHD SportHD is offline
Vehicle: 1998 dodge ram
Trim Level: sport
Rep:43
SportHD is on a distinguished road
Default ABS/Red brake light coming on
My ABS and red brake light will come on occasionally just driving down the road. I had it scanned and it said ABS main relay open. I didn't see an ABS relay, but found the ABS 40amp fuse. It appeared ok, but I replaced it anyway. That fixed the light for a few days, then it came on again. This time I pulled the fuse out and put it back in. Light went out for a day then came back on. Any ideas what may be causing this?
Old 09-09-2011, 01:22 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
I used to have the same issue with my F150 back in the day... On the Ford I replaced the ABS sensor on the rear differential and all was good. I'm not familiar with the ABS setup for your particular model, but maybe it's got the same issue??
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 09-09-2011, 12:20 PM
Trim Level: sport
Rep:43
Someone else told me dodges had issues with the rear abs sensor also. Is that a dealer part?
Old 09-11-2011, 04:47 PM
crip crip is offline
Vehicle: 2000 dodge ram 1500
Color: green
crip is on a distinguished road
my brake/abs light were on and i replaced my abs speed sensor or rear wheel speed sensor and light went away. may be that. i ordered it from summit, was 17.95 or something.
Old 09-13-2011, 10:59 AM
MBCJim MBCJim is offline
Vehicle: 1999 Dodge Ram
Color: Green
MBCJim is on a distinguished road
I just replaced mine a couple of weeks ago. Got the part from my local parts store. Unless you have a lift available I would suggest taking the spare tire out before replacing the sensor; it will allow you more room to work. just my $.02
Old 09-17-2011, 06:15 PM
pocketchange pocketchange is offline
Vehicle: 2001 1 Ton Ram
Trim Level: Loaded
pocketchange is on a distinguished road
If the speedometer is working without any issues, it is NOT the RWSS.
Check and/or replace the brake switch for the pedal, assuming the other sensors are ok.
I'm new here BTW.. but not to owning a ram.
pc
Old 09-17-2011, 06:46 PM
Rep:147
pc
Don't think that's right man. The RWSS/ or ABS speed sensor has nothing to do with the speedo. Im quite sure the speedo gets its data from the transmission when determining speed.
Turn Signals In 3rd Brake Light Coastiejoe Custom Dodge Ram Interior and Exterior Lighting 2 07-04-2011 05:44 PM
Brake Light coming on intermittently DaFreak Electrical 3 06-03-2011 09:42 AM
Backup lights on the third brake light not working. backsaw13 Electrical 6 03-27-2011 09:10 PM
Early 3rd Gen LED Tails and Third Brake Light jcasey10 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 3 01-04-2011 02:53 PM
Brake light in dash is on RDG Brakes 6 10-13-2010 10:29 AM
