Old 09-09-2011, 12:22 AM
markstoys1's Avatar
markstoys1 markstoys1 is offline
Vehicle: 2010 Ram 1500, 4X4, Big Horn
Color: Light Greystone Pearl
Rep:70
markstoys1 will become famous soon enough
Default Just recieved a recall notice
Just got a recall for defective tierod ends. I wonder if they will give me a hassle over my leveling kit. If they have to re-aline the front end it now calls for different specs.
Mark
Old 09-09-2011, 03:46 PM
bgerard's Avatar
bgerard bgerard is offline
Trim Level: Big Horn 4x4 Crew
Color: Austin Tan Pearl
Rep:28
bgerard is on a distinguished road
Just call in before you go (even if you have appt). Had my appointment set up, drove 25 miles to dealer. Got there and they "were out of that part" and didn't know when they'd have more in. Seriously - you can't call a guy? Evidently the part if hard to come by until the end of Sept...
Old 09-09-2011, 03:48 PM
You should be OK, Mark. The recall identifies a problem area they found, not a problem area caused by modifications, such as a lift kit.
They should fix you up with no problem.
ps: I'll get to that picture issue tonight.
Old 09-11-2011, 12:36 AM
markstoys1's Avatar
Rep:70
Thank you. My dealer usually treats me good. I will check with them as far as when the parts will be in. I have noticed a metalic creeking sound once in a while while turning the wheel hard over bumps. Seems to be coming from the front end.
Mark
Old 09-11-2011, 12:47 AM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
like maddog said i dont think it will be a issue either
New Recall k36 found it today at Dodge dealer - REAR AXLE FLUID DRAIN-BACK FLOW RESTRICTOR - Pic RAMTX 2011 Dodge Ram Forum 131 09-23-2011 10:36 PM
2010 Recall - K08 RamTech Dodge Ram Recalls and TSB's. 6 02-25-2011 03:13 PM
Just received a notice from dealer about a recall Ray 2010 Dodge Ram Forum 27 01-02-2011 01:53 AM
Recall notice Allstate48 2010 Dodge Ram Forum 8 10-18-2010 04:21 PM
Safety Recall Notice - H46 jamesb0 Dodge Ram Recalls and TSB's. 1 09-18-2009 04:32 PM
