Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 10-07-2012, 09:58 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:251
Ramzaq is a jewel in the roughRamzaq is a jewel in the roughRamzaq is a jewel in the rough
For those out of warranty and like to fix your own things, here is a quick guide for that clicking noise.
Chances are it is only the motor that is bad if it is clicking or thumping.
Not very hard to fix really. I think most of these cases are the motor gears stripping and not the doors themselves.
If you know how to take the center stack bezel around the radio off you are halfway there. Don't forget about the screw over the 115V out let. Take the bezel off then the two side 12V acc. plugs. Remove the ring bezel around the cup holder if equipped.
The culprit is the lower center motor, unplug remove two screws and remove.
If the gears are stripped you can position the big gear 180 out from the smaller gear. The door only travels about 120 degrees so won't hit the stripped part.
Reassemble and you should be good to go. 1 to 2 hours of your time. If you want to get a new motor it is about $40 from Chrysler.
Hopefully this is the extent of your problem.
Old 11-09-2012, 01:58 AM
libuke libuke is offline
Vehicle: 2011 Dodge Ram 2500
libuke is on a distinguished road
Default Clicking Noise AC
Anyone have any problems with a 2011 Ram with the AC blower clicking for a few seconds when you turn it on? It dosent stay on and dosent happen but 70-80% of the time. I have taken it in and all that was out there was the 2009-2010 recal which they checked out and said it was the issue.
Old 11-09-2012, 02:08 AM
Rep:2705
I see Dodge is still using the CHEAP white plastic gears
when will they their collective heads screwed on right
Old 11-23-2012, 06:09 PM
gabo5.7 gabo5.7 is offline
Vehicle: 2009 dodge ram
Trim Level: sport
Color: blue
gabo5.7 is on a distinguished road
thank you very very much for your repair pictures! just did mine and you just saved me alot of money and to the guy who started this post i guess.
Old 10-03-2013, 05:19 PM
hawgdriver14 hawgdriver14 is offline
hawgdriver14 is on a distinguished road
Hey guys,
New to the forum but am hoping someone with some dealership experience can help me out. I own a 2009 Ram 1500 SLT. Had the clicking noise with my HVAC system and took it in recently for recall K17. Before the repairs, I could get cold or hot air but couldn't control where the air was going. After said work, it only blows warm air now and I was told that the actuator doors were replaced and the head reprogrammed. I was also told that a new control head was needed, to the tune of 265 dollars. Can someone tell me if I'm having the wool pulled over my eyes? I feel as though I am and when I asked why the system only blows warm air they gave me the standard answer of "the system is tricky with things like this and could be anything internal failing." Many thanks.
Old 10-04-2013, 08:09 PM
Rep:251
Originally Posted by hawgdriver14 View Post
Hey guys,
It sounds like they screwed something up. Your original problem definitely sounds like the blend door motor, (see my post above) only blows out the lower outlets both hot and cold air.
I would take it to another dealer and tell them what the original problem was and what was done to fix it and tell them you have a new problem now after the fix, only hot air blowing now.
The blend door motor is a simple fix really so if they replaced all the motors for the doors it might be a bad motor for the temperature blend or they updated the program wrong somehow. Not totally sure but I think the motor to blend hot and cold is behind the glove box.
This is just speculation on my part.
Old 10-25-2013, 09:31 PM
jeb6294 jeb6294 is offline
Trim Level: SLT - Big Horn
Color: Grey
Rep:18
jeb6294 is on a distinguished road
Blend door actuator replaced!!! I will add one thing to Ramzaq's write-up. When I initially got the new actuator put back in everything started coming out as defrost. I'd recommend hooking the two connections to the HVAC module back up and making sure it works right before you replace everything. I had to take the actuator out, crank the selector to the vent setting and then turn the blend door by hand so it was coming out the vents so that way the door and actuator were both on the same page. After that I buttoned everything back up and all is good.
It really is very easy. I ended up getting a new actuator on eBay for $22. Even if they fixed it under the recall, it'd probably cost me more than that just to drive to the dealer. Just to give you an idea, I threw a frozen pizza in the oven for the boys just before I was putting everything back together. I still made it back inside with 3 minutes to spare.
Old 10-29-2013, 07:45 PM
Rep:251
Good point. Just plug everything in first to make sure it is running right.
Interesting about what you had to do to get it working properly. Pretty much just plugged mine in and it worked. I did have to move the gear I turned 180 out a tooth or two to get a proper lineup, but that was about it.
Glad to hear everything worked out well and you didn't burn the pizza.
Old 10-31-2013, 10:12 PM
Color: Grey
Rep:18
Who makes the actuators for Mopar? All the parts store actuators are from Dorman. I just replaced my bad actuator and the new one started clicking after a few days. I just got another one and replaced it, but I took the original and Dorman actuators apart and, as cheesy as the stock one is supposed to be the aftermarket look even worse.
Old 12-09-2013, 11:35 AM
troygt troygt is offline
Color: Metallic Black
troygt is on a distinguished road
Default Chrysler Case
Guys... had the same problem with the clicking noise in the dash. I lost the ability to direct air to the front windshield for defog/defrost purposes. I took my vehicle to the local Dodge dealership to have Cust Satisfaction Notification K17 done on my vehicle. But, they refused because my particular VIN didn't show that K17 was an option for me. I called the number on the K17 notification and opened a case with Chrysler... they called my dealership while I was still on the line and talked with the service manager. When Chrysler came back to me, they transferred me to my dealers service manager to schedule an appointment to have it done.
I'm very satisfied. If you're VIN doesn't show up, don't worry... just call Chrysler and they will make sure the problem is taken care of. Now that's an example of making customer satisfaction a top priority.
-Troy
clicking noise? 98redbull2 5.2L V8 Specific Topics 5 10-23-2015 06:55 PM
Clicking noise StormTrippinFiVe9 Suspension 11 04-26-2014 08:56 PM
Clicking noise in rear end HemiGTX Suspension 3 10-24-2012 02:22 PM
Darn thing won't start --> clicking noise under dash david05111 5.2L V8 Specific Topics 3 05-01-2011 09:48 PM
engine clicking noise on cold starts John999 Dodge Ram General Discussion 9 01-07-2011 05:06 AM
