Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.7-liter V6 engine - 210 horsepower, 235 lb-ft of torque.
Place your Ad Here!
Old 03-27-2014, 03:14 PM
kmccune kmccune is offline
Vehicle: 2006 Dakota
Engine: 2002-2012 226ci (3.7L) Magnum/PowerTech V6 215hp 235lb/ft
kmccune is on a distinguished road
Howdy Guys ,new to the Forum(best one I've ever seen) have a love hate relation with my 06 3.7 Dakota,what I really dislike is that the Guys with the V-8s claim as good or better gas mileage then my truck gets,I would like to to help things a little bit(already have CAI installed{super turbo muffler didn't help a thing,it finally rusted off} what do you recommend? E fan? or underdrive pulleys?,looking for bang for the buck ,mpg improvement desirable too,I see a brand new E-fan from Dorman for about 160$ for a 2010 ram V-6,will that work-hello and thanx-Kevin
Old 03-31-2014, 02:14 AM
smoknight's Avatar
smoknight smoknight is offline
Vehicle: 2014 ram reg cab
Trim Level: base
Color: silver
smoknight is on a distinguished road
Use supper unleaded. You will get 1-2 more miles per gallon. No a good bang for your buck in millage but the added response you will have will be well worth the price. After a few tanks if you think there is no difference in power go back to the cheaper plain unleaded. Before the tank is empty your going to be hardly able to wait to filler up with premium. So you can have the power back at higher speeds. I just can't figure out why this is not on your list of modification for this six banger.
Old 05-09-2014, 09:17 PM
RT65 RT65 is offline
Vehicle: 2003 Dodge Ram
Trim Level: Stand cab shortbox
RT65 is on a distinguished road
Well that's a pretty good list of things to start with. I swapped my gear set out and managed to find a set of 373's.I was gonna do the 410 deal but had some concerns about high rpm for hwy driving. What I would like to know is anyone here tried a supercharger or turbo setup yet? Just wondering how much more grunt could be gained from trying this out?
Old 06-12-2014, 08:27 PM
boyohboy's Avatar
boyohboy boyohboy is offline
Vehicle: 2008 Dodge Ram
boyohboy is on a distinguished road
Originally Posted by samsquanch View Post
Just look at all that room for an underhood intercooled turbo setup! Just need someone to step up and come out with a tuner for the 2012s. I pick mine up tomorrow night...
Originally Posted by HemiLonestar View Post
Gotta change your pistons if you're going to add boost, whole reason they stopped mking that kit for the 3.7's in the first place. High ring lands were breaking.
Sounds like a turbo set-up can be done but some internals need revamping. Lou.
Old 10-02-2014, 02:07 PM
Stampede4.7 Stampede4.7 is offline
Stampede4.7 is on a distinguished road
The TB can be bored out also.
Thanks.
Old 10-14-2014, 07:56 AM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
Default 3.21 ratio
Originally Posted by Tazdiablo View Post
Just one question. It shows you going up to higher gears but I read somewhere else that for best MPG you should go to 3.21 gears. Does anyone know about this or which is better as far as mpgs go?
I believe you'd be going the wrong way with the 3.21. That's 10 % lower than 3.55, if that's what's in your Ram. You'd need a lot more throttle to maintain your driving style and most likely never see the "eco on" light up unless you're going downhill or coasting. It's been said that gas mileage is maximized at rpm's where torgue is at it's max. If true, you'd have to drive faster, but then increased wind resistance would drag your mileage back down. It's a no-win situation. I do believe that factory engineers knew what was the best all around choice for your particular model and tranny. My favorite saying is always "if it ain't broke, don't fix it"
Old 12-14-2014, 09:06 AM
Ysuran Gunman's Avatar
Ysuran Gunman Ysuran Gunman is offline
Vehicle: 2006 Dodge Ram 1500
Color: Blue
Ysuran Gunman is on a distinguished road
Originally Posted by chambers View Post
Maybe this should get a sticky to make it easier to find. There are a good amount of mods that you can get for the 3.7 here is a list:
-Tuner either from hemifever for earlier years of the 3.7 or now hypertech has a tuner for 07-10 3.7's. As for the Jet chip I dyno'd one as I had it before there were tunes available and it showed gains only above 4k rpm on the dyno.
-Ported fastman throttle body, more air in just like the intake should help with power.
-Cold air intake, there are a lot of choices as you can easily make a 4.7 or 5.7 intake fit as long as the throttle body and air filter locations are the same as on your truck. I used a spectre intake for a hemi on my 3.7 and just had to use a big coupler from home depot to get the throttle body and intake tube lined up.
-Electric fan conversion. For this you remove the clutch fan that cools the engine and replace it with a electric fan and controller that tells it to turn on and off when needed. This can be done for as little as $100 with a ford taurus 3.8 fan, wiring, and a cheap controller. You can also buy the black magic 180 kit, but that costs a bit more. This was the only mod on my truck to increase my mpg, went up 1.5 mpg.
-Exhaust, there are shorty headers from jba which I posted about in the exhaust section. Pair them with a magnaflow y-pipe and muffler and you'll have some more grunt.
-Underdrive pulley, both ASP and ATI have underdrive pulleys that fit the 3.7. I'm not 100% on which years they fit, but I have the ASP on my 04 and it gave it some more grunt.
-Regearing, you can regear the rear end to give you more grunt and help alleviate loss of power from bigger tires, I went from 3.55 to 4.10 in my truck. If you do this the most important thing is to find a good installer who works on dodge 9.25 rears often.
-180 thermostat, not really sure what performance this gives but it was recommended with my tuning so I replaced the oem with a stant 45358. All I had to do was drill a bleed hole in it to match the stock t-stat and put it in.
-Cams, you can get stock cams reground and should be able to get more power from the truck. It will require running lash caps and can be quite expensive especially if you can't do the install yourself. I talked to both Crower and Crane about doing regrinds, but decided against it just because it was going to cost so much for the cams, then regrind, then install and I wasn't even sure if I would get good enough power to make the investment worth it.
If anyone knows of any others post them up.
Do you have any links where I could acquire some of these parts?
I've got an 06 ram quad cab with the 3.7L V6
Also, would I need to look for parts for the 02-05 v6 or the 07-10 v6?
Old 02-12-2016, 07:27 PM
spanky56's Avatar
spanky56 spanky56 is offline
Vehicle: 2002 dodge ram 1500
Trim Level: st
Color: metallic grey
spanky56 is on a distinguished road
So i see that this is an older thread but has anybody gotten reported gains from these mods? and has anybody checked out the knowlton headsfrom airram? they seam really pricey and dont really know if they are worth it.
Old 07-23-2016, 07:10 PM
DodgeRob DodgeRob is offline
Vehicle: 2006 Dodge Ram 1500 ST
DodgeRob is on a distinguished road
To change out that Y pipe, from factory, it looks like I need to change everything from the Cats. to the muffler to replace it. Should I cut the existing pipes from the cats and install sleeves? Or just go all the way up to the factory headers? How legal is it going to be without the cats? I live in Az. I think those are required.
Mod list datboiryan 2010 Dodge Ram Forum 6 06-15-2011 01:02 PM
Performance Mod Questions FLsportsman32 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 15 05-10-2011 09:15 PM
2nd MOD LIST COMPLETE!... AND YES PICS Kearns16 2010 Dodge Ram Forum 16 02-28-2011 09:34 PM
Gear and performance mod help E.L.D. 44 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 7 02-08-2011 11:07 PM
