Old 09-11-2011, 04:40 PM
crip crip is offline
Vehicle: 2000 dodge ram 1500
Color: green
crip is on a distinguished road
Default binding noise/brakes sticking in rear?
when i stop then take off sounds like something binding in rear end or brakes sticking. when come to a stop and turn L or R the sound is louder and easier to hear. i listened from outside the truck with someone else pulling off slowly and it sound like its inside the drum on both rear drums. anyone have an idea of what this could be? could both wheel cylinders be bad? when i get some time i was going to puill of the drum and see what it looks like inside. any ideas would be great. thanks trucks a 2000 ram 1500 5.2L
Old 09-12-2011, 09:00 AM
Color: green
Took drivers drum off andlooked fine. Need some ideas
Old 10-08-2011, 03:08 AM
GradyR GradyR is offline
Vehicle: 2000 Ram
Trim Level: not sure
Color: Blue
GradyR is on a distinguished road
not sure but mine is doing the same thing keep us updated
Old 10-08-2011, 02:14 PM
Rep:2620
When was the last time that you serviced the rear end
Does it have any fluid in it
It may be the wheel bearings, but it could be something way more serious
Good luck
Old 10-09-2011, 03:08 AM
Vehicle: 2000 Ram
Color: Blue
not meaning to thread jack
at first i thought it was the wheel bearings so i replaced the and inspected the rear end gears while one of the wheel bearings were on it's way out they were not shot and it still does it after i put the new ones in however i am going to replace the wheel cylinders next weekend and see if that fixes the problem it sounds like a sticky rear break and it only does it when the breaks/rear end gets good and hot also it only makes the sound when i stop completely and go again until the wheels make about 2 or 3 fill turns then it stops untill i stop again but like i said it only does it after about 25 or 30 miles of driving
Old 10-09-2011, 09:49 AM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
I'd be checking your U -joints, based on your description. And I would check your pinion bearing and check your rear diff fluid level.
Lastly, if your truck has a limited slip differential, nothing else is bad, and you abuse it, you may want to pop off your rear cover and make sure you didn't break some of the retaining washers that hold the plates in place. That's a long shot.
Old 06-03-2013, 07:22 PM
jphotroder jphotroder is offline
Vehicle: 2001 dodge durango
Color: green
jphotroder is on a distinguished road
I think it may be the abs rear speed sensor gone out.
New Rear window with defrost 05DodgeRam2500 Dodge Ram General Discussion 16 02-11-2015 06:32 PM
Just Got My Build Sheet highlandchef 2009 Dodge Ram Forum 11 05-24-2011 06:12 PM
does dodge ram have issues with rear ends on there trucks ? nitro1965 5.7L V8 Specific Topics 9 04-17-2011 12:03 PM
Rear End SHOT! BOSS 32V 5.7L V8 Specific Topics 3 03-25-2011 04:20 AM
Sticking rear doors billycanuk Dodge Ram General Discussion 4 10-22-2009 11:49 PM
