Old 09-11-2011, 03:56 PM
AZHunter86's Avatar
AZHunter86 AZHunter86 is offline
Vehicle: 2007 1500 Mega Cab 4x4
Rep:32
AZHunter86 is on a distinguished road
Default Biggest tire size without rubbing?
I just bought a '07 Mega Cab 1500 SLT 4x4 and have BFG All Terrains K/O LT275/70R17 and they look tiny on my truck... So i was wondering what's the largest size I can go without rubbing, I even took the stupid bumper shroud off.. I was thinking Goodyear Wrangler Duratracs in LT285/70R17 but not sure if I can go bigger
Old 09-12-2011, 09:30 AM
AZHunter86's Avatar
Rep:32
Now I'm also thinking about the Nitto Terra Grapplers in LT295/70R17... would these rub anywhere or would I be good at this size, apparently that diameter is 33.2
Old 09-12-2011, 10:00 AM
Twisted10's Avatar
Twisted10 Twisted10 is offline
Vehicle: 2012 Dodge Ram QC 4wd
Color: Mineral Gray
Rep:25
Twisted10 is on a distinguished road
u should be able to stuff a 35" tire under there.
u can squeeze 35's under a 1/2 ton w/o a lift.
where u have to be careful is width. much over 11.5 wide and they might rub.
Old 09-12-2011, 10:49 AM
285 will def work, 295 is a bit of a squeeze and you might rub inside at full steering lock. Don't go above a 70 series tire...that's too tall unless you want to install a leveling kit.
I have the same truck, 4" lift, 285/75RX18 (35") Toyo Open Country A/T tires, KMC XD Addict 18X9 wheels with a +18 offset. No rubs at all but they are kinda close to the trailing edge of the front wheelwells and the leading edge of the rear wheelwells.
I have plenty of room inside for a wider tire if I so choose.
Old 09-12-2011, 11:49 AM
AZHunter86's Avatar
Rep:32
hmm, I think I'll go with the 285's thinking of the goodyear duratracs they have aggressive side walls but if i had money to throw around i'd try the 295's, dang... well thanx for the feedback
Old 09-12-2011, 03:13 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
You sound like the same boat as me, I had a qc long bed and 285s still looked to small, 35s will fit but the 12.5 makes them rub on the control arms. The only way to stop that rubbing is to push the tires out and then you start rubbing on the lower part of the fender near the door.
Heres sorta an idea of how 285s look although the shadow sucks
Old 09-12-2011, 08:51 PM
AZHunter86's Avatar
Rep:32
O, I see... do any of you know if 295's are 12.5 wide... good lookin truck btw
Old 09-13-2011, 12:03 AM
Color: Mineral Gray
Rep:177
Thats how it sat almost 2.5 years ago, its leveled with 35s now
295mm is 11.6" wide, 285 is 11.2" wide
I think 295 would be safe but from what I remember from looking at tires before it is an odd size and they are pretty expensive when you do find them
Old 09-13-2011, 03:54 AM
AZHunter86's Avatar
Rep:32
damn, that gave your truck a whole new personality, how much was the level kit and those 35's are they 315s
Old 09-13-2011, 10:45 AM
Color: Mineral Gray
Rep:177
Leveling kit was $80 shipped from Hell Bent Steel. I ran them for over a year with stock length shocks with out problems, but I replaced them with shocks for a +2" lift, which were $45-$50 a shock and the ride is much better!
Those are 35x12.5x17, but my next set will probably be 315s. 315s are still going to rub but the rubbing isn't actually that bad. Our animal shoot is in a weird place and backing a live stock trailer into can be tough so I need all the turning radius this long of a truck has.
New set of wheels isn't in the budget yet so I have 1.75" spacers. It's not something I would really recommend, although I haven't had any problems they are only a temporary fix.
If your alright with a little bit of rubbing (which is only at full turn) then I would say just go with 315/70/17. You can do this all at a process, 35s or 315s will fit without a leveling kit
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Determining Speedometer Error Due To Tire Size Change MADDOG Dodge Ram Wheels And Tires 16 01-04-2015 06:33 PM
biggest tire size? anyone knows? slamtime155 2011 Dodge Ram Forum 6 04-25-2011 12:04 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
What tire size for 24 inch rims wesr52 2010 Dodge Ram Forum 7 02-09-2011 05:33 PM
