Do These Look Plasti-Dipped? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-27-2013, 06:06 PM
jeb6294 jeb6294 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: SLT - Big Horn
Color: Grey
Rep:18
jeb6294 is on a distinguished road
Default Do These Look Plasti-Dipped?
I just picked up this '09 with "custom" black wheels...as the salesguy tried to point out until I pointed out the big chunk peeling off one of the wheels. Just based on the picture and the fact that I can peel black of in big sheets from one of the wheels, are these plasti-dipped? Is this stuff meant to be temporary? Only one is peeling but the other three are pretty chipped up around the edge. They put new tires on it so I'm guessing it's from that.
Old 07-27-2013, 06:42 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
yep plastidip is temporary and thier flat coat is one of their best selling options. the front emblem maybe plastidip too.
Old 07-27-2013, 09:44 PM
Color: Grey
Rep:18
Yep, looks like the same finish so I'm guess the PO did both. The emblem seems to be holding up pretty well.
Old 07-27-2013, 09:47 PM
gotbrains230's Avatar
Vehicle: '12 RAM 1500
Rep:420
If its peeling off easy and in big chunks, chances are its plastidip. Powdercoat wouldn't peel like that, and paint would be in hard chunks
Plastidip
MATT
Old 07-28-2013, 12:54 AM
012RAMbo's Avatar
012RAMbo 012RAMbo is offline
Vehicle: 2012 Ram 1500 CC
Rep:264
Pretty sure that's plasti dip. Looks like they also dipped the oem mopar side steps as well as the front emblem.
Cabin Air Filter -Debadged -14" Magnaflow -Mopar T Grip Shifter -Foxbox w/ 10" Type Rs -B Pillar tape removed -Tint matched - Rear level - 22'' SRT-10 reps on 305/45/22 nitto 420s -AMP Power Steps - Custom retro headlights
Old 07-28-2013, 02:11 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Most definitely Plasti-Dip. Those are stock rims that have been dipped. They do look good dipped, but you need to tell that salesman to take long walk off a short pier.
Old 07-28-2013, 08:47 PM
Color: Grey
Rep:18
I was a little worried because initially he had mentioned fixing the wheel that was actually peeling, but after we got our deal done I don't think he was very happy because he wasn't putting any more money into it. Once I saw the Plati-Dip is only $25 or so I was fine with it. I'll probably see about just doing the one wheel and keeping the rest and doing the other wheels as they need it.
Couple questions....
will this stuff hold up going through a car wash?
Will I have to peel the rest off the wheel or can I just touch up the spots where it peeled?
Old 07-28-2013, 09:22 PM
AlbertaFarmBoy's Avatar
AlbertaFarmBoy AlbertaFarmBoy is offline
Vehicle: 2002 Ram 1500 4x4
Rep:14
AlbertaFarmBoy is on a distinguished road
The plasti-dip should hold up in the car wash if it was done properly (had enough coats put on). I would just take it easy the first time you wash it and make sure none is peeling afterwards. Unfortunately it is is peeling and you try to touch it up, you will see a ridge where the old plasti-dip ended and the new application started because it is put on in layers so you will get some plasti-dip on the old layers when you put it on the peeled off bit, making the old plast-dip higher. I would suggest just using a paint thinner or minerals spirits to thin the plasti-dip and try to get rid of the edge of the old stuff by spreading it out before applying new plasti-dip. That way there is no ridge when you apply more. Best of luck!
Farm Kid from Alberta. 2002 Ram 1500 crew cab 4x4 sport. Plasti-dip badges, 18" Magnaflow muffler
Old 07-28-2013, 10:54 PM
Rep:2968
Good advice from the FarmBoy. You'd do well to follow his direction.
Old 07-29-2013, 11:33 AM
Color: Grey
Rep:18
Should the color still match pretty well (assuming it is Plasti-Dip)? I'm not sure if this stuff fades over time cause if it does I'm not even sure how long ago it was put on. Would I be better off just peeling the one wheel and doing the whole thing?
