Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.7 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Factory Spec: 3.7-liter V6 engine - 210 horsepower, 235 lb-ft of torque.
ZDOG
Old 10-30-2011, 02:42 AM
HemiLonestar's Avatar
Rep:280
Myth. If you lose torque with headers on one engine, you'd lose torque with headers on any engine. You gain overall torque with headers.
Not necessarily. Each engine reacts differently depending on the way it's cammed and tuned. Just like if you go with too big of an exhaust on a newer hemi you'll lose some low and mid-range. You gain overall power, especially higher up with headers. A stock 3.7 just doesn't need them. There's a guy I know with a 3.7 in a Jeep that just swapped back to the stock manifolds because the JBA's leaked constantly and he said it felt like it fell flat on it's face. Now if the cams have been upgraded, compression, tuning, etc, then headers on a 3.7 may be worth it.
"Big Red"
2006 Charger R/T
Old 11-06-2011, 10:20 PM
chambers chambers is offline
Vehicle: 2004 Dodge Ram 1500
Rep:29
chambers is on a distinguished road
Interesting, did your friend use mopar or jba gaskets when he put them on? I haven't had any issues w/ mine leaking and I used the gaskets they sent w/ them. Did he have other mods to compliment the headers? I think a good tune is a must w/ them in order to see their potential.
Old 11-06-2011, 10:43 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
You'll be fine man, the "less back pressure makes you lose low end" thing is not true, it's a misconception. The reason people sometimes lose low end from an exhaust change is that they go with a larger diameter exhaust. A larger diameter pipe slows exhaust gas velocity and this hurts low end power. If you have a proper sized exhaust you won't lose low end, even with headers and a free flowing muffler. Less back pressure is ALWAYS better; people just seem to think it's the back pressure that effects low end, but it's actually the exhaust gas velocity. If you have the stock exhaust tubing for most of the exhaust you won't lose any torque with the headers.
Sean
Old 11-06-2011, 10:56 PM
Rep:29
Oh I know, I was just interested in the issues his friend experienced.
Old 11-06-2011, 11:03 PM
snrusnak's Avatar
Rep:1385
Gotcha. How thick is the flange on the headers where it bolts to the heads? That is usually what makes them leak is when the cheaper manufacturers use thinner flanges and they end up warping from the heat. The exhaust port in the head is the hottest part on the whole engine, the header right at the flange is basically the same temp...
Sean
Old 11-07-2011, 01:12 PM
Rep:29
It's pretty thick, I think close to as thick as the oem manifolds.
Old 11-07-2011, 02:41 PM
snrusnak's Avatar
Rep:1385
Ok. Some cheapo companies use 3/16" that's not good at all. Most use 1/4" which is ok, but 3/8" is much better, I've even seen 1/2" as well.
Sean
Old 11-07-2011, 08:46 PM
Rep:29
JBA's site says 3/8, I'm too lazy to go out and measure to confirm it.
Old 11-07-2011, 08:57 PM
snrusnak's Avatar
Rep:1385
Cool sounds like a good deal you got on a good product!
Sean
Ebay stainless headers 2000RAM Exhaust 7 03-16-2012 08:47 AM
Headers and Exhaust PhillyMarine79 5.7L V8 Specific Topics 2 03-08-2011 09:42 PM
types of headers Place186 Exhaust 2 02-14-2011 01:24 AM
headers on truck Scotty1500 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 8 05-11-2010 12:26 AM
Which length headers are the best 04 hemi Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 6 01-30-2009 12:24 AM
