Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 09-24-2011, 03:58 PM
Rye0an's Avatar
Rye0an Rye0an is offline
Vehicle: 2011 ram
Color: Deep water blue
Rep:22
Rye0an is on a distinguished road
Originally Posted by Gene K View Post
Oil is supposed to be checked hot after a 20 minute drain down although I realize this is seldom done.
1. Fill the engine with 1 quart less than specified.
2. Drive the car until you reach full operating temp.
3. Pull dip stick (this is so you wont have oil in tube and can get a very clean reading).
4. Allow 20 minutes drain down time.
5. Check oil noting level on stick.
6. Scribe stick, this is now your new add mark.
7. Add 1 quart of oii.
8. Allow 20 minutes drain down time.
9. Check oil level noting level on stick.
10. Scribe stick, this is now your new full level mark.
Its always preferred to calibrate the stick to the engine instead of the other way around.
anyone done this and checked how accurate the stick is?
Old 09-24-2011, 08:28 PM
ramit355's Avatar
ramit355 ramit355 is offline
Vehicle: 2014 1500 4x4 CC Laramie 392
Trim Level: Laramie Crew Cab
Rep:28
ramit355 is on a distinguished road
Excellent information and thanks....but you would think a 40k truck would have a ready dip stick to read with out any scribing of any thing!!!!
Old 10-02-2011, 12:00 AM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
Engines that cost considerably more than the whole truck come with those instructions in the owners manual. The only difference is that its usually not specified in quarts. You will find in most cases the sticks are off a little. In an engine with 10.5 gallon oil capacity I found it was off by about 1/2 gallon. That would be equivalent to about 0.33 Qt in a Hemi.
Gene
4.7 dipstick wrong? gt8287 4.7L PowerTech V8 Specific Topics 6 07-24-2011 11:16 AM
Oil Entering the Radiator System SpecialEd 3.7L PowerTech V6 Specific Topics 6 07-15-2011 10:21 AM
Where did it go????????? bigred0603 4.7L PowerTech V8 Specific Topics 5 04-03-2011 11:54 PM
RRT 10-073 CTD Dipstick Change RamTech Dodge Ram Recalls and TSB's. 1 11-16-2010 09:37 PM
