Old 09-11-2011, 09:44 PM
firecadet613 firecadet613 is offline
Vehicle: 2006 Ram 2500 Hemi
firecadet613 is on a distinguished road
Default P1128 p1129
I've got an '06 2500 Hemi 4x4.
Changed the plugs at 30k miles when I got it, with the factory Champions.
Out of no where, one day I started it up and she was hesitating/surging a bit under 2500 RPM while accelerating, but only for the first minute she was on.
I got codes 1128 and 1129. No matter how many times I clear them, they come back. 0132 was thrown today, but it did not come back.
I put a new MAP sensor on, and that did not change anything.
Any ideas?
Old 09-11-2011, 10:03 PM
Rep:2657
Welcome to this ForumZ
Hopefully someone that knows the codes will answer up soon
Old 09-11-2011, 10:09 PM
Did a search and found some helpful info.
May be bank 1 sensor 1. On the previous Dodge forum I was on no one had any idea...5 different threads about it here!
Old 09-12-2011, 01:53 PM
adventurer's Avatar
adventurer adventurer is offline
Vehicle: 2010 Ram and 2006 Ram Hemi
Trim Level: 4x4 SLT and4X4 SPORT
Color: Silver , Flame Red
adventurer is on a distinguished road
Send a message via Skype™ to adventurer
I hope this will help
Diagnostics Trouble Code Descriptions
P0016-crankshaft/camshaft Timing Misalignment 2.7l
P0016-crankshaft/camshaft Timing Misalignment 3.5l
P0016-crankshaft/camshaft Timing Misalignment 5.7l
P0031-o2 Sensor 1/1 Heater Circuit Low
P0032-o2 Sensor 1/1 Heater Circuit High
P0037-o2 Sensor 1/2 Heater Circuit Low
P0038-o2 Sensor 1/2 Heater Circuit High
P0051-o2 Sensor 2/1 Heater Circuit Low
P0052-o2 Sensor 2/1 Heater Circuit High
P0057-o2 Sensor 2/2 Heater Circuit Low
P0058-o2 Sensor 2/2 Heater Circuit High
P0071-ambient Air Temperature Sensor Performance
P0072-ambient Air Temperature Sensor Circuit Low
P0073-ambient Air Temperature Sensor Circuit High
P0107-manifold Absolute Pressure Sensor Circuit Low
P0108-manifold Absolute Pressure Sensor Circuit High
P0111-intake Air Temperature Sensor Performance
P0112-intake Air Temperature Sensor Circuit Low
P0113-intake Air Temperature Sensor Circuit High
P0116-engine Coolant Temperature Sensor Circuit Performance
P0117-engine Coolant Temperature Sensor Circuit Low
P0118-engine Coolant Temperature Sensor Circuit High
P0121-throttle Position Sensor 1 Performance
P0122-throttle Position Sensor 1 Circuit Low
P0123-throttle Position Sensor 1 Circuit High
P0125-insufficient Coolant Temperature For Closed-loop Fuel Control
P0128-thermostat Rationality
P0129-barometric Pressure Out-of-range Low
P0131-o2 Sensor 1/1 Circuit Low
P0132-o2 Sensor 1/1 Circuit High
P0133-o2 Sensor 1/1 Slow Response
P0135-o2 Sensor 1/1 Heater Performance
P0137-o2 Sensor 1/2 Circuit Low
P0138-o2 Sensor 1/2 Circuit High
P0139-o2 Sensor 1/2 Slow Response
P013a-o2 Sensor 1/2 Slow Response - Rich To Lean
P013c-o2 Sensor 2/2 Slow Response - Rich To Lean
P0141-o2 Sensor 1/2 Heater Performance
P0151-o2 Sensor 2/1 Circuit Low
P0152-o2 Sensor 2/1 Circuit High
P0153-o2 Sensor 2/1 Slow Response
P0155-o2 Sensor 2/1 Heater Performance
P0157-o2 Sensor 2/2 Circuit Low
P0158-o2 Sensor 2/2 Circuit High
P0159-o2 Sensor 2/2 Slow Response
P0161-o2 Sensor 2/2 Heater Performance
P0171-fuel System 1/1 Lean
P0172-fuel System 1/1 Rich
P0174-fuel System 2/1 Lean
P0175-fuel System 2/1 Rich
P0196-engine Oil Temperature Sensor Performance
P0197-engine Oil Temperature Sensor Circuit Low
P0198-engine Oil Temperature Sensor Circuit High
P0201-fuel Injector 1 Circuit
P0202-fuel Injector 2 Circuit
P0203-fuel Injector 3 Circuit
P0204-fuel Injector 4 Circuit
P0205-fuel Injector 5 Circuit
P0206-fuel Injector 6 Circuit
P0207-fuel Injector 7 Circuit
P0208-fuel Injector 8 Circuit
P0221-throttle Position Sensor 2 Performance
P0222-throttle Position Sensor 2 Circuit Low
P0223-throttle Position Sensor 2 Circuit High
P0298-engine Oil Temperature Too High
P0300- Multiple Cylinder Misfire
P0301-cylinder 1 Misfire
P0302-cylinder 2 Misfire
P0303-cylinder 3 Misfire
P0304-cylinder 4 Misfire
P0305-cylinder 5 Misfire
P0306-cylinder 6 Misfire
P0307-cylinder 7 Misfire
P0308-cylinder 8 Misfire
P0315-no Crank Sensor Learned
P0325-knock Sensor 1 Circuit
P0330-knock Sensor 2 Circuit
P0335-crankshaft Position Sensor Circuit
P0339-crankshaft Position Sensor Intermittent
P0340-camshaft Position Sensor Circuit 2.7
P0340-camshaft Position Sensor Circuit 3.5
P0340-camshaft Position Sensor Circuit 5.7
P0344-camshaft Position Sensor Intermittent 2.7
P0344-camshaft Position Sensor Intermittent 3.5
P0344-camshaft Position Sensor Intermittent 5.7
P0401-egr System Performance
P0403-egr Solenoid Circuit
P0404-egr Position Sensor Performance
P0405-egr Position Sensor Circuit Low
P0406-egr Position Sensor Circuit High
P0420-catalyst Efficiency (bank 1)
P0430-catalyst Efficiency (bank 2)
P0440-GENERAL EVAP SYSTEM FAILURE
P0441-EVAP PURGE SYSTEM PERFORMANCE
P0443-EVAP PURGE SOLENOID CIRCUIT
P0452-EVAP PRESSURE SWITCH STUCK CLOSED
P0455-EVAP PURGE SYSTEM LARGE LEAK
P0456-EVAP PURGE SYSTEM SMALL LEAK
P0457-EVAP SYSTEM - LOOSE FUEL CAP
P0461-FUEL LEVEL SENSOR 1 PERFORMANCE
P0462-FUEL LEVEL SENSOR 1 CIRCUIT LOW
P0463-FUEL LEVEL SENSOR 1 CIRCUIT HIGH
P0480-COOLING FAN 1 CONTROL CIRCUIT
P0481-COOLING FAN 2 CONTROL CIRCUIT
P050B-COLD START IGNITION TIMING PERFORMANCE (ETC)
P0501-VEHICLE SPEED SENSOR 1 (NON-ABS)
P0503-VEHICLE SPEED SENSOR 1 ERRATIC (NON-ABS)
P0501-VEHICLE SPEED SENSOR 1 (EQUIPPED W/ABS)
P0503-VEHICLE SPEED SENSOR 1 ERRATIC (Equipped ABS)
P0506-IDLE SPEED PERFORMANCE LOWER THAN EXPECTED
P0507-IDLE SPEED PERFORMANCE HIGHER THAN EXPECTED
P050D-COLD START ROUGH IDLE
P0513-INVALID SKIM KEY
P0520-ENGINE OIL PRESSURE SENSOR CIRCUIT
P0521-ENGINE OIL PRESSURE SENSOR PERFORMANCE
P0522-ENGINE OIL PRESSURE SENSOR 1 CIRCUIT LOW
P0523-ENGINE OIL PRESSURE SENSOR 1 CIRCUIT HIGH
P0524-ENGINE OIL PRESSURE TOO LOW
P0532-A/C PRESSURE SENSOR CIRCUIT LOW
P0533-A/C PRESSURE SENSOR CIRCUIT HIGH
P0551-POWER STEERING PRESSURE SWITCH PERFORMANCE
P0562-BATTERY VOLTAGE LOW
P0563-BATTERY VOLTAGE HIGH
P0571-BRAKE SWITCH 1 PERFORMANCE
P0572-BRAKE SWITCH 1 STUCK ON
P0573-BRAKE SWITCH 1STUCK OFF
P0579-SPEED CONTROL SWITCH 1 PERFORMANCE
P0580-SPEED CONTROL SWITCH 1 CIRCUIT LOW
P0581-SPEED CONTROL SWITCH 1 CIRCUIT HIGH
P0585-SPEED CONTROL SWITCH 1/2 CORRELATION
P0591-SPEED CONTROL SWITCH 2 PERFORMANCE
P0592-SPEED CONTROL SWITCH 2 CIRCUIT LOW
P0593-SPEED CONTROL SWITCH 2 CIRCUIT HIGH
P0600-SERIAL COMMUNICATION LINK
P0601-INTERNAL MEMORY CHECKSUM INVALID
P0606-INTERNAL ECM PROCESSOR
P060B-ETC A/D GROUND PERFORMANCE
P060D-ETC LEVEL 2 APP PERFORMANCE
P060E-ETC LEVEL 2 TPS PERFORMANCE
P060F-ETC LEVEL 2 ECT PERFORMANCE
P061A-ETC LEVEL 2 TORQUE PERFORMANCE
P061C-ETC LEVEL 2 RPM PERFORMANCE
P0622-GENERATOR FIELD CONTROL CIRCUIT
P0627-FUEL PUMP RELAY CIRCUIT
P062C-ETC LEVEL 2 MPH PERFORMANCE
P0630-VIN NOT PROGRAMMED IN PCM
P0632-ODOMETER NOT PROGRAMMED IN PCM
P0633-SKIM KEY NOT PROGRAMMED IN PCM
P0642-SENSOR REFERENCE VOLTAGE 1 CIRCUIT LOW
P0643-SENSOR REFERENCE VOLTAGE 1 CIRCUIT HIGH
P0645-A/C CLUTCH RELAY CIRCUIT
P0652-SENSOR REFERENCE VOLTAGE 2 CIRCUIT LOW
P0653-SENSOR REFERENCE VOLTAGE 2 CIRCUIT HIGH
P0660-MANIFOLD TUNING VALVE (MTV) CONTROL CIRCUIT
P0685-AUTO SHUTDOWN RELAY CONTROL CIRCUIT
P0688-AUTO SHUTDOWN RELAY SENSE CIRCUIT LOW
P0700-TRANSMISSION CONTROL SYSTEM (MIL REQUEST)
P0703-BRAKE SWITCH 2 PERFORMANCE
P0850-PARK/NEUTRAL SWITCH PERFORMANCE
P1004-SHORT RUNNER VALVE CONTROL PERFORMANCE
P1005-MANIFOLD TUNING VALVE CONTROL PERFORMANCE
P1115-GENERAL TEMPERATURE RATIONALITY
P1128-CLOSED LOOP FUELING NOT ACHIEVED - BANK 1
P1129-CLOSED LOOP FUELING NOT ACHIEVED - BANK 2
P1239-ENGINE OIL TEMPERATURE TOO LOW
P1404-EGR POSITION SENSOR RATIONALITY CLOSED
P1411-CYLINDER 1 REACTIVATION CONTROL PERFORMANCE
P1414-CYLINDER 4 REACTIVATION CONTROL PERFORMANCE
P1416-CYLINDER 6 REACTIVATION CONTROL PERFORMANCE
P1417-CYLINDER 7 REACTIVATION CONTROL PERFORMANCE
P1501-VEHICLE SPEED SENSOR 1/2 CORRELATION - DRIVE WHEELS (NON-ABS)
P1502-VEHICLE SPEED SENSOR 1/2 CORRELATION - NON DRIVE WHEELS (NON-ABS)
P1501-VEHICLE SPEED SENSOR 1/2 CORRELATION - DRIVE WHEELS (EQUIPPED W/ABS)
P1502-VEHICLE SPEED SENSOR 1/2 CORRELATION - NON DRIVE WHEELS (Equipped ABS)
P150D-COLD START ROUGH IDLE - OPEN THROTTLE START
P1521-INCORRECT ENGINE OIL TYPE
P1572-BRAKE SWITCH STUCK ON
P1573-BRAKE SWITCH 1STUCK OFF
P1593-SPEED CONTROL SWITCH 1/2 STUCK
P1603-PCM INTERNAL DUAL-PORT RAM COMMUNICATION FAILURE
P1604-PCM INTERNAL DUAL-PORT RAM READ/WRITE INTEGRITY FAILURE
P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY
P1618-SENSOR REFERENCE VOLTAGE 1 CIRCUIT ERRATIC
P1628-SENSOR REFERENCE VOLTAGE 2 CIRCUIT ERRATIC
P1696-EEPROM MEMORY WRITE DENIED/INVALID
P1697-EMR (SRI) MILEAGE NOT STORED
P1897-PCM PROCESSOR
P1897-PCM PROCESSOR
P2008-SHORT RUNNER VALVE (SRV) CONTROL CIRCUIT
P2016-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT LOW
P2017-SHORT RUNNER VALVE (SRV) POSITION SENSOR CIRCUIT HIGH
P2066-FUEL LEVEL SENSOR 2 PERFORMANCE
P2067-FUEL LEVEL SENSOR 2 CIRCUIT LOW
P2068-FUEL LEVEL SENSOR 2 CIRCUIT HIGH
P2072-ELECTRONIC THROTTLE CONTROL SYSTEM - ICE BLOCKAGE
P2077-INTAKE MANIFOLD TUNING VALVE POSITION SENSOR CIRCUIT LOW
P2078-INTAKE MANIFOLD TUNING VALVE POSITION SENSOR CIRCUIT HIGH
P2096-DOWNSTREAM FUEL TRIM SYSTEM 1 LEAN
P2097-DOWNSTREAM FUEL TRIM SYSTEM 1 RICH
P2098-DOWNSTREAM FUEL TRIM SYSTEM 2 LEAN
P2099-DOWNSTREAM FUEL TRIM SYSTEM 2 RICH
P2100-ELECTRONIC THROTTLE CONTROL MOTOR CIRCUIT
P2101-ELECTRONIC THROTTLE CONTROL MOTOR PERFORMANCE
P2107-ELECTRONIC THROTTLE CONTROL MODULE PROCESSOR
P2108-ELECTRONIC THROTTLE CONTROL MODULE PERFORMANCE
P2110-ELECTRONIC THROTTLE CONTROL - FORCED LIMITED RPM
P2111-ELECTRONIC THROTTLE CONTROL - UNABLE TO CLOSE
P2112-ELECTRONIC THROTTLE CONTROL - UNABLE TO OPEN
P2115-ACCELERATOR PEDAL POSITION SENSOR 1 MINIMUM STOP PERFORMANCE
P2116-ACCELERATOR PEDAL POSITION SENSOR 2 MINIMUM STOP PERFORMANCE
P2118-ELECTRONIC THROTTLE CONTROL MOTOR CURRENT PERFORMANCE
P2122-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT LOW
P2123-ACCELERATOR PEDAL POSITION SENSOR 1 CIRCUIT HIGH
P2127-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT LOW
P2128-ACCELERATOR PEDAL POSITION SENSOR 2 CIRCUIT HIGH
P2135-THROTTLE POSITION SENSOR 1/2 CORRELATION
P2138-ACCELERATOR PEDAL POSITION SENSOR 1/2 CORRELATION
P2161-VEHICLE SPEED SENSOR 2 ERRATIC (Equipped ABS)
P2166-ACCELERATOR PEDAL POSITION SENSOR 1 MAXIMUM STOP PERFORMANCE
P2167-ACCELERATOR PEDAL POSITION SENSOR 2 MAXIMUM STOP PERFORMANCE
P2172-HIGH AIRFLOW / VACUUM LEAK DETECTED (INSTANTANEOUS ACCUMULATION)
P2173-HIGH AIRFLOW / VACUUM LEAK DETECTED (SLOW ACCUMULATION)
P2174-LOW AIRFLOW / RESTRICTION DETECTED (INSTANTANEOUS ACCUMULATION)
P2175-LOW AIRFLOW / RESTRICTION DETECTED (SLOW ACCUMULATION)
P2181-COOLING SYSTEM PERFORMANCE
P2271-O2 SENSOR 1/2 SIGNAL BIASED
P2273-O2 SENSOR 2/2 SIGNAL BIASED
P2299-BRAKE PEDAL POSITION / ACCELERATOR PEDAL POSITION INCOMPATIBLE
P2302-IGNITION COIL 1 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2302-IGNITION COIL 1 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2305-IGNITION COIL 2 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2305-IGNITION COIL 2 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2308-IGNITION COIL 3 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2308-IGNITION COIL 3 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2311-IGNITION COIL 4 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2311-IGNITION COIL 4 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2314-IGNITION COIL 5 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2314-IGNITION COIL 5 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2317-IGNITION COIL 6 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 2.7/3.5
P2317-IGNITION COIL 6 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2320-IGNITION COIL 7 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2323-IGNITION COIL 8 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION - 5.7/SRT8
P2503-CHARGING SYSTEM OUTPUT LOW
P2610-PCM INTERNAL SHUTDOWN TIMER FAST RATIONALITY
P3400-MDS RATIONALITY BANK 1
P3401-MDS SOLENOID 1 CIRCUIT
P3402-CYLINDER 1 DEACTIVATION CONTROL PERFORMANCE
P3425-MDS SOLENOID 4 CIRCUIT
P3426-CYLINDER 4 DEACTIVATION CONTROL PERFORMANCE
P3441-MDS SOLENOID 6 CIRCUIT
P3442-CYLINDER 6 DEACTIVATION CONTROL PERFORMANCE
P3449-MDS SOLENOID 7 CIRCUIT
P3450-CYLINDER 7 DEACTIVATION CONTROL PERFORMANCE
P3497-MDS RATIONALITY BANK 2
U0001-CAN C BUS
U0101-LOST COMMUNICATION WITH TCM
U0103-LOST COMMUNICATION WITH ELECTRIC GEAR SHIFT MODULE
U0121-LOST COMMUNICATION WITH ANTI-LOCK BRAKE MODULE
U0141-LOST COMMUNICATION WITH FRONT CONTROL MODULE
U0155-LOST COMMUNICATION WITH CLUSTER/CCN
U0168-LOST COMMUNICATION WITH VEHICLE SECURITY CONTROL MODULE (SKREEM/WCW)
U110A-LOST COMMUNICATION WITH SCCM - CAN - C
U110C-LOST FUEL LEVEL MESSAGE
U110E-LOST AMBIENT TEMPERATURE MESSAGE
U110F-LOST FUEL VOLUME MESSAGE
U1110-LOST VEHICLE SPEED MESSAGE
U1113-LOST A/C PRESSURE MESSAGE
U1120-LOST WHEEL DISTANCE MESSAGE
U1403-IMPLAUSIBLE FUEL LEVEL SIGNAL RECEIVED
U1411-IMPLAUSIBLE FUEL VOLUME SIGNAL RECEIVED
U1412-IMPLAUSIBLE VEHICLE SPEED SIGNAL RECEIVED
U1417-IMPLAUSIBLE LEFT WHEEL DISTANCE SIGNAL RECEIVED
U1418-IMPLAUSIBLE RIGHT WHEEL DISTANCE SIGNAL RECEIVED
2010- S&B CAI/87MM TB/HKS TB GW/OIL FILTER BREATHER/Y PIPE/PYPES VIOLATOR MUFFLER/HEMIFEVER TUNE.
06- MAGNAFLOW CAT-BACK/Y PIPE/TB SPACER/HKS-TB GW/MOPAR CAI/SUPERCHIPS/OIL BREATHER FILTER/JET 180 TSTAT/3.92 LSD
Old 09-12-2011, 04:20 PM
I should have posted, I know what the codes mean, just didn't know what to start with.
Putting in a new 1/1 O2 sensor today.
Old 09-12-2011, 04:39 PM
Rep:2657
I believe this may help you
you need to pull the connectors off & check for bent pins too
http://www.scribd.com/doc/36337099/p...a-Kk-2007-2010
Old 04-19-2013, 09:35 PM
DarcyJL DarcyJL is offline
Vehicle: 2007
DarcyJL is on a distinguished road
Did you ever find a solution to this? Im having the exact same problem.
Old 04-19-2013, 10:23 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Could be O2 sensors, but try some Seafoam first. Most automotive supply stores carry it. Put it in the gas tank and run for a couple days or say a 50 mile trip and see what happens. It cleans fuel injectors, carbon buildup and also cleans O2 sensors and the cats.
Old 04-19-2013, 10:52 PM
Vehicle: 2007
Sorry but i need a better answer then seafoam it that is not going to help me haha.
My motor totally cut in and out for a few seconds then stabilized and ran fine the rest of my 20min ride to work. Felt like fuel pump cutting in an out or could have been fuel filter clogging and breaking free after a few second, i guess ill find out.
Old 03-06-2015, 01:52 AM
Reyesh661 Reyesh661 is offline
Vehicle: 2007 dodge ram 1500 5.7 HEMI
Trim Level: Big horn
Reyesh661 is on a distinguished road
Hey what's up guys, thought I create an account and share my experience. My truck had p01128 and p1129. Replaced IAT and MAP Sensor and still had the same issue. (Stalling and dying on idle). Then I replaced 02 sensor. Same issue. Today I cleaned the throttle body and replaced the PCV valve, and codes are gone as well as the stalling and its really smooth at idle.
need help with p1128 dtc code nitro1965 5.7L V8 Specific Topics 7 09-24-2013 06:01 PM
