Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.9L V8 Specific Topics
Old 09-12-2011, 05:33 PM
TXRAM1975 TXRAM1975 is offline
Vehicle: 2003 Dodge Ram 1500
TXRAM1975 is on a distinguished road
Default Dodge Electrical Question
I have a 2003 Ddge Ram 1500, 5.9L and I'm having problems starting it. My A/C condenser fan went out and I tried to test the fan by connecting it directly to the battery to see if I could get it to operate before I got a new one. I must have touched the wrong wire to the battery because I heard a pop and now it won't start. I initially thought it was a fuse, but I checked all the fuses in the fuse panel under the hood and all are still good. I don't know what to do now and hope I didn't totally screw something up. When I try to start it, it turns over but won't start. Any ideas would be appreciated.
Old 09-15-2011, 10:16 AM
RAMING IT's Avatar
RAMING IT RAMING IT is offline
Vehicle: 2002 DODGE RAM
Trim Level: QC SLT 2WD
Color: Almond Pearl, Blacked Out
Rep:65
RAMING IT will become famous soon enough
So your truck wont start at all because of your ac condensor fans out??
Heavy A$$ truck w/ ported stock heads, intake / heads gasket matched, keg mod, iat mod, cks mod, 2 tone vinyl wrap, blacked out trim, (pcm junkyard mod)
Old 10-02-2011, 12:55 AM
RedneckMechanic RedneckMechanic is offline
Vehicle: 2002 Dodge Ram 1500 4x4
Rep:28
RedneckMechanic is on a distinguished road
Sounds like the 'pop' you heard may have been a relay. Not a fuse... Check the ASD (Auto Shut Down) Relay... Swap it out with one of the other relays in the box that has the same part number. Be sure though that the one you swap it with isn't detrimental to starting your truck.
Old 10-02-2011, 02:00 AM
RAMING IT's Avatar
Rep:65
Cool
What would cause the ASD relay to trip????
Old 10-02-2011, 11:58 PM
Rep:28
Any number of short circuits. If the PCM feels in any way that there will be catastrophic damage to the engine or the PCM, it'll cut power to the ASD relay. But if you heard a pop and nothing's working, it was more than it could handle... Is it even cranking? Do you have power with the key on? I'll do some research at work tomorrow and see what I can find.
Old 10-03-2011, 08:01 AM
RAMING IT's Avatar
Rep:65
Thanks so much bud!!!!
Old 10-05-2011, 12:33 AM
Rep:28
Well, I did some looking and asking around at work and the concensus is, without physically looking at it, it's hard to tell what exactly happened. Honestly, I would look at the relays first, if you're SURE none of the fuses blew. Some fuses will pop and the separation will be at the leg of the spade and hard to see. BUT, in retrospect, if you actually HEARD it, it was probably enough to blow the filament apart and would easily be seen...
Worst case scenario, the pop you heard was the ECM... But the fan relay should have taken the brunt of the surge and blown before it had a chance to get THAT far. Here's a schematic of the condenser fan and relay:
I know it's not much help and I apologize, but I hope you can get a little further with this info... Let me know if you find anything or need any other assistance. I'll look some more at the circuitry when I get a chance and see if I can see anything else.
Old 10-05-2011, 04:36 AM
RAMING IT's Avatar
Rep:65
Cool Goodwork!
All I gotta say is
Old 10-08-2011, 02:16 PM
RAMING IT's Avatar
Rep:65
Im sorry guys I know this isnt my thread but I was having the same issue.. Hey TXRAM did you have any luck trouble shooting your ram??
Old 10-08-2011, 09:49 PM
Rep:28
Are you having problems with your condenser fan not working? I had (still have) that issue. My fan motor is shot... If you disconnect it and test for resistance between the two pins on the fan plug and it reads OL, it's shot.
'83 Dodge Power Ram 150 4x4 SMOG QUESTION PLEAS HELP!! country livin 5.2L V8 Specific Topics 5 01-18-2012 08:05 PM
Can you help me with this question im new here and new to having a Dodge chomper Newbie Checkin! 9 10-30-2009 07:17 PM
Question about Dodge Ram Parts ponchopower Dodge Ram General Discussion 6 08-05-2009 12:30 AM
96 Dodge 1500 V8 Question (?) HELP!!!!!! atdunn 5.2L V8 Specific Topics 3 08-02-2009 11:13 PM
01 dodge ram lift question guys i need help??? greenfury Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 02-24-2009 10:01 PM
