Old 09-12-2011, 11:19 PM
ToDieFor71 ToDieFor71 is offline
Vehicle: 2010 Ram 1500
Color: Mineral Gray Metallic
ToDieFor71 is on a distinguished road
Default blacked out grill and bumpers?
hey guys ive seen some pictures of some trucks on here that people blacked out the grill and bumpers and stuff I was wondering how you guys did it just regular spray can paint? I want to do the same but definately dont want to mess it up. also did you guys sand it or??? thanks alot!
Old 09-12-2011, 11:36 PM
ORT's Avatar
ORT ORT is offline
Vehicle: 2004 Dodge Ram
Rep:184
ORT has a spectacular aura aboutORT has a spectacular aura about
I've blacked out everything on my truck. If you go with rattle can spray make sure you prep good and use a quality color and clear. If you do it will turn out fine.
Sidewinder Cam/Edge Converter/Pacesetter LT's/SCT&SC Stack/Hemifever Tune/BFI #32/20% UD Pulley/Fastman TB/Triple Pillar/1 TonCooler/Sonnax/E-Cutout/Venom Hood/SRT Bumper/Roll Pan/HID's/Aeroforce Wideband/E-Fan/Hellwig/2" Drop/170 Stat/D&S Rotors/Remote Start/Hella 500's/5% Tint/Black Everything
Old 09-12-2011, 11:41 PM
can you please explain how you prepped it all and what paint/clearcoat you would recommend? thanks alot ive been wanting to do this since I bought the truck!
Old 09-12-2011, 11:43 PM
o and was yours chrome before you blacked it all out? does that make a diffrence?
Old 09-12-2011, 11:48 PM
ORT's Avatar
ORT ORT is offline
Rep:184
I got my paint from paintscratch. They sell factory colors in rattle cans. Some parts started out as chrome like my side steps and grill. Other parts were just primered or painted when I got them like my roll pan and wheels. And my front bumper was raw plastic when I got it.
When I painted my side steps I cleaned them real good, then sanded them down good and then primered, painted and cleared them.
Old 09-13-2011, 10:39 AM
Thanks alot I'm gonna give it a shot prob start with the nerf bars
Old 09-13-2011, 11:46 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Do some research online for how to properly prep for paint. The spraying of the paint is the easy part (as long as you don't do anything careless). Chrome is difficult to paint, but there are ways to do it. Black is also the hardest color to paint. Not trying to scare you off, just do alot of research before you do it, alot of prep goes a long way, a little prep goes a little way....I've done good paint jobs using crappy rattle can paint and good prep and they turn out good and last. I've also seen bad prepped jobs with the best paint and they don't last.
Sean
Old 09-13-2011, 12:36 PM
ORT's Avatar
ORT ORT is offline
Rep:184
^prep is key^. I spent a week prepping my srt front bumper just to make sure it was as perfect as I could get it. Now you can't even tell it is painted from a rattle can and I attribute that to the prep.
Old 09-13-2011, 01:16 PM
snrusnak's Avatar
Rep:1385
And some tips that I've found....don't bother wasting money on expensive prep products. All I ever use is the following:
You don't have to buy all the expensive paint prep products either....here's what I do for just about any paint process:
Wipe old surface with mineral spirits, then wipe with dawn dish soap/water mixture
Wet sand old surface (can use paint remover if you have to strip old surface....then clean with mineral spirits, then dish soap/water, then wet sand)
Just before you are ready to spray first coat, wipe surface with mineral spirits, then wipe with a mixture of water/dawn dish soap
Wipe surface with a tack cloth to pick up any dust
Spray
Wet sand lightly with a finer grit in between coats, then wipe with dish soap/water mixture.
Spray
Repeat as necessary
When you are done, wet sand lightly with finer and finer grits up to about 3000, then rub out with rubbing compound, then rub out with polishing compound. You can buy everything you need at autozone and walmart.
Notice one of the main things is keeping the surface clean of dirt/oils/waxes at all times, this includes what it touches too (your hands, table, etc.....)
Sean
Old 09-13-2011, 11:19 PM
RIDERED67 RIDERED67 is offline
RIDERED67 is on a distinguished road
Heres the problem with spray paint; It will not last! You can spend days and weeks laying a killer looking spray bomb paint job on a car, motorcycle etc. but it will never look any better than when its fresh and that aint for long!
Spray paint lacks the UV protection that is needed if you plan on letting your paint job sit out in the sun. Spray paint will quickly fade. Even when fully cured a spray paint job will not be as hard or durable as a quality paint job.
Ive done many spray paint jobs and the trick is knowing what to use spray paint on and what to leave to the pros.
Here is the best writeup I've ever read on how to do a spray bomb paint job. I do not who wrote these steps or i would give them credit.
I am no professional painter, however I am very experienced in using can spray paint for various purposes on a variety of surfaces. I have done everything from small bits and pieces to full mural art. I have painted cars, motorcycles, boats, and much more all using “rattle cans”. I decided to post this in order to help anyone who may not have experience using the “rattle can” method. I have seen various posts where someone gave some advice on painting, some using rattle can and some using professional equipment. I intend on covering every step in this thread. I hope anyone who has experience, will elaborate or criticize any of my method they see fit in order to prefect a collaborative method. The main reason I wanted to do this thread is I have seen where lesser experienced people have struggled with “rattle canning”. I hope they can use this as a reference.*
Keys to a great rattle can job:
1. * Start with good body work
2. * Buy good quality brand paints
3. * Learn to move in one direction with long even strokes
4. * Create a make-shift paint booth(good lighting, sealed off from bugs/dusts/wind)
5. * GOOD PAINT TAKES TIME!
Tools and supplies needed:
1. * Dual action sander, preferably variable speed or at least a variable speed trigger
2. * Sand paper for DA sander, 400 grit / 800grit / 1200grit / 2000grit
3. * Denatured alcohol
4. * Liquid soap
5. * Lint free cloths (clean)!
6. * Filler primer ( I like the gray rustoleum brand)
7. * Body color paint
8. * Clear enamel paint
Intro:
** As stated in the keys above, the body work must be smooth and seamless, I cannot stress that enough! (Maybe someone who is handy with the body filler and finishing techniques will create that tread) *I still like to prep the body work for paint by using the DA sander and the 400grit followed by the 800grit turning it on a high speed. If you are painting on fiberglass, be careful around edges not to cut in too deep. You are looking for a smooth surface with no noticeable transitions from filler to metal or resin. Never work in your paint booth unless painting body color or clear coat, even the primer will create a dust in your booth!*
The following are prep methods that you will refer back to in many stages of the process, so from this point forward each method will be sited by its title.
“Wash Prep”:*
** Wash object with running water and soap. I like dish washing liquid. Make sure you use a rag. Rinse thoroughly with running water. Wipe dry with shamy or lint free cloth. *Allow some time after to air dry.
“Tack prep”:
** Move object to paint booth. Using a clean/dry lint free cloth, wipe down entire object with liberal amounts of denatured alcohol. Be sure you do not touch the object with anything (especially your fingers) after wiping down.
Prep:*
** When ready to begin painting you should start with a light coat to check your body work. This first coat will show you any imperfections before you waist too much time. Begin by “wash prepping” your object, then spray a light coat of the primer on the object. You should be holding the can 16 to 20 inches away from the object, waving it back and forth lightly while intermittently releasing and pressing the nozzle. *You want to slowly cover the item with a light even coat, barley getting the object covered in color. Allow this coat to dry for 15-20 minutes. Visually inspect the object for imperfections in the bodywork. If you see definite lines where two layers meet or pitting, your body work is not done and you are not ready for paint. *Once you are satisfied with you visual inspection coat move on to priming!
Priming:
** Start by “dust coating”. This means hold the can about 20 inches from object and rapidly depress and release the nozzle until you have covered the entire object in a dusty looking coat. This coat should have a texture to it, which is what allows you to build a heavy coat without getting running or sheeting. Never let this “dust coat” look wet; you are laying it to heavy if it appears wet. Allow the “dust coat” 5 minutes to set then begin “covering”. *“Covering” means to lay fairly heavy coats of paint using the longest stroke possible. (EXAMPLE: if you were painting a flat square you would start across the bottom and work to the top by moving in horizontal strokes. Aim the nozzle more toward the unpainted surface and away from the freshly painted surface. Depressing the nozzle before your come over the edge and releasing after passing over the opposite edge, painting in both directions.) You should hold the can 12 to 14inches from object and overlap each previous pass by about 2 inches. Don’t try to get it to cover everything, just move at one constant speed and keep it all even, you will be making many passes over the object so it will get covered. After you first “covering coat” you can start over with another “covering coat”. That should be done about for times before pausing. After the forth coat, stop and allow a 15 minute tack time. After the time has passed you can lay on another four coats of “covering”, wait 15 more minutes then repeat covering again! At this point you have 12 coats on your object, it needs to cure, primer dries fast but when you lay it heavy it will take a while for it to cure. Place the object in your booth or other safe place and allow it to cure for at least 48 hours. After curing you may find that your primer has a gritty texture or even some egg shell or orange peel finish, this is ok. In fact if you did it all right, it should! Time to do some sanding! With your DA sander on a low speed, wet sand the surface using 1200grit. DO NOT sand corners with sander, save them and do them by hand very lightly. (TIP: mix up some wet sanding solution by using one tea spoon of baby shampoo in a gallon of water) Once the primer coat is all smooth, time to lay some color! If you sanded through your primer coat, * do it all again, and sand lighter!
Color painting:
** It is crucial that you have a good grasp of the “covering” technique for laying color. Begin by doing the “wash prep” followed by the *”tack prep”. Once you are ready and feeling confident with your “covering” technique, begin your “dust coat” of the color. Allow that 10 minutes to tack then go with the “covering” method. Just as above do the “covering” method by doing four full passes, wait 15 minutes, repeat, and repeat again. This again should be twelve coats, give this 24 hours in the booth. After the set time, go straight into another “dust” coat followed by the same 12 coat “covering” process. Curing time, allow the object at least 48 hours to cure before continuing. After curing, DA wet sand the object lightly with the 1200 grit paper, again stay away from edges, they will have to be done by hand. Make sure you start with clean paper. Sand until orange peel finish is removed all the way down to smooth color, but not through to primer! Once sanded, complete a “wash prep” followed by“tack prep”. DO NOT “dust coat” this time, just lay two passes of “covering” coats and wait 15 minutes then lay two “covering” coats of clear paint. Allow this to cure for 48 hours. Now you’re ready to clear.
Clear Coating:
** Start by “tack prepping”. After you have prepped, lay four passes of “covering” coats with the clear, wait 15 minutes, repeat, then repeat again. After that you must cure for 48 hours. Wet sand using clean 1200 grit at low speed, “wash prep”, “tack prep”, repeat the entire “covering” coat steps again. Cure for 48 hours and repeat wet sanding, after wet sanding with 1200 grit move to 2000grit and smooth out more. You are almost there! “Wash prep” again then begin buffing.
Buffing:
** Using a high speed buffer and a fine buffing compound, buff clear coat on high speed applying light pressure over entire object. “Wash prep” and wax using a quality wax and hand applicator. Apply and remove wax by hand, two or three coats really gets a nice bling.
I hope you find this helpful, the above is for gloss paints only, see page two for the flat method.
Cheers! And happy “rattle canning”!
Ranch Hand grill guard or bumper?? Help pcasso87 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 20 02-14-2015 12:26 PM
Tints, Badges, Grill, and Minor Disaster jdz414 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 21 09-19-2011 02:14 AM
1 Chrome Grill Down, 2 Bumpers and the headlights Left to Go :-) MOPAR MULiSHA Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 30 03-26-2011 01:55 AM
Color match grill KarateManAZ 2009 Dodge Ram Forum 2 10-30-2009 07:57 PM
