Old 09-13-2011, 12:14 PM
TonyD87's Avatar
TonyD87 TonyD87 is offline
Vehicle: 2011 Ram 1500
Color: Gray
TonyD87 is on a distinguished road
Default Lowering a 2011 Ram Express
I am interested in lowering my 2011 Ram Express. Has anyone lowered a ram express or R/T? What is the best kit and how much work is involved?
Old 09-13-2011, 12:44 PM
chuckie chuckie is offline
Vehicle: 2011
Trim Level: r/t
Color: silver
Rep:102
chuckie will become famous soon enoughchuckie will become famous soon enough
Basic tools needed, floor jack / jackstands. etc. Definitely something you can do
in your garage. I went with the groundforce 2/3 kit , came with shocks too.
There are other kits out there that guys have used, Mcgaughy's has a 2/4 drop.
All depends on your budget and the stance you want
Old 09-13-2011, 01:40 PM
TonyD87's Avatar
Color: Gray
Is the kit a direct bolt on? I saw on another post that there was some holes that had to be drilled and some modification to make it fit right?
Old 09-13-2011, 02:11 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
If you check the suspension lowering section there are plenty of pictures and information for you. That way your not just getting opinions from us 2011 guys
2011 Big Horn 4x4 -SnowWhite-
Old 09-13-2011, 02:15 PM
Vehicle: 2011
Trim Level: r/t
Color: silver
Rep:102
Had to drill a couple holes to relocate the rear sway bar. The instructions are very good and have pictures of what to do. Other than that everything else is bolt on.
Old 09-13-2011, 09:12 PM
Actionjackson's Avatar
Actionjackson Actionjackson is offline
Vehicle: 2013
Trim Level: EXPRESS
Color: WHITE
Actionjackson is on a distinguished road
silver r/t looks geat....
Old 09-13-2011, 09:19 PM
Dutch Dodge Dutch Dodge is offline
Dutch Dodge is on a distinguished road
If you are going to lower it, then don't lower it with spindels. I bought my truck pre-owned and he had lowered the truck with a spindel drop and didn't adjust the springs, the ride was way too bumpy. so I took it off and put the original set under it.
Old 09-13-2011, 09:32 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
You do have some choices, Belltech, McGaughy's, and Ground Force to name a few.
Old 09-13-2011, 09:45 PM
TonyD87's Avatar
Color: Gray
I heard that the belltech 2 and 4 kit was the best, but I was reading on another post that if you lower it that much that the track bar and sway bar have to be modified? Does that sound right? If it's only drilling a couple of holes then that won be that bad. I am just not sure about drilling into a brand new truck.
Old 11-19-2011, 11:44 PM
JB1's Avatar
JB1 JB1 is offline
Vehicle: 2011 Dodge Ram Express
Rep:17
JB1 is on a distinguished road
you realize that makes no sense whatsoever
2011 Silver Dodge Ram Express 2wd
Houston, Texas
2011 Ram Express Upgrades TonyD87 2011 Dodge Ram Forum 32 10-15-2011 08:48 PM
2011 Ram Express wheel diameter question POWWAG Dodge Ram Wheels And Tires 6 10-14-2011 09:20 PM
2011 Express snrusnak 2011 Dodge Ram Forum 19 07-21-2011 12:37 AM
