Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 09-13-2011, 02:05 PM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
Default How do I choose a relay?
I want to install two relays in my truck. One for some KC lights and one for my CB radio. How do I chose the right relay for these devices?
Old 09-13-2011, 02:21 PM
highlandchef's Avatar
Trim Level: SLT Big Horn
Rep:220
Not overly difficult just choose relays rated to handle at least the amps you expect to draw for your lights of CB. Particularly for the lights you also want to make sure you have the right gauge wire. Remember you will need a heavier gauge wire based both on the number of amps being drawn as well as the length of the run.
Your amps for lights are figured by dividing the TOTAL light wattage by 12 and that will give you the amps (i.e. 100 watts/ 12volts = 8.33 amps)
Old 09-13-2011, 02:28 PM
Alright, easy enough. Second, I'd like to wire up the CB radio relay under the hood and tap into a key-on only power supply and want to know which device/circuit I should tap into?
Thanks for the formula. That will make it very easy.
Old 09-13-2011, 03:05 PM
Rep:220
For the relays, unless you plug a lot into the 12v outlet I would do that if yours is keyed-on. For the actual power to run the the lights and CB, wire them directly to the battery with an inline fuse. In my van I had several battery direct connections so I installed a terminal block right next to the battery and ran my connections there so you could do that as well.
Old 09-13-2011, 03:28 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
If your just running a plain cb without an amp or any power adders you will be fine just running the cb off of an accesory fuse (look into a thing called add a fuse) or you could use the cigerette lighter (I just put a plug on like this: http://www.google.com/products/catal...d=0CIUBEPMCMAA# which is nice cause it has a fuse in it)
Old 09-13-2011, 03:34 PM
Is the cigarette lighter only powered with the key on?
Old 09-13-2011, 04:04 PM
Rep:220
Sometimes yes; sometimes no. The new rams have one of each. If the power to your lighter isn't keyed try the radio power for the relays.
Old 09-13-2011, 05:02 PM
Color: Mineral Gray
Rep:177
The top one near the radio and the one in my consol always have power, the lower one near my transfer case shifter is only with the key, I relayed that one to my air horns so you have to have the key
Old 09-13-2011, 05:29 PM
Rep:220
That's just it; different vehicles have different circuits that work, even different years or models from the same manufacture vary. The nice thing is the relays themselves pull so little power you can easily place several of them on almost any line.
How To: Push Button Start Black05 Dodge Ram Knowledge Base 10 01-30-2014 06:46 PM
Hmmmmmm.....HID Relay Buzzing Ramathorne Custom Dodge Ram Interior and Exterior Lighting 29 03-19-2013 10:14 PM
My truck has trouble starting... no one can figure out problem Pork Chop 3.7L PowerTech V6 Specific Topics 15 05-14-2011 09:14 PM
How much would you charge? crob 5.7L V8 Specific Topics 4 04-27-2011 12:12 AM
!!how much would you charge?11 crob LD RAM - General Discussion 5 04-21-2011 10:44 PM
