Old 09-13-2011, 02:25 PM
tylerlovesjen tylerlovesjen is offline
Trim Level: 1500
tylerlovesjen is on a distinguished road
Default mufflex
Hey, just ordered the mufflex 14 inch setup, anything i need to know for installing this myself? Thanks a lot
Old 09-13-2011, 02:33 PM
WyGuy's Avatar
WyGuy WyGuy is offline
Vehicle: 2012 Dodge Ram
Trim Level: Outdoorsman
WyGuy is on a distinguished road
It's a pretty straightforward install. One thing you might want to do is add one or two more slits to help with compression when tightening the clamp. I'd also recommend an impact wrench, I couldn't get the bolts tight enough by hand.
Old 09-13-2011, 02:45 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
like stated above it is a pretty straight forward install i just recently installed a magnaflow catback but i had to cut my old exhaust in 3 places to get it out lol but hopefully you dont need to do any cutting and if impact tools are not a option for you just crank thoes bolts as tight as you can with a big ratchet like i did and there plenty tight enough
Old 09-13-2011, 02:51 PM
Crash's Avatar
Crash Crash is offline
Color: Deep water blue
Rep:401
And be sure to recheck them in a week or so. They will loosen up a bit and possibly start to leak. Some people have had them welded on for this reason
Old 09-13-2011, 07:32 PM
Trim Level: 1500
Thanks for the input guys, ill post a review on the install the day it gets here!
Old 09-13-2011, 09:46 PM
HVACeR HVACeR is offline
Color: Mango Tango
Rep:113
HVACeR will become famous soon enoughHVACeR will become famous soon enough
I don't know about anybody else that installed a Mufflex kit on their truck, but I got sick and tired of trying to work the OEM muffler loose, so I went at it with a sawzall (cutting close to the OEM muffler to ensure I didn't cut into the exhaust pipe I was leaving behind).
I also dropped my spare tire, it helped me to get my driver side exhaust tip out from under the truck. (My truck is lowered so it sits at about stock level while on jack stands)
MODS: BellTech 2/4, Air Lift 1000 Air Bags, Mufflex DOD14M, Partial Debadge, Pin stripe removal, B Pillar blackout removal.
Old 09-15-2011, 08:40 AM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
Get some penitrating lub spray and spray all your conections , bolt and hanger grometts the day before. The biggest thing with the install is to be super anal about tightening a little at a time and re-seating the connection each time (pushing the muffler foward into the pipe. Once its snug , hold forward pressure on the muffler with one hand as you tq the clamp . Then the tail pipes, a couple turns , adjust and re-seat then repeat. I did this at least 5 times making sure everything was even and fully seated. And once your done start the truck let it get warm then cool down and re-torque, drive it for a day then check the tq again and leaks. I,ve done this to two trucks and havent had any issues, but being anal is the key.
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 09-15-2011, 10:03 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I just installed the Mufflex DOD24M on mine last night. Make sure you un-clip the ground strap from the hanger rod on the muffler. I didn't notice it there and was having difficulty trying to remove the muffler. Once disconnected, the hanger slipped out without issue.
I also wrapped my tips in a towel so when I was removing the tail pipes they wouldn't scratch the bumper.
brad
Interested in one of my mods?
Old 09-21-2011, 09:14 PM
Trim Level: 1500
thanks guys, it just arrived today so here we go! ill take a bunch of pics and post em if i figure out how...and any pointers i can give to the next guy
Old 09-21-2011, 09:49 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
WD-40 the crap out of all the bolts and let them sit for about 10 minutes or so before loosening! Also on the hanger rubber mounts
A few questions. (Mufflex & other things) hugecanoli 2011 Dodge Ram Forum 12 09-15-2011 12:29 AM
Sneak Peak Mufflex Tips JEC Exhaust 16 01-28-2011 09:28 PM
Just installed a Mufflex ramc010 Exhaust 10 11-13-2010 09:33 AM
18" Mufflex Install brc3858 2010 Dodge Ram Forum 3 06-10-2010 03:53 AM
Mufflex Exhaust Woes smartel 2009 Dodge Ram Forum 12 10-26-2009 07:00 PM
