Old 09-13-2011, 06:07 PM
97 5.9 MAG's Avatar
97 5.9 MAG 97 5.9 MAG is offline
Vehicle: 1997 Ram 1500 2wd ext cab 5.9
97 5.9 MAG is on a distinguished road
Default pulling hard right on brakeing
Hey guys heres a little info any input would be awsome. I have just recently replaced most of the front end on my truck. Upper lower ball joints, inner outer tie rods , pitman arm and idler arm. After doing this I noticed my truck pulled to the right on braking... Then I had a shop install my 2.5 in level kit and shocks and align it ( because the sent me the wrong parts the first time when i had her apart! ) and still it was pulling to the right with braking the harder the brakeing the worse it gets.... So i checked the caliper that i recently replaced to find it was sticking again.. so i replaced that and then the rear wheel cylinder on the same side that was bad so after all this my truck is still pulling to the right on brakeing... Any ideas this one has me stumped!!
Old 09-13-2011, 06:18 PM
Rep:2657
sounds like a braking issue
you may be able to adjust the brakes on the opposite side to make them more even
sometimes the auto adjusters don't work well & you have to adjust them manually
Old 09-14-2011, 04:38 PM
97 5.9 MAG's Avatar
I adjusted the rear drums both sides when I changed the wheel cylinder.. I adjusted them till it had a little bit of drag. But it still pulls and the pedal doesent feel all that hard. Very frustrating lol
Old 09-14-2011, 06:04 PM
Rep:2657
some things to consider
is your 13 year old brake fluid a nice & clear color ? or is it time for a full line flush, either DIY or a shop
when you changed the wheel cylinder, did you maybe leave a bit of air in the system ?
personally i picked up a MityVac 8020 hand pump to do the bleeding/flushing
i had a friend keeping the master cylinder full, no need for anyone to pump the brake pedal
Old 09-15-2011, 10:21 PM
crip crip is offline
Vehicle: 2000 dodge ram 1500
Color: green
crip is on a distinguished road
could it be the prop valve not send right pressure? just idea?
Reduced Hard Drive Capacity on 730N bram11 Electrical 6 08-16-2011 06:47 PM
Having a hard time finding one BCEAGLES Dodge Ram General Discussion 4 03-03-2011 06:11 PM
Using ext hard drive to transfer music from Itune to truck cgayheartjr Newbie Checkin! 13 02-15-2011 05:06 PM
RAM-1500 Radio replacement gvangerven 2009 Dodge Ram Forum 5 01-26-2011 01:29 PM
2009 Factory Radio Guide RamTech Custom Dodge Ram Interior Modifications - Custom Audio / Video 0 12-21-2009 02:55 PM
