Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Place your Ad Here!
Old 09-13-2011, 06:27 PM
belle belle is offline
Vehicle: 2011 Dodge Ram Laramie
Trim Level: laramie
Color: rugged brown two tone
belle is on a distinguished road
Default MPG and Octane conclusion
After 10,000 miles of experimenting with different octanes, I have come to this, my personal, conclusion. My 2011 Laramie Crew Cab runs better, sounds better, and gets better mpg primarily using 87 octane and occasionally using a tank of 89. I use the 89 about every fourth fill just to be clean up any problems, if any, with the 87. My biggest concern is with ETHANOL !!!
Old 09-13-2011, 07:12 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
Thats funny, I only have 2300 or so miles, but Ive gotten best on 93, seems to stay in eco mode longer and pulls the little hills in eco as opposed to running a lower grade.
What mods do you have on your truck?
2011 Big Horn 4x4 -SnowWhite-
Old 09-13-2011, 07:34 PM
FireWire's Avatar
FireWire FireWire is offline
Rep:12
FireWire is on a distinguished road
There has been a lot of threads on this.
Some swear that 89 is better and some say no difference from 87.
I am a bit cheap and have only ran 87 since I got my truck.
Now gas prices have gone down and 89 is the price 87 was last week.
I guess I'll finally try a tank of 89 and decide for myself.
Old 09-13-2011, 08:21 PM
Rep:2890
I usually use the 89, but when prices climb, i may use some 87 between tanks of 89, so it may be more like 88 octane.
Now when i cross into Arizona, i only use 89, prices are 20 to 30 cents cheaper a gallon
The reason that they suggest using 89 octane is because of the Compression ratio
Displacement 5.7L (345ci) Compression Ratio 9.6:1
Bore 3.92 in. (99.5mm) Torque 375 @ 4400 RPM
Stroke 3.58 in. (90.9mm) Horsepower 345 @ 5600 RPM
Fuel Type Gasoline 87 Octane Net Weight 92.9 kg (205 lbs.)
Fuel Induction Sequential Multi‐port Fuel Valve gear OHV MDS 2v/cyl
The general rule is
87 octane up to a compression of 9 to 1
89 octane up to a compression of 10 to 1
91 octane up to a compression of 11 to 1
103 can be used up to 16 to 1
worthless stuff
there are many other variables & 2 different compression types, 1 is DYNAMIC, which i think is the one that engine manufactures use
Compression Ration =
Cylinder vol. + clearance vol. + piston Comp. vol. + gasket vol. + chamber vol. divided by Clearance vol. + piston vol. + gasket vol. + chamber vol.
Read more: http://www.carcraft.com/techarticles...#ixzz1XshuZNpp
Old 09-13-2011, 08:51 PM
Well, what I've noticed in tuning several HEMI's using a Predator or Trinity is that they are all different. One likes a higher octane with a middle of the road air/fuel ratio, another one likes mid-grade with a rich mix, some like higher octane with a rich mix, yadda yadda yadda.
I'm not surprised by this finding by belle. I did the same thing with mine and 92 octane works best for me.
Thanks for the info, belle! Every little bit helps.
Old 09-14-2011, 06:34 AM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
The general rule is
worthless stuff
Compression ratio on the 4th gens is 10.5:1
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 09-14-2011, 07:45 AM
Trim Level: laramie
I've never used 93, but I'll try it next tank. I heard that 93 octane doesn't contain ethanol. Is that true?
Old 09-14-2011, 10:32 AM
doug713's Avatar
doug713 doug713 is offline
Rep:33
doug713 is on a distinguished road
In the warmer months there really is little to no ethanol in the gas, I beleive they mainly use it in the gas during the colder months,, at least thats what I've found around here....
Old 09-14-2011, 10:37 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Ugh all this ethanol talk....they might as well just use 10% water instead, it'd save them money....
From what I've seen most have the best luck with 89 on their hemis.
Sean
Old 09-14-2011, 01:14 PM
garner's Avatar
Rep:46
It depends on the gas station. I've seen some where they have no ethanol listed by 93 but I've seen others where they have the little ethanol sticker by all octanes
MPG Booster/93oct Tunes thedvsmonkey Diablo Predator Questions & Info! 10 08-07-2011 09:48 PM
mpg Surprise dwadestrick 2011 Dodge Ram Forum 10 07-02-2011 11:27 PM
Rec 90 octane (recreational 90) MrPEZO 2011 Dodge Ram Forum 5 05-12-2011 01:05 PM
Tuner and Octane Questions for you Modaholics xopt1js Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 4 03-26-2011 11:51 AM
My MPG ShotGunWillie 2009 Dodge Ram Forum 12 08-14-2010 12:35 AM
