Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram MPG Zone
Dodge Ram MPG Zone Discuss your MPG woes and helpful hints here!
Old 09-14-2011, 08:54 PM
Dancianne's Avatar
Dancianne Dancianne is offline
Vehicle: 2011 Dodge Ram, Quad Cab
Trim Level: ST with combo packag
Rep:136
Dancianne will become famous soon enoughDancianne will become famous soon enough
Default Ethanol
I understand that the EPA, lobbyists and others in government are pushing for a 15% Ethanol content in gasoline to become the new standard instead of 10%, and some wanting an unspecified increase somewhere in-between 10-15%.
It's been argued that late model vehicles could use E-85 safely, but for most drivers on the road today, more than 10% will deteriorate fuel system seals and other components, and presumably result in a fire.
If enacted at some point in the near future, I am sure 10% would still have to be an option at gas stations. But, I sure hope legislation doesn't pass
Old 09-14-2011, 09:10 PM
tonyhawk196's Avatar
tonyhawk196 tonyhawk196 is offline
Vehicle: 2011 Dodge Ram Express
tonyhawk196 is on a distinguished road
A big factor also is the timing advance. The more timing the higher the octane that is required. I run 87 because Dodge says I can and I am cheap. If and when I start to play around with the engine with a tuner that advances the timing, then 89 and maybe 93 octane must be used.
Old 09-14-2011, 09:33 PM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
If you want to search for non-ethanol gas in your area, try this site:
http://www.buyrealgas.com/
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 09-15-2011, 02:04 AM
DenDen's Avatar
DenDen DenDen is offline
Vehicle: 2011 ram 1500 4x4
Color: Hunter Green
DenDen is on a distinguished road
Thats what knock sensors are for.when they sense knocking it retards the timing to a safe level.So if you put the higher grade gas in,the computer will let the timing advance up to the knocking point the back it off a bit.
2011 Dodge Ram.Hunter Green Crew Cab,Hemi.20 inch wheels.Bought August 28 2011.
Old 09-15-2011, 08:38 AM
jeman022004 jeman022004 is offline
Vehicle: 2011 RAM QC Sport 4WD
Color: Mineral Gray
jeman022004 is on a distinguished road
This confirms the advice my dealer gave me. The tech said the computer starts to learn the pattern of your driving including the octane fuel you are using. He said if you use 87 then stick with it, if you use 89 stick with it... If you ever do change the best thing to do is remove your negative battery terminal for a short period of time to reset the computer so that it will begin learning the driving pattern.
With that said, I am hesitant to trust him 100% on this...
Old 09-15-2011, 01:52 PM
MrPEZO's Avatar
MrPEZO MrPEZO is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x2
Trim Level: Crew Cab Outdoorsman
Rep:38
MrPEZO is on a distinguished road
Thatís a great site but please note most places are marinaís and they sell ďrecreational 90 or R90Ē Itís 90 octane ethanol free gas for boats, 2 & 4 cycle engines, chain saws, lawnmowers etc..
Itís not for highway use. I believe itís taxed different, plus its 100% gas and they donít want cars using 100% gas hence 10% ethanol.
I went to 3 places and they are marina and fuel depots. My local Sunoco has R90 but the sign on the pump says not for Highway use all though, I am still inclined to pump a few gallons one day or use a gas can.
2011 RAM Crew Cab Outdoorsman- Nav, Remote Start, 3.92 Gears, Alpine Stero, Mopar Bed Rug w/RAM Head, Mopar Black Side Steps, Tint, Weather Tech In Channel Vent Visors
2012 Durango RT
2006 Charger RT - Mopar Vent Visors, Daytona Blacked Out Grille, BT Catch Can, Air Hammer CAI-SOLD
Old 09-15-2011, 02:41 PM
Pretty much the way we learned to reset the adaptives on the LX cars. We unplugged the PCM fuse, let it sit for a while, then plugged it back in and drove it like we stole it. It does change the vehicles driving characteristics...for a while. Then, as you slip back into the old routine (highway driving, stop and go in traffic, around town at low speeds) the characteristics change as we are talking an adaptive system here.
One way to stop having to pull the battery cable or the PCM fuse (It was like getting a tune up every time you did it though ) was to install a programmer. Some adaptives are over written by the program and it doesn't end up feeling like your Grandfather's Model A.
Old 09-15-2011, 04:47 PM
Razorbass's Avatar
Woo Pig Sooie!
Rep:95
Never noticed that Pezo so thanks for pointing it out. I only looked at the station nearest my location and it is a normal gas station for cars, trucks, etc. Never bothered to check other locations.
Old 09-15-2011, 04:50 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^ yeah all I can find anywhere near me is marina's.
Sean
Old 09-15-2011, 04:57 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
Closest station to me is 1 hr 30 min away and most are over 2 hours away :/ Gotta love Texas
Gone but not forgotten:
First 2011 Ram R/T in Texas
MPG Booster/93oct Tunes thedvsmonkey Diablo Predator Questions & Info! 10 08-07-2011 10:48 PM
mpg Surprise dwadestrick 2011 Dodge Ram Forum 10 07-03-2011 12:27 AM
Rec 90 octane (recreational 90) MrPEZO 2011 Dodge Ram Forum 5 05-12-2011 02:05 PM
Tuner and Octane Questions for you Modaholics xopt1js Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 4 03-26-2011 12:51 PM
My MPG ShotGunWillie 2009 Dodge Ram Forum 12 08-14-2010 01:35 AM
