Old 09-13-2011, 10:25 PM
Netman66 Netman66 is offline
Trim Level: Laramie 4x4
Color: Inferno Red / Light Greystone Pearl
Rep:82
Netman66 will become famous soon enough
Default TPMS part number please!
I'm looking to buy a set of TPMS for some winter rims and tires.
I am finding two different possible numbers for my truck and I am wondering if someone here that has access to this info from Chrysler can confirm.
My VIN info is: AS119457
I have found:
56029398AB
and
56029359AA
Also, can anyone confirm that these sensors need to be added to the WIN? Does the WIN accept more than 4 sensor IDs if this is true? It would be a PITA to have to keep paying the Dealer to re-ID the sensors every time I switch sets.
Old 09-14-2011, 12:03 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Both of those sensor P/N's are for the 433Mhz system. There is one more sensor (p/n 56029319AC) that operates at 315Mhz. None of these sensors are interchangeable, so getting the right one is paramount. If you check with your Dodge dealer, they can look up your VIN and get you the correct P/N.
After you get the right sensors, there should be no problem programming them yourself.
Programming procedure -
Install new rims/tires.
Move truck at least 50' away from old tires, and shut off.
Let truck sit stationary for at least 20 minutes (30 minutes is best)
Drive truck at a speed greater than 25km/h for more than 10 minutes.
Programming done.
When you switch back to the other tires, repeat the above procedure.
brad
Interested in one of my mods?
Old 09-21-2011, 04:47 PM
cowpie636's Avatar
cowpie636 cowpie636 is offline
Vehicle: 2010 ram crew cab laramie
Trim Level: laramie
cowpie636 is on a distinguished road
The correct part # is 56029398AA. A few month ago i bought a set of 20 inch wheels and tires because i did not like the stock 20 inch wheels with the plastic chrome i wanted to keep the stock wheels and tires .i called dealer to price tpms sensor they wanted 56.00 each. I went on EBAY and got a set of 4 for 65.00 with shipping at sales@ oewheels.net .Tire shop mounted and balanced for 60.00 and programed the tpms system.
2010 laramie crew cab, white, mufflex 18,
Old 11-17-2014, 07:48 PM
chilly's Avatar
chilly chilly is offline
chilly is on a distinguished road
Are both of the 433mhz parts (AA & AB) interchangeable? Or, do you have to replace AA with AA and AB with AB?
2010, part numbers, tmps
2009 TSBs BlueJet 2009 Dodge Ram Forum 38 10-28-2014 05:03 PM
Rear Camera Tailgate Wiring Kit - Need part number CBR Dude 2011 Dodge Ram Forum 4 08-12-2011 09:02 AM
Help with Y Pipe part number pointcover Exhaust 6 07-29-2011 06:53 AM
I am Number 4 (And Spoiler) Chili1K Movies And Entertainment 1 02-23-2011 12:43 AM
FOBIK part number Al E. Gator Electrical 1 02-13-2011 03:05 PM
