United Radio
Old 09-14-2011, 03:31 AM
fcr112 fcr112 is offline
Vehicle: 2005 Ram 2500 Quad 4x4 Manual
Trim Level: 5spd SLT Stock 17"
fcr112 is on a distinguished road
Default Fair price for clutch replacement parts and labor?
What's an average fair price to expect for replacing a clutch on a 2005 5.7 hemi 2500 4x4?
Mines making crazy noises which started with a rhythmic clicking (almost like a loud lifter) that went away when the clutch pedal was depressed. And now it is a rediculous screeching randomly like a bearing about to blow, and it's getting harder to get into gear with the pedal depressed. No fluid leaking.
Old 09-14-2011, 10:00 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
[QUOTE]What's an average fair price to expect for replacing a clutch on a 2005 5.7 hemi 2500 4x4?
Mines making crazy noises which started with a rhythmic clicking (almost like a loud lifter) that went away when the clutch pedal was depressed. And now it is a rediculous screeching randomly like a bearing about to blow, and it's getting harder to get into gear with the pedal depressed. No fluid leaking./QUOTE]
Hopefully someone else can better help you with that particular model but just to give this thread a bump I'll tell you when I did the clutch on my s10 I spend about $600-$800 in parts, but that included clutch kit(pressure plate and clutch disc), flywheel, slave cylinder, master cylinder(had to get this from GM as the flexible line was damaged from previous owner), and fluid of course. If you are only needing to replace some parts, not the entire system like i had to, it may be cheaper, but then again the parts may be more being a full size truck, and heavy duty truck....hope this helps at all lol.
Sean
