Old 09-14-2011, 04:51 PM
DAYTONA81's Avatar
DAYTONA81 DAYTONA81 is offline
Vehicle: 2005 dodge ram
Trim Level: Daytona
Color: go man go
Rep:108
DAYTONA81 will become famous soon enoughDAYTONA81 will become famous soon enough
Default 4th gen guys with broken transmissions
Has anyone ever had a broken tranny on the 4th gen yet? If so did you have a tune and what did the dealership say? Did they figure out you had a tune?
2010 DODGE RAM CC 5.7L- MAGNAFLOW ONLY
2005 RAM DAYTONA- 426 HEMI
Old 09-14-2011, 06:12 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Autobred (a bunch of bolt-ons, cammed, CMR) and MGH (twin turbo) have both broke theirs. There's also that gen III with the Maggie too.
Old 09-14-2011, 06:32 PM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
Monitoring this thread.... I'd like toknow this as well. I assume a major broken powertrain component may prompt a dealer to check for a tune, but I am curious too...
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 09-14-2011, 06:35 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
I think RamTex toasted one recently,
mods:
Performance Mods:180stat,Trinity/HEMIFEVER Custom Tunes,Volant Intake,DODM24,ARH's No Cats,Raceland E-Cutout,BBK 90mm,MSD Coils,NGK Iridiums,Removed Stock Clutch Fan,BT Catch CanExterior Mods:Factory Bed Liner,Retrax,R/T Grille,Debadged,Blacked Out Exhaust Tips/Ram Heads/Stock 20's on Nitto 305 55 Trailgrapplers,Black KMC Slide 24's on 305 35 Delinte Desert Storms,6000k HI/LO/FOG,Smoked Recon Projector Headlights/Third Brake Light/Tail Lights,Interior Mods: BT Custom Hemi Shifter,Recon Interior LED Kit, Cobra XRS 979
Hemi09R/T
from DT is going onto his third transmission already
and his 2nd one was even "Built" up. (no warranty)
mods:
Airaid CAI, 2/4" Drop ,Diablo Programmer (93 Octane), Flowmaster 40 Series True Duals(side exit before the wheel), Nitto 420 Tires (305,50,20), Powder Coated Black OEM Wheels, Painted Black Headlights, Street Scene Roll Pan,Airaid TB Spacer, 4:10 Gears, 2800 Stall Circle D TC, Smoked Recon Tail Lights ,Debadged, Sonnax Line Pressure Booster, Jet 180 T-stat, 1 7/8"ARHeaders w/cats, Moes Ported Throttle Body,Raceland E-Cut out, Crazy Jay Eagle cam, CMR Tuned by Secret Service
Originally Posted by Hemi09R/T View Post
I have also killed two trans :/ and i wasnt so lucky i dynoed only like 340 or so i cant quite remember but i would never have thought i was making enough power to blow one of these trannys i know they arent very good but i figured it had 400 rwhp in it after my rebuild since i went from 4 stock clutchs in each gear to 8 alto red racing clutchs in each gear and i had a shift kit installed my 2800 stall and the sonnax all on my tranny and i blew it in 72 day... idk what to do this time around my trans mechanic says he think the CIDS (clutch volume index) need to go from the 50s to atleast the 60s to hold the tranny together but i have no idea on what else to do
My best guess is that if you Dyno over 330 WHP, your days are numbered if you "use and abuse it.
Old 09-14-2011, 07:00 PM
mgh's Avatar
mgh mgh is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
My dealer was willing to rebuild it for me the first time I toasted mine, but I did not what the same stock parts that could not hold the power put back in. I am working with Alto to put together a better friction pack for us. When I rebuilt my trans, they did not have a solution for the 2C frictions, so I used some Raybestos clutches, but they did not last. I now have all Alto Red Eagle single sided frictions, upgraded low/reverse sprag, TransGo shift kit, upgraded trans pump bypass valve, and a Sonnax line pressure booster.
Old 09-15-2011, 12:24 AM
azzo540 azzo540 is offline
Vehicle: 07 Hemi Ram QCSB 4x4
Trim Level: laramie
Rep:21
azzo540 is on a distinguished road
Send a message via Yahoo to azzo540
hey get off my maggie. jk
and i don't think the maggie was the reason it had less than 200 miles on with the s/cr after the got done.
but had 6k with superchip. 5k with k/n cai, 4k exhaust, 30000 into the shop for s/c 31000 after tuning and now at 32000 for my ats tranny.
07 1500 QCSB Laramie "Black Betty" Magnuson supercharged, "ATS Diesel" Tranny w/ TCI breakaway TC, Dynatech Super Maxx LT headers, FM Cat-back, K&N
custom doors courtesy of "Axle Break Hill"
Old 09-15-2011, 01:06 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
...you guys are running into he same 2nd prime issues the 3rd gens have? I read alot of 4th Gens using 2nd primes while shifting..
Old 09-15-2011, 01:09 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
I wonder how much the weight of what wheels/tires are being used is playing a factor in smokin these trannys?
2011 Big Horn 4x4 -SnowWhite-
Old 09-15-2011, 06:27 AM
mgh's Avatar
mgh mgh is offline
Rep:27
That has not been my problem. I think the real problem with the 45-545RFE is line pressure. If you look at the 68RFE guys, they are boosting their line pressure because they can tune their TCM like the LX guys. The more pressure we can get on these clutches, the more they will be able to hold.
Old 09-15-2011, 09:58 AM
chefred112's Avatar
Rep:656
so you think boosting line pressure would work for me too?.. I like collecting trannys as well...lol
broken power window motor/regulator? hallpass Electrical 3 04-09-2011 03:32 PM
Got broken into...crap. Customization time! Hosslt1 Custom Dodge Ram Interior Modifications - Custom Audio / Video 11 01-07-2011 11:46 PM
What do you guys think about these rims? thatreddodge Dodge Ram Wheels And Tires 14 12-16-2010 03:19 PM
what do you guys think? HEMI time? RamItAll Dodge Ram General Discussion 24 12-01-2010 02:49 PM
newbie her guys Quiet Lunatic Newbie Checkin! 11 02-08-2010 04:45 PM
