Old 09-16-2011, 10:50 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Stay away from the sonnax line pressure booster this was the other reason why my tranny went.
See comments like this make me nervous lol. I can't decide if I want to try it...
Sean
Old 09-16-2011, 11:24 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
You've got to take those comments with a grain of salt and compare apples to apples, I'd say running 370 WHP kills more transmissions than increasing the holding pressure of the clutch pack in the transmission.
I mean really the physical difference is holding the clutch pack with more pressure vs allowing it to slip and burn off the friction material.
Ask MGH, with 500 WHP Twin Turbo's on his 4G, The weakest link in the transmission is the overdrive frictions/steels
as soon as you hit 3rd gear or higher at WOT your going to start wearing those down. If you have 30+ HP over stock they will wear out much Faster/Sooner, that's a given.
Originally Posted by mgh View Post
That has not been my problem. I think the real problem with the 45-545RFE is line pressure. If you look at the 68RFE guys, they are boosting their line pressure because they can tune their TCM like the LX guys. The more pressure we can get on these clutches, the more they will be able to hold.
For those who dont fully understand how a modern trans and torque converter work... One of my posts from "another forum"
Originally Posted by Porter_ View Post
lots of good info here myoung84. i have a question though: when using ERS mode cant you technically take advantage of all 6 cogs by way of up-shifting one last time to exit ERS mode and enter 'D' which will eventually put you into "6th" gear? granted the last 2 cogs are overdrives, but still wouldn't it go something like this...
1=1st – 3.00:1
2=2nd – 1.67:1
3=2nd Prime – 1.50:1
4=3rd – 1.00:1
5=4th – 0.75:1
6=5th - 0.67:1 (by way of exiting ERS mode)
The 545RFE, and most newer auto transmissions dont have a large number of individual "Gogs" like a manual,
it uses a series of clutches and bands that act as brakes to control several rotating housings with just a few planetary gears that are always turning.
..and here's one of the best I've seen on Torque Converters...
...I was doing some research when ordering my Edge 2800 stall and had these bookmarked.
Old 09-16-2011, 11:33 AM
snrusnak's Avatar
Rep:1385
I would like more line pressure/firmer shifts/less slipping. I really don't care at all how "comfortable" it shifts. I'd rather it be firm. Just still slightly skeptical on any bad side effects of the line pressure booster...but agree more power obviously makes it harder on the transmission. I'll get it figured out...
Also, with the 4.7L I have a fair amount less power and torque than you hemi guys, but the same transmission, so I have alot less to worry about. My engine will never output more than 300rwhp, and that's if I do every mod that I have planned, and that's still probably out of reach. After all my mods I'll maybe be in the range of the stock 2nd gen hemi. I probably sit around 240rwhp currently. Getting another 60 rwhp from other bolt ons is not likely. If I did head work and cams, 300-350 rwhp is plausible, but I don't think I want to spend all that money on the truck.
Sean
Old 09-16-2011, 12:27 PM
mgh's Avatar
mgh mgh is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
Not trying to start anything with you, but what proof do you have that higher line pressure caused trans failure?
I have worked with a lot of different automatic transmissions and the only way to get them to handle more power is to boost line pressure one way or another. In the older transmissions, I would put stronger springs in the accumulator, or put check balls in some of the passages in the valve body to get more fluid to the clutches.
Old 09-16-2011, 03:10 PM
Rep:554
Yeah this forum and the buell forum I'm on take up all my computer time lol. I probably spend an hour every evening on here, and 15-30 minutes every evening on the buell forum lol! I can't believe you guys belong to multiple forums like this, I'd have no time left after checking the messages haha. Usually on friday morning my wife will say to me "can we go on a date tonight, and can you stay off the forum for 24 hours?" lol. Thanks for the info, I'm sure I will try it out at some point and see how it goes.
You've made over 2300 posts on RamForumz alone since Jan11? OMG!
My post count here is only a quarter of yours lol and I've been here over twice as long....since July 2010.
Even my total posts on DT are only 1534 but that started there 7 years ago in Feb.04' when I had a 3G Hemi QC.
just sayin LOL!
Old 09-16-2011, 03:18 PM
snrusnak's Avatar
Rep:1385
just sayin LOL!
Very true. I do post a lot....but I just try to answer people's questions, and comment on people's posts, and ask my own questions lol. Several posts an hour or so a night, and probably more on weekends, plus I pretty much always have the browser opened up with the forum, and check it throughout the day. I went on vacation for a weekend and came back to an inbox overloaded with forum messages haha, so I try to check it all day. I do my searching and time consuming stuff in those hours in the evenings.
Imagine if I posted this much on several forums, Yikes!
Sean
Old 09-16-2011, 06:39 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:597
Maybe your keyboard needs a Sonnax lol. Becareful of those space bar kick downs.
Old 09-17-2011, 12:40 PM
smeers59's Avatar
smeers59 smeers59 is offline
Vehicle: 2005 Ram Daytona
Color: Silver / Go Mango
Rep:103
smeers59 will become famous soon enoughsmeers59 will become famous soon enough
I have been running the Sonnax for about 2 months now. I am quite impressed how it helped with shifting, I did not expect that big of difference.
Daytona 00293, 3.92, 4X4, Custom Two-Tone Silver / GoManGo Paint, Custom Vortex Hidden Exhaust, Sonnax Trans Line Booster, AirRam Scoop, Stubby Antenna, Spectre Breather Filter, 22" SRT-10 GunMetal Rims, Fully DeBadged, Injen PowerFlow Intake w/ PowerBox, DSP Performance 93 Tune
Old 09-19-2011, 02:34 AM
johnnyh
I remember when I use to have my silverado, reading something about boosting the line pressure was a fast easy way to do it, but I ended up putting in corvette servos that actually had more surface area for the pressure to hold better on a specific shift(1st to 2nd if I recall) or something along those lines, which was a more direct approach than just upping line pressure. Food for though I suppose
Old 09-19-2011, 02:53 AM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
All this is great info, IMO it really needs it's own thread. I think the original poster was more interested in how the dealer treated your repair on a truck with a tune loaded (if and if not they knew). I hope I'm not out of line saying that...Daytona, can you confirm?
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
broken power window motor/regulator? hallpass Electrical 3 04-09-2011 04:32 PM
Got broken into...crap. Customization time! Hosslt1 Custom Dodge Ram Interior Modifications - Custom Audio / Video 11 01-08-2011 12:46 AM
What do you guys think about these rims? thatreddodge Dodge Ram Wheels And Tires 14 12-16-2010 04:19 PM
what do you guys think? HEMI time? RamItAll Dodge Ram General Discussion 24 12-01-2010 03:49 PM
newbie her guys Quiet Lunatic Newbie Checkin! 11 02-08-2010 05:45 PM
