Old 09-14-2011, 07:20 PM
Cutt Cutt is offline
Cutt is on a distinguished road
Default Debadging Issue
Hey all, so just like a lot of you have done, I decided to pull the badges and moldings off my 05 QC. I pulled the passenger side molding first and after some 3M adhesive remover and a quick polish and wax you cant even tell they were there. Then on to the driver's side. I pulled to molding off and had a dark shadow outline around the molding just like the other side. After a thorough working with the adhesive remover I had no success. Tried the polishing compound with my buffer and no luck! Since I didn't have any rubbing compound handy I went straight to the 2000 grit but still cant get the line off. The paint is smooth to the touch and I got the gloss back after sanding and polishing but the outline is still there. Do you think the truck could have been painted on that side at one time? The carfax was clear when I bought it but I know that doesn't mean anything. I will try to get some pics up soon bu does anyone have any ideas short of sanding and blending in some new paint? The color is the Mineral Grey Metallic (PDM I think for the code but I will have to verify).
Old 09-14-2011, 07:25 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
now idk if its what i think it is but usually on an older truck itll be harder to take off since its baked longer, but alot of guys will tell you that itll eventually go away, just takes time...wash it and just keep an eye out for it and hopefully it fades away...
-Pat-
Old 09-14-2011, 07:32 PM
I had one on my SRT car (it was almost brand new!!!) and I ended up getting the clear coat buffed out at the dealer's body shop. Looks all fine now!
Old 09-14-2011, 08:25 PM
Heres what I'm talking about. Passenger side was almost identical but buffed right out. This side...No Dice. (Sorry about the foot in the pic )
Old 09-14-2011, 10:33 PM
BlackHemI's Avatar
Rep:296
jeez that look like a big difference...almost does look like they cleared around the piece that was originally there
-Pat-
Old 09-14-2011, 11:02 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I have never seen anything like that. It might be worth while to have a local body shop look at it, and possibly give you some advice... or at least an explanation to what would cause that.
brad
Interested in one of my mods?
Old 09-14-2011, 11:33 PM
BlackHemI's Avatar
Rep:296
i agree Brad, that looks rediculous, never seen anything like it, kinda looks like the clear coat came off with the piece that was there
-Pat-
Old 09-14-2011, 11:39 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
That's weird.... have you tried clay barring it?
Dillon-aka, The Little Kid
Old 09-15-2011, 05:59 PM
Pulled out the clay bar and tried but got nowhere. I liberally sprayed the 3M into the molding before removing it and used a plastic applicator to separate the adhesive, leaving quite a bit on the door panel, just like the other side so I don't think I pulled The clear off. There is a distinct lip that follows the black line which is why I was thinking that there may have been a re-clear applied to part of the door.
Old 09-15-2011, 07:18 PM
BlackHemI's Avatar
Rep:296
ya maybe a re-clear was put on
-Pat-
C-clip/rear diff issue...info and questions starquestbd22 4.7L PowerTech V8 Specific Topics 8 08-28-2011 07:27 PM
Lazy/non-existent downshifts - anybody else with this issue? Turbovsix 2010 Dodge Ram Forum 18 05-20-2011 12:48 PM
RUST issue with 2010 4x4 Ram Big Horn...anyone else having this issue SupermanWV 2010 Dodge Ram Forum 18 01-29-2011 10:42 PM
Vibration Issue WickedSix 5.7L V8 Specific Topics 5 01-13-2011 12:30 AM
AAC Interior Light issue Quiet Lunatic Custom Dodge Ram Interior and Exterior Lighting 8 06-01-2010 09:58 PM
