Old 09-14-2011, 07:50 PM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
Default difference in front coil springs?
whats the difference between the coil out of a 05 4x4 vs. a 05 2wd?
and the difference between a 04 coil and a 05 coil?
im refering to the 1500s.
right now i have a 7 inch cst kit 4 inch spindle 3 inch coil, but i want to bring it down to the 4 inch spindle. And i was thinking a coil spacer on my stock coil to give me around 5 1\5 inches of total lift. Or i really want soft ride coils but they have them listed up to a 2004. Or will the stock coil be a softer spring rate then my cst coil?
or is there any other coil that is a softer rate and same height as my stock coil or maybe 1-2 inches taller?
thanks
Old 09-16-2011, 01:36 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Well I don't have an answer so, it's time to .................... this back to the top! Hope to see you around!
'92 Coil Spring rodeofan5656 Suspension 1 05-06-2011 07:55 AM
Front Driveline Question herc 2011 Dodge Ram Forum 7 04-19-2011 05:35 PM
04 dodge ram front differential noise timhorton Newbie Checkin! 10 09-24-2010 11:48 PM
2inch lowering front coil springs bones64 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 10 03-11-2010 10:48 AM
Engine weights/ Front springs bones64 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 0 03-11-2010 09:09 AM
