ZDOG
Old 09-14-2011, 08:25 PM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
Default Low tire pressure warning on EVIC
So I start up the truck this morning and the EVIC gives me a low tire pressure warning. In particular, the front driver' side tire is flashing on the EVIC. Oddly, it read I had 34 psi in each tire but was still flashing. So, I fire up the ol' air compressor and grab my tire gauge. Since I always like to check the tire pressure before adding more, I put the gauge on every tire. Every single one registered 35 psi on the gauge.
Obviously my truck thinks it is right and I side with with the gauge. I had some pics but for some reason the Manage Attachments function has not been working all day. Any ideas or suggestions? Maybe a computer glitch?
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 09-14-2011, 08:48 PM
glimmerman glimmerman is offline
Vehicle: 2011 dodge ram 1500 crew cab
Trim Level: big horn sport
Color: white gold
glimmerman is on a distinguished road
If your gauge is right then i would take it to the dealership, let them worry about it...may be a pressure sensor in the tire..2011 its still under warranty right?
Old 09-14-2011, 08:54 PM
Razorbass's Avatar
Woo Pig Sooie!
Rep:95
Still under warranty. Just the hassle of taking it to the dealer. Oh well, I think I have an oil change coming up anyway. Might as well get the sensor checked and see if there are any other updates available.
Old 09-14-2011, 09:12 PM
Color: white gold
Its a hassle but if ya got the warranty then use it, I paid for the 7 year 70000 bumper to bumper..as long as i am making payments on it then i want it under warranty..all kinds of little things can go wrong and they will charge you a arm and a leg to fix it..
Old 09-14-2011, 10:18 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
The sensor can go bad in the tire.. I rented a Traverse before I got my truck when my old car got hit and was in the shop when I picked it up from (well Ill be nice and leave the name out) the manager tried to get me to take the car saying that they just put air in the tire and everything will be fine.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
Old 09-14-2011, 10:27 PM
Was it cold there this morning?
The manage attachments function seems to be working fine. How many times have you used it and have you exceeded your attachment allotment?
Old 09-15-2011, 07:17 AM
Al E. Gator's Avatar
Al E. Gator Al E. Gator is offline
Vehicle: 2014 Ram 1500
Color: Deep Water Blue Pearl
Rep:30
Al E. Gator is on a distinguished road
I guess different trucks have different pressures. The door sticker for my 17" rims has the pressure at 40 PSI. My light comes on at about 36 PSI.
Old 09-15-2011, 07:26 AM
jeman022004 jeman022004 is offline
Vehicle: 2011 RAM QC Sport 4WD
Color: Mineral Gray
jeman022004 is on a distinguished road
I got a pretty good size leak after running over some kind of metal chunk at the dump last week. I think the lowest it got was 24 psi on my way to the tire shop. After getting it repaired at the tire shop, it probably took a good 5 minutes of driving to clear the low tire pressure warning even though all (4) tires were reading in the normal range.
Old 09-15-2011, 09:10 AM
Razorbass's Avatar
Woo Pig Sooie!
Rep:95
It was colder than normal but not extreme. I checked all of them again last night after the real cold front moved through and the gauge still read 35 psi on all four tires. I am guessing it is the sensor and will take it to the shop.
I tried the attachments function multiple times from both by work computer and home computer. I have not exceeded my limit by a long shot (yet). The window would pop up and I could select files but once I hit the upload button, the popup window would turn completely white and nothing would ever be uploaded. No error messages or anything, just a blank window. Must have tried half a dozen times.
Old 09-15-2011, 09:32 AM
nicslaw's Avatar
nicslaw nicslaw is offline
Vehicle: 2011 Dodge Ram Outdoorsman
Trim Level: Outdoorsman
Color: Forest Green
Rep:15
nicslaw is on a distinguished road
I took mine into the dealer to even out the pressure once... They told me that the EVIC showed approximately 3 pounds less than the gauge and to run the gauge pressure but to keep an eye on differences only with the EVIC..... I'm guessing there are some anomalies in the comps.....
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 165 02-18-2016 08:35 PM
Tire Pressure Warning light simpsons Dodge Ram Wheels And Tires 2 04-21-2011 04:07 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
warning for trucks with tire pressure monitoring Bighorn5.7 2009 Dodge Ram Forum 7 02-11-2011 01:30 PM
Incorrect door sticker tire pressure recommendation steve57 2010 Dodge Ram Forum 48 09-29-2010 10:38 PM
