Fog Lights Not Working - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 09-16-2011, 08:56 PM
camoman214 camoman214 is offline
Vehicle: None right now
camoman214 is on a distinguished road
Is it possible to get the reading from #1 (85) with the relay in-place.
I'm willing to bet it changes from 0v to 12v (switch on or off), and if it does, the problem is the ground trigger to the relay from the light switch, which could be either the ground to the switch, the switch itself, or the connection from the switch to the relay.
This circuit of the light switch is on a 2 wire connector with -
Black/Orange wire - this ties to ground (Should always test 0v)
Brown/Yellow wire - this connects to relay pin 1 (85), and switches to ground when the fog lights are turned on. (Should test as 12v with fogs off, and 0v with fogs on)
I guess the prudent check is to see if this connector is even plugged into the light switch.
Sure enough, with the relay in place the voltage read 12v on pin #1/85. I removed the relay and voltage was at 0.
Is there a way I can "jump" the relay to make it think it's being controlled by the switch? Like take a wire and run it across two points on the relay or something to that nature? I remember having issues with a past car of mine where the cooling fans wouldn't engage and I read about tricking the relay. It worked, but the fans would run anytime the key was on. I just don't remember that procedure for sure.
Old 09-16-2011, 10:10 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Now we're getting somewhere.
From what I can determine so far, the relay and all circuitry past it is likely fine, so we have narrowed the issue down to the control switch and associated wiring.
On the light switch, there should be 2 connectors. One has a bunch of wires....the one of interest has only 2 wires.
Check the voltage on the Brown/yellow wire at the switch. It should be 12v with the fogs off, and 0v with the fogs on.
Then check the Black/Orange wire. It should be 0v at all times.
brad
Interested in one of my mods?
Old 09-18-2011, 12:23 PM
brad12kx's Avatar
Rep:2581
How are you making out with this?
brad
Old 09-18-2011, 12:43 PM
I was actually stuck at work yesterday, but I plan to tear the bezel off and pull that switch out to test it. I'll post my readings as soon as I have them.
Thanks for checking in. Thanks to your help, I'm determined to figure this out.
Old 09-18-2011, 12:47 PM
brad12kx's Avatar
Rep:2581
I share your determination. I figure we're very close to having working fogs on your truck.
brad
Old 09-18-2011, 02:41 PM
Update: Pulled the switch out and tested the voltages at those two wires. The brown/yellow wire had 12v with the switch OFF and also had 12v with the switch ON.
The black/orange wire was at 0v with switch ON or OFF.
Thank ya.
Old 09-18-2011, 02:52 PM
brad12kx's Avatar
Rep:2581
Theoretically, if you jumper from the Black/Orange to the Brown/Yellow, the fogs will light and confirm that the switch is defective.
brad
Old 09-18-2011, 03:00 PM
You are absolutely correct. Jumped the two wires and for the first time I heard the relay click on. Jumped out of the truck and was happy to see that both fog lights were burning bright.
Good work brad12kx. I really appreciate the help ya gave me.
Old 09-18-2011, 03:08 PM
brad12kx's Avatar
Rep:2581
Next step....new switch!
At least you know that the 'system' and wiring are OK. A switch is a lot easier to replace then tracking down and fixing a broken wire somewhere in a harness.
brad
Old 09-18-2011, 10:49 PM
Very true, thanks for walking me through it. I'm not out of the dark yet though. I still need to figure out my taillight/turn signal/reverse light issue. Apparently it's a ground problem somewhere. Wiring hates me.
Brake lights not working gkconcepts Newbie Checkin! 11 07-22-2012 02:26 PM
Fog lights not working on 2001 Dodge ram stmabe Electrical 8 09-17-2011 01:15 AM
tail lights not working dasr12006 Electrical 5 06-15-2011 04:16 PM
Reverse Lights Not Working dschluet 5.2L V8 Specific Topics 4 02-27-2011 02:07 PM
Fog Lights not working?? Aries 2010 Dodge Ram Forum 7 11-20-2010 03:20 PM
