Old 09-15-2011, 01:24 AM
andytcox andytcox is offline
Vehicle: 99 Dodge Ram
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
andytcox is on a distinguished road
Default 99 ram ignition problem
Hi I'm new to this page but a long time dodge fan I recently purchased a 99 ram shorted 2wd with a 318 in it an it was running great and then the other day I drove it down the street and when I shut it off it wouldnt start again I checked every fuse and relay but nothing it has power at the key when I turn it back to accessory but when I turn it forward to on or try to start it it loses everything. Before I buy an ignition switch has anyone els had this prob and if so was it the ignition switch? Any help would be great thanks!
Old 09-15-2011, 06:58 AM
Rep:4072
I moved your post here where you're more likely to get some help but good luck and welcome to the forum! When you get a chance, be sure to stop by the Newbie Checkin and introduce yourself to everyone!
PROBLEM: says 'Key In Ignition' but it's clearly not XaeLee Electrical 4 08-27-2011 01:06 AM
Ignition problem andrewdains Electrical 2 05-22-2010 03:35 PM
Key Ignition Problem andrewdains Electrical 3 03-17-2010 10:38 AM
Changed ignition switch now alarm system problem ineedabin2 Dodge Ram General Discussion 1 07-08-2009 07:58 PM
