Old 09-15-2011, 02:52 PM
dvdsram dvdsram is offline
Vehicle: 2011 dodge ram Laramie
Trim Level: Laramie QC
Color: blue
dvdsram is on a distinguished road
Default voice and phone button not working on u-connect
got new phone and while trying to set up the HTC Desire phone on the uconnect the voise button and the phone button quit working and I cannot get anything out of them any ideas I had the new phone connected but it would say no phone available about 1/2 the time so I thought I would reinstall and this happened. would rather not take to dealer as it is along drive
thanks
David
Old 09-15-2011, 06:59 PM
Ogreboy Ogreboy is offline
Vehicle: 2011 Dodge Ram Sport
Ogreboy is on a distinguished road
Same thing is happening with mine. Try to change the radio station and it says U-connect phone not available. Called the dealership today and they told me to make an appointment to get it fixed next week. Let me know if you find any way to fix it yourself.
Old 09-15-2011, 07:01 PM
Color: blue
it is going in in the morning so I will send update I tried pulling the poi fuse but that didn't do anything
thanks
Old 09-15-2011, 11:31 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
Try disconnecting the vehicle battery for a few minutes and the reconnect it, this might reset the module. Can you drop the glove box and look inside to the right and you should see the Uconnect module. Can you get a picture of it? Have you performed the Uconnect update?
thanks
David
Old 09-16-2011, 12:57 PM
Color: blue
I did perform the update and it did not help--took to dealer today and they are having to replace the voice system and something about the interface with the bluetooth, if that makes any sense? so I am out of town for 2 weeks and will have to leave it with them overnight when I get back. They want to install another radio to see if it works then and then replace entire system if it does not. Curious as to if the update or the new phone may have anything to do with any of this? Didn't get an anwer on that at least not yet
Old 09-19-2011, 05:44 PM
Rep:73
The update for Uconnect or the Desire either one would not cause this issue. It also sounds like the dealer doesn't know what the problem is either and just wants to throw parts in until the problem is solved. Can you take a picture of the module and post it for me? Drop down the glove box and look inside to the right and you will see a module like the one that I have attached below. Have you had any other phone paired to the Uconnect system?
U connect and radio problem jj ram 2010 Dodge Ram Forum 6 10-29-2010 04:04 PM
