Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Dodge Ram Decals
Old 03-19-2012, 05:02 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
^Hey man were have you been!? lol
Yeah I think I have like 10k or 15k on mine and no issues.
Sean
Old 03-19-2012, 08:24 PM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
Eh I'm here. Just another oil pressure low CEL on my truck. Idk but evrrytime that. Comes on its my fuel cap... annoying!
-Pat-
Old 08-07-2012, 11:41 PM
stanb757 stanb757 is offline
Vehicle: 2004 ram 1500
stanb757 is on a distinguished road
Just performed this service exactly as you described, and everything went great. Bought the parts you mentioned from advance, 8 qts of atf-4, and went to work. I had no problems at all. Drove the truck up on the ramps, removed the pan bolts, and let the fluid leak out, slowly and gently prying at the pan to increase fluid flow as needed. This way when i dropped the pan barely any rushed out. It was sealed with RTV, but i used the gasket from Advance. Only thing I did differently was I spread a thin layer of RTV on the pan flange with a 1 1/2" plastic scraper and placed the gasket in place on the pan and let it bond for about 20-30 minutes. Then installed the pan, carefully installing each bolt with a 1/4" drive extension and a 8mm socket. Then I tightened the bolts in a crossing pattern, and I was done. It's pretty much common sense to not torque the crap out of the bolts. You shouldn't break any if you install them carefully. I also did not replace the small round seal as you suggested. It took 7 qts altogether when I refilled it. Thanks for the write-up.
Old 09-20-2012, 02:54 PM
99gp's Avatar
99gp 99gp is offline
Vehicle: 2004 Dodge Ram 1500
Rep:155
I am thinking about changing my fluid and filters soon, and I was wondering if you think it is worth it to get the mopar filters. They are not cheap though, $18.10 for the spin on filter, and $31.10 for the other one. Seems steep if the advance auto one's work.
Old 09-20-2012, 03:18 PM
snrusnak's Avatar
Rep:1388
Personally I would at least get the mopar spin on filter. When I did the service I used the parts from advanced discount(~$75 total for filters, gasket, and fluid IIRC) and I have had no problems(am now near 70,000 miles). But after talking to transengineer about possible issues with the aftermarket spin on filters(drain back problems with the converter), I'll definitely use the mopar spin on filter in the future.
Sean
Old 09-20-2012, 03:32 PM
99gp's Avatar
Rep:155
Thanks. I will do that. You think that the advance auto non-spin filter and gasket is fine to use though?
Old 09-20-2012, 03:43 PM
snrusnak's Avatar
Rep:1388
Yeah the other filter is just a screen.
Sean
Old 09-20-2012, 03:51 PM
99gp's Avatar
Rep:155
sweet. Thanks for the help man
Old 09-22-2012, 02:07 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
I have used A filter kit from autozone for my transmission on my 09, and it worked like a charm. Only cost me $19 for both filters.
I am wondering how easy it is to do the trans service on the hemi, being that the exhaust hangs over the pan. What a PITA.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 10-06-2012, 02:42 AM
LunchboxL1's Avatar
LunchboxL1 LunchboxL1 is offline
Vehicle: 2013 Dodge Ram 1500 Laramie
Color: Deep Cherry Red
Rep:14
LunchboxL1 is on a distinguished road
I just wanted to say great right up. Very informative. Doing my service this weekedn so this is a big help.....now the only question for you is have you changed your spark plugs and have a great right up on how to do those cause I am dreading to do them.....I have held off doing them when I should of. Now I got 60,000 on my ride and think its time.
Dealerships: A User’s Guide RootBeer Dodge Ram Knowledge Base 3 05-04-2012 05:03 PM
545RFE trans service help/advice/tips!? snrusnak 4.7L (287 cu in) PowerTech V8 Specific Topics 38 09-11-2011 02:00 PM
545rfe Transmission slipping on 3rd shift snrusnak Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 3 08-13-2011 05:17 PM
Just ordered Arrington Big Valve Heads RamTex Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 19 07-08-2011 02:38 PM
Automatic Transmission Service Life Expectancy? IN2H2O LD RAM - General Discussion 7 05-12-2011 07:49 AM
