4x4 newb question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Old 11-02-2011, 03:26 PM
Natedog37 Natedog37 is offline
Vehicle: 2012 Ram Sport 4x4
Color: Dark Gray
Rep:33
Natedog37 is on a distinguished road
Default 4x4 newb question
Ok I have a 2012 ram 1500 sport 4x4
I have anti spin rear end
With the 4x4 system I have
2wd, 4wd auto, 4wd lock, 4wd low.
So I know how to use the 2wd.
Auto I think I am engage any time under 55 MPH
What speeds should I bee at for 4wd lock, and 4wd low, and does the truck need to be in neutral?
Also when it says 4wd lock is it saying the front and rear have lockers?
Sorry just trying to understand the Manuel better and make sure I don't screw the truck up when I need to use 4x4.
2012 Ram C.C. 4x4 Hemi, 1989 Conquest TSI Stock heheh, 1988 Conquest TSI 440 BB
Old 11-02-2011, 03:56 PM
Those are good questions! I can't answer them, though.
I have a 2007 with a 2wd, 4 hi & 4 lo setting. I can shift into 4 hi at any speed under 50 mph. I have to be stopped to shift into 4 lo.
Old 11-02-2011, 05:18 PM
socket462 socket462 is offline
Vehicle: 2007 Dodge Ram Hemi 4x4 Quad
Color: Mineral Gray
socket462 is on a distinguished road
I can't answer this either, but I can refer you to the EXPERT on this subject-- your OWNERS MANUAL that is supplied with all new vehicles. If you don't have one, ask for one from Dodge you can sometimes download one for free. http://www.dodge.com/en/owners/manuals/index.html
4wd lock means (unless you have a Power Wagon) that the 4wd front and rear power is locked -- and you don't want to run in that mode on dry pavement. Another thing that the wonderful owners manual will provide into on. The only truck that has front and rear lsd differentials is the POWER WAGON.. and that will have a knob on the dash to lock each or both differentials. All power wagons have manual transfer case shifters as well... on the floor.
'07 1500 SLT - 4x4 QC Hemi Big Horn package- Billstein 5100's, Cooper At3's (NEW!), K&N drop-in
Old 11-02-2011, 05:37 PM
Color: Dark Gray
Rep:33
read the Manual and got lost so that is why I asked. So I should at least have rear lock with the rear anti spin axle.
I know not to drive in 4wd unless I need to just wanted to know the speeds to shit into it.
Old 11-02-2011, 06:11 PM
black beast black beast is offline
Vehicle: 2000 dodge ram 1500
black beast is on a distinguished road
ok so i would recommend always having the truck in neutral and completely stopped to use 4wd lock and 4wd low. also you should never run 4wd lock or 4wd low on dry pavement. it will tear everything up and will cost you quite a bit.
Old 11-02-2011, 07:25 PM
Butter's Avatar
Butter Butter is offline
Vehicle: Ford owner as of 4-25-15
Trim Level: XLT
Color: Flame Blue Metallic
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
When it say 4 lock it is referring to the transfer case, not the diffs. In 4 auto it will only engage 4wd when the rear tires loose traction. In 4 lock the transfer case is locked into 4wd full time. You can shift into 4 auto or 4 Hi under 50mph but I really see no need to. To shift into 4 lo you should be stopped and in neutral, if it will not lock (light keeps flashing) put it into drive and creep at 2 mph or less and it should lock in
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 11-02-2011, 07:37 PM
SeattlePete's Avatar
SeattlePete SeattlePete is offline
Vehicle: 2011 SLT CC 4x4
Color: Mineral Gray Metallic
Rep:24
SeattlePete is on a distinguished road
Exactly correct.
Old 11-02-2011, 09:18 PM
Color: Dark Gray
Rep:33
Thank you that is what i needed.
Old 11-04-2011, 12:00 AM
dsdellRam06's Avatar
dsdellRam06 dsdellRam06 is offline
Vehicle: 2006 Ram SLT Quad Cab 4x4
dsdellRam06 is on a distinguished road
another way that makes it easy to get into 4 low is to creep it forward then while rolling, shift to neutral. should lock in no problem
Old 11-04-2011, 12:11 PM
Rkeytek's Avatar
Rkeytek Rkeytek is offline
Vehicle: 2011 ram 1500
Rep:210
Rkeytek has a spectacular aura aboutRkeytek has a spectacular aura aboutRkeytek has a spectacular aura about
I thought there was a new "memo" or something out that said even 4 high should be done at a stop or crawl because they were having problems with the servo that switches the transfer case.
On my dad's Avalanche they did the same thing...they originally told him he could switch to 4 high at any speed under 40 mph, when he had to have the transfer case servo changed they said that Chevy now says not to switch at speed, but to stop.
I don't know how many people have used manual transfer cases, but I know on my old bronco I would not want to switch to 4 wheel anything while moving more than 5 mph. Those gears have to align so by creeping forward you slowly turn one while pressure is applied to the other until they mesh. Its much harder and more taxing on the gears and servo to do this at 50 mph.
Newb checking in with a question... weahpaman Newbie Checkin! 8 09-08-2011 07:22 PM
Newb with a question brewdog Newbie Checkin! 11 05-10-2011 06:10 PM
Newb Question about Tire Sizes geddy Dodge Ram 4x4 - Offroad Discussion 5 03-16-2011 07:25 PM
Newb question; goofy wiring? WesB Towing 1 11-29-2010 09:50 AM
Newb question Duff Newbie Checkin! 8 01-05-2010 10:00 AM
