Old 09-16-2011, 10:34 PM
actoney actoney is offline
Vehicle: 1995 dodge ram 3500
Trim Level: 3500
Color: silver and blue
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
actoney is on a distinguished road
Default 1995 RAM 3500... Biggest size tire i can go with???
I have a 1995 Ram 3500 and i am about to buy some new wheels i just put up and thread about a leveling kit and now along with the leveling kit i want to know what size tires i will be able to fit on my dually? if i do a 3" leveling kit will i be able to do 33" tires or even 35"????
PLEEEEASE SOMEBODY HELP ME OUT!!!
Old 09-17-2011, 01:00 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
If you actually haul with your truck you can't go any wider then 265mm or your back tires will rubagainst each otter when loaded. My buddy has 285s on the back of his dually but he has a 1.5 spacers. Tire with is a problem in the front as well, over 285mms on a stock offset will rub on the control arms
As for the leveling kit check out fatbobsgarage.com, they usually have a bunch of different leveling kit for 2wd trucks. Measure from the center of your axle to the lip of the fender.
Old 10-16-2011, 11:03 PM
Trim Level: 3500
will a 255 70 22.5 tire fit on my truck with my 3 inch leveling kit??
Old 10-17-2011, 12:46 AM
Color: Mineral Gray
Rep:177
I think you may be able to clear them but it's going to be really close in the front
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 157 09-21-2014 08:47 PM
Biggest tire size without rubbing? AZHunter86 Dodge Ram Wheels And Tires 14 07-29-2013 06:07 PM
Max tire size for a 3500 4x4 Mega Cab with a 2" leveling kit? Dukecdn Dodge Ram Wheels And Tires 2 05-25-2011 10:58 PM
biggest tire size? anyone knows? slamtime155 2011 Dodge Ram Forum 6 04-25-2011 12:04 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
