Old 09-17-2011, 01:27 AM
Nufy Nufy is offline
Vehicle: 2011 Ram 1500 QC Sport
Nufy is on a distinguished road
Default Under Hood Lamp install
So I purchased a under hood lamp for my 2011 Ram Sport that didn't have one from the factory.
When I went to install it I noticed there was no wiring in the place where the light attaches.
I assume its part of the wiring harness but need to know where to start looking before I start pulling parts off my truck.
Thanks.
Old 09-17-2011, 01:31 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Don't know but if you figure it out post it because I'd be interested in doing this. Thanks.
Sean
Old 09-17-2011, 01:37 AM
Drake371's Avatar
Drake371 Drake371 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:83
Drake371 will become famous soon enough
I been wanting to do this on my truck for awhile as well
Superchips Cortex, K&N CAI 63-1529, Sprayed in Bedliner, ARE cover, Flowmaster exhaust kit ... more to come
Old 09-17-2011, 03:47 AM
djnwc djnwc is offline
Vehicle: 2011 ram sport QC 1500 black
Trim Level: luxury sport
Color: sparkly black
djnwc is on a distinguished road
you have to buy the wiring harness for the light as well I have been told as mine didn't come with one either....so back to the dealer you must go....
Old 09-17-2011, 07:41 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Mine has the light however I can't believe that something as simple as an underhood light would be on some but not others.
Old 09-17-2011, 08:04 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I'm just thinking out loud here.....
I'm thinking that there has to be an easier way than tapping in to the wiring harness (which sounds expensive if you buy the one from MOPAR).
If you go to an electronics supply store (Radio Shack or something similar) you should be able to find a motion switch in the proper voltage/ amperage. These used to be called mercury switches, though I'm not sure what they're called now.... in a nut shell when the switch senses that you've raised the hood, it'll turn on the light, but when it senses that the hood is closed then the light will say off.
Tie all of this in to your battery along with the proper fuse, and perhaps a relay and you have what you're looking for, at a fraction of the price.
I will do some research on finding they type of switch I'm talking about
Exco
Bill
Old 09-17-2011, 08:17 AM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Mopar makes one for about 20 bucks (I think) but you have to get the harness that will plug into the light and I'm not sure about that price. I think the other end has a ground and hot to connect your battery. I believe that one works something like a mercury switch. Quadratec makes one for the jeep but it's 60 bucks and that one works like the old door spring switches. You have to mount the switch in a place where it will come on and go out when depressed (shutting the hood). There are also flexible (self adhering)and non flexible led strips if you like the bling thing. I don't know much about them other than seeing them when I searched for a hood light for my truck. I decided to wait and see one in person and gave up on it.
Old 09-17-2011, 08:20 AM
RadioFlyer's Avatar
Rep:146
Well then I would think the dealer would have one if it is available on some trucks, right?
Old 09-17-2011, 08:36 AM
Excoastie's Avatar
Rep:1358
The best I could come up with, using my sleep deprived brain was this one from Amazon. It's a lot cheaper than $60, but it doesn't give any specs, other than to say it's for several automotive applications
Exco
Bill
Old 09-17-2011, 10:09 AM
RadioFlyer's Avatar
Rep:146
I just called my dealer and they still can't find a part number for the wiring harness without the vin # from a truck like yours that has one. So in order for Nufy to get this from the dealer, you would have to give him your vin number unless there's another way.
Underhood lamp with sport hood? abpelch Body & Interior 99 12-17-2014 09:35 AM
Hood Supports For My SRT-10 Hood BigHornRam2006 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 1 05-18-2011 05:53 PM
SRT-10 Hood Issue.... BigHornRam2006 Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 12 03-12-2011 01:01 PM
Ram Air Hood and Products Dano61 Dodge Ram General Discussion 10 11-15-2009 03:12 AM
SRT10 hood & AMP ram air intake... CHILLZ HEMI Dodge Ram General Discussion 12 10-12-2009 02:06 AM
