4TH Gen: Stock Alpine Dash and Headliner Speaker Specs - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-17-2011, 08:51 AM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
Default 4TH Gen: Stock Alpine Dash and Headliner Speaker Specs
Here are the detailed measurements of the stock Alpine dash, center and headliner speakers:
Dash: 3.5" speakers with a 2.5 ohm rating (1 3/4" depth)
Center: 3.5" speaker with a 2.5 ohm rating (1 3/4" depth)
Headliner: 2.5" speakers with a 2.5 ohm rating (1 1/4" depth)
The center channel uses a mix of the right and left dash signals.
The headliner speakers use the right and left rear audio signals.
For removal, the dash speakers are each held in by two bolts which require a 7mm socket. The headliner speakers are removed with a torx screw sized at 20.
For ease of replacement, use Crutchfield harness #12071039 on all of these speakers.
http://www.crutchfield.com/p_1207103...s.html?tp=3097
*Note- Door speakers require a different Crutchfield harness #12071050
http://www.crutchfield.com/p_1207105...s.html?tp=3097
2012 R/T 392
Old 09-18-2011, 08:22 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, Nice Sticky
Old 09-18-2011, 10:49 PM
Frank Drebin Frank Drebin is offline
Vehicle: 2011 RAM CC SPORT
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:34
Frank Drebin is on a distinguished road
Some more good info on speaker sizes from another poster. All 4 door speakers are 6X9 with a top mount depth of 2.75`.
I just copied his post from his thread. (Great info here)
Originally Posted by GoatFarmer View Post
There we go!
That Looks a little better eh?
Attachment 21734
Attachment 21735
Attachment 21736
I took some measurements for mounting depth too. It looks like you have 2.5" to plastic that holds the window track, and 3.5" to the window track itself, but be careful that plastic gets in the way of most large magnets.
Attachment 21739
I'll start with the HU.
I have the center console, so the first thing that needs to be removed is the chrome trim ring around the shifter. This thing is a b**ch to get out, so be patient and have a good set of plastic pry tools.
Attachment 21740
Attachment 21741
Next the screws come out. There are 5 total. Two in the front cubby, under the rubber liner.
Attachment 21742
Two under the rubber at the top of the center under the rubber liner that says Dodge.
Attachment 21743
And one behind the power outlet cover.
Attachment 21744
Next you’re ready to start taking the center off. At this point everything is held on with Push clips so it just pulls off. Start with the center console cover.
Attachment 21745
And then the cover comes off of the front. Start at the top, and work your way down as the clips pull out. There are various wire connections on the back for your HVAC, tow/haul, inverter, and other things. I was able to move the cover far enough to work with only a few wires unplugged.
I didn’t get a shot of the front cover pulled, or the screws that hold the HU in but they’re pretty self explanatory. Once you pull the plugs on the old HU out the other one just goes back in plug and play.
Reverse the order to put it all back together.
Next the door speakers.
Start by taking the door panels off, I’ve marked everything in the picture below.
A – 6 push rivets. Back the screw out with a torx driver, and pop the inserts out
B – Use a pry tool to pop the cover off, remove the Philips screw in handle, and the surround pops out from the end closest the door hinge
C – Use a pry tool to lift the lock panel out, and unplug the connector
D – This cover just pops off
After all of this the door just lifts up, and out.
Attachment 21746
The rear door is pretty well the same except there are 5 push rivets instead of 6
Attachment 21747
At this point you’ll see the speakers. Remove the 4 screws and unplug them.
The magnet on my speakers was big enough that it hit the plastic that holds the window track, so I flipped the spacers onto the back side of the speaker.
Attachment 21748
When I was looking online I found that there were two different ways of wiring the speakers. Some said the polarity was one way with the alpine package, and reversed without. It was pretty confusing so I decided to check it myself. I hooked a 5v source to the speaker and switched the wires until the cone popped outward. I marked the polarity on the terminal for future reference. (You can use a 9v battery instead of a 5v source, just touch it to the terminals if the cone pops in switch it around, and there’s your +-)
Attachment 21749
In my case I didn’t want to use crimp on terminals on the wiring in the door (in case one of the crimps wasn’t tight enough), or drag an extension cord with my soldering iron to the driveway so I built short pigtails using the factory terminals that I yanked off the POS stock speakers.
Attachment 21750
Attachment 21751
I put foam weather stripping on both sides of the spacer, and screwed them back into the door. At this point I realised that one of my fears came true. With the spacers installed, the protruding tweeters stuck out too far and were touching the door panels. So I warmed the speaker mesh in the door with a heat gun, and found a dead blow hammer that kind of matched the contour of the 6x9 and bulged it out a little. I could have just slapped the panels back on and let them stretch, but I was afraid the speaker mesh would turn white when it stretched.
Attachment 21752
Attachment 21753
The door panels go back on by lining up the panel a couple of inches above where it should go, and pushing down (remember to put the lock knob back through its hole, and pull the lock and window control plugs through their hole before you put it on)
Now that everything is in I defiantly notice that the 3.5”ers thin the dash suck, so I think they’re going to be next.
Three Generation Dodge Ram Owner - 1998, 2003, 2011
Old 06-14-2012, 09:25 PM
Mophead's Avatar
Mophead Mophead is offline
Vehicle: 2012 2500 4x4 Crew
Trim Level: Bighorn
Mophead is on a distinguished road
[QUOTE=ironchef2011;615281]Here are the detailed measurements of the stock Alpine dash, center and headliner speakers:
High quality "ALPINE" speakers?! Just begging for replacement.
What mfg have this dimension available? Would it be better to just place 1" tweeters in strategic locations?
Old 04-16-2013, 04:36 PM
autobred's Avatar
autobred autobred is offline
Vehicle: sold* 10' R/T... 13' R/T
Trim Level: R/T
Rep:142
autobred will become famous soon enoughautobred will become famous soon enough
Originally Posted by RedRam10 View Post
Hi, Nice Sticky
Old 05-18-2013, 01:21 AM
BlownGP's Avatar
BlownGP BlownGP is offline
Vehicle: 2009 RAM CC Sport
Color: Sunburst Orange Pearl
Rep:15
BlownGP is on a distinguished road
So, what a good replacement for the headliner speakers?
98 GTP-Mods? Yeah, lots of them
2009 Ram CC Sport- Mods very SOON!!!
Old 05-18-2013, 02:30 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
Wit you have an r/t and you have headliner speakers
Old 01-30-2014, 09:19 AM
vyper340 vyper340 is offline
Vehicle: 2014 Ram 1550 Longhorn Limited
Trim Level: Longhorn Limited
vyper340 is on a distinguished road
Stupid question: are the headliner speakers right behind the driver and passenger seats in the roof panel. What is the best replacement speaker?
Also, on mine I don't hear anything coming out of them... I have the Alpine 10 speaker set up.
2014 1500 4x4 Longhorn Limited w/Rambox
2015 2500 4x4 Cummins w/Rambox
Old 02-26-2014, 08:03 AM
Figured it out - just didn't hear much noise from them and wasn't sure. Duh...
Old 01-20-2015, 12:12 AM
thegreat22 thegreat22 is offline
Vehicle: 2015 Ram CC 4x4
thegreat22 is on a distinguished road
does this work on 2015 models?
Alpine to JL Audio- Dash, Center and Headliner Speakers ironchef2011 Custom Dodge Ram Interior Modifications - Custom Audio / Video 62 03-01-2017 10:04 AM
2010 Dodge Ram Alpine RER stereo system upgrade / wiring harness diagrams chadzilla500 Custom Dodge Ram Interior Modifications - Custom Audio / Video 49 04-02-2013 12:03 AM
Dash speaker removal in a 2010? hpc3 Custom Dodge Ram Interior Modifications - Custom Audio / Video 7 04-28-2010 10:07 AM
