Old 09-17-2011, 03:25 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
Default 4TH Gen: Stock Alpine Subwoofer Specs
The stock Alpine subwoofer is a dual two ohm voice coil unit sized at 8" in diameter. The entire face is 8.5" and it's 4" in depth.
Two remove the subwoofer from it's box, you must remove the Torx head bolts which are sized at 25. Then, remove the two 18mm bolts holding the box into the cargo tray. Unplug the box, flip it over, and remove the phillips head bolt on the bottom of the box. Turn the box over and remove the subwoofer by disconnecting each of the wiring harnesses.
In my opinion, the plastic box is not suitable for a stronger subwoofer. It will just resonate and flex and the mounting ring is paper thin. The stock Alpine subwoofer is appropriate for this type of enclosure and any need to add more or a different style of bass response should be handled by a different amplifier and subwoofer/enclosure.
2012 R/T 392
Old 09-18-2011, 09:21 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, Great Sticky!
Old 02-15-2013, 07:48 PM
simonmw75 simonmw75 is offline
Vehicle: 2009 Dodge Ram
Color: Graphite
Rep:72
simonmw75 will become famous soon enough
Is there a separate amplifier driving this thing? Or is it driven from the head unit? Any ideas on how we can improve this thing without replacing the speaker, or adding an amp? Just curious.
Old 02-15-2013, 08:10 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
If I remember correctly there is a small dedicated amp for the sub.
2012 R/T 392
Old 03-12-2013, 09:14 AM
eight-bit eight-bit is offline
Vehicle: 2011 Ram 1500
Color: Green
Rep:107
eight-bit will become famous soon enougheight-bit will become famous soon enough
Anyone have any further info on this?
Location, size, etc?
Old 03-12-2013, 04:34 PM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Trim Level: Outdoorsman
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
I believe there is only 1 amp for the entire system. You can get a low power amp for the factory sub and it will sound better. If you're like me you will eventually want more.
Old 05-30-2013, 11:50 PM
RileyZap RileyZap is offline
Vehicle: 2009 Ram 1500
Color: Pearl White
RileyZap is on a distinguished road
New to the site here.. wondering if someone could give me a little help. I'm looking to give my stock bass a little more kick and trying to keep it low budget. I have a 250w mono amp that I want to install to the factory sub, and i'm looking for a little guidance to completing this. Has anyone else simply added the amp in? A lot of work?
Old 06-11-2013, 03:46 PM
whiteknight312 whiteknight312 is offline
Vehicle: 2012 dodge Ram Bighorn
Trim Level: big horn 4x4
whiteknight312 is on a distinguished road
I don't have the alpine system, where do they install it?
thanks
Chris
Old 11-19-2013, 08:50 PM
jeffthomastx jeffthomastx is offline
Vehicle: 2012 dodge 2500 mega cab 4x4
Trim Level: laramie
jeffthomastx is on a distinguished road
where the "H" is the alpine sub located? i Have the Alpine upgrade and can hear it but Ill be dammed if I can find that booger
Old 11-26-2013, 02:56 PM
Black Diamond 357's Avatar
Black Diamond 357 Black Diamond 357 is offline
Vehicle: 2012 Ram 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
Color: Black Diamond
Rep:25
Black Diamond 357 is on a distinguished road
The sub if you have it is located under the back seat on the right hand side. I want to get a little more bump so I am thinking about adding a real sub/amp combo.
Alpine to JL Audio- Dash, Center and Headliner Speakers ironchef2011 Custom Dodge Ram Interior Modifications - Custom Audio / Video 59 10-13-2015 09:17 AM
Alignment specs? txhemi Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 22 08-17-2010 03:30 PM
stock alpine sub broke?? is that possible?? FlashSmith101 Custom Dodge Ram Interior Modifications - Custom Audio / Video 1 06-30-2010 08:31 AM
Alpine or Pioneer Premier? Please help me decide! MrCantu Custom Dodge Ram Interior Modifications - Custom Audio / Video 22 06-09-2010 08:06 PM
rt subwoofer question#2. Quiet Lunatic Dodge Ram R/T 2 05-04-2010 09:25 PM
