Old 09-17-2011, 05:50 PM
oilersfan2's Avatar
oilersfan2 oilersfan2 is offline
Vehicle: 2010 Dodge Ram Quad Cab
oilersfan2 is on a distinguished road
Default How much do you tow?
Was wondering what everyone around here tows with their 1/2 ton? I have the dodge Quad cab sport with 20" tires and 3.92 rear axle ratio, and was looking at buying at toy hauler with GVWR of 7900 lbs. Looked all over the Internet and shows the dodge with options like mine is "recommended" for 9600 lbs max. So curious if anyone else is pulling this much or more with any issues. Would hate to buy the trailer, then realize its too heavy. And before anyone says it, no I don't want to upgrade to a 2500/3500 at the moment. Lol
Thanks
Old 09-17-2011, 06:14 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Thanks
Mine's a crew-cab with the same gears and tire/rim size, picked up a new 26 foot jayco trailer this spring, the trailer weighed in about 5400 pounds loaded, in my opinion that's about half of what it could potentially haul,I kinda planned it that way though, I'm not sure I would pull anything heavier, it just seemed really balanced with that much load. If I knew I would be pulling anything heavier, I hate to say it, I would trade up to a diesel.
Old 09-17-2011, 10:04 PM
gbkinggerry's Avatar
gbkinggerry gbkinggerry is offline
Vehicle: 2010 dodge ram
gbkinggerry is on a distinguished road
I have a Laramie crew cab same set up (3.55 gears)and pull a desert fox 21 foot toy hauler.It weighs 5800 I think (i tell myself 6000) and the bikes are 1000 plus all the gear. So I would say around 7500. It pulls it fine uses lots of gas but works well. I needed to install the timbren system because the load levelers were not enough. Hope this helps.
Old 09-18-2011, 03:00 AM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
The truck would haul the trailer fine but it's not hard to put 2000 lbs in a toy hauler with out realizing it
Old 09-18-2011, 04:39 AM
Rep:2657
this is an interactive site
pick the year, model, etc, etc
then under Technical Information, look for the line that begins with BASE WEIGHTS
then set the zoom to a size that allows you to read the charts
http://www.dodge.com/bodybuilder/year.pdf
Old 09-18-2011, 07:34 AM
Netman66 Netman66 is offline
Trim Level: Laramie 4x4
Color: Inferno Red / Light Greystone Pearl
Rep:82
Netman66 will become famous soon enough
I pull a 7500lb, 35 foot trailer with my 2010 QC 4x4 with 3.55 gears. It's not ideal, but it pulls fine. A little head wind and some hills and it get's a little sluggish, but your 3.92s are a better setup than mine.
I'd say you're in good shape.
Old 09-19-2011, 02:01 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
3.92 will help you out a lot. The truck can definitely tow that weight, but like stated about it's easy to add a couple thousand pounds without even knowing it....so just be careful what you load up...
Sean
Old 09-19-2011, 02:12 PM
BigDaddyHock's Avatar
BigDaddyHock BigDaddyHock is offline
Vehicle: 2014 Dodge Ram Sport Crew Cab
Rep:40
BigDaddyHock is on a distinguished road
I have the Quad Cab 4x4 with 3.55 gears, pulling a 32 foot ultra lightweight trailer, 4800 unloaded. I would say I'm around 6200 loaded up. Trailer has a very wide spread axle which seems to really help with towing. I had a 20 foot Jayco tandem axle and our new one seems to handle better.
Old 09-19-2011, 02:27 PM
jj ram's Avatar
jj ram jj ram is offline
Vehicle: 2014 Dodge Ram 4x4
Trim Level: Outdoorsman
Color: Maximum Steel Metallic
Rep:16
jj ram is on a distinguished road
I have a similar set up to big daddy, except with a HEMI. 29 foot Kodiak travel trailer, weighs around 6300 loaded and I have the 3:55's.
It tows it well, but I wouldn't want anything heavier with this trucks gearing.
With the 3:92's I think you will be fine with something around 7900 - 8000 lbs just be careful how much you load up. Once you put a trailer on these trucks they run out of cargo carrying capacity QUICK, so you will actually be better off with a toy hauler and the gear in the trailer.
Enjoy the new trailer!
"They will not force us, they will stop degrading use, they will not control us, we will be victorious" - Muse
Old 09-19-2011, 06:24 PM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
I have the 4x4 crew cab Big Horn with Hemi and 3.55 gears and the factory brake controler. I have had up to 8K+ behind mine and it tows fine. Barley even notice its there. I think your comfort level will increase with experience and properly set up tow equipment. I would not hesitate to put a full 10K behind mine if I had the need.
Then again I dont live in the Colorado mountains
Spyntec Hubs, 35" Toyo AT II, Synergy Steering Brace, Fox 2.0 IPF. BullyDog Tuner, Katskinz Leather........................
How to: Hood Insulation / Radiator Cover Graphic Designs 10ramisport Dodge Ram Knowledge Base 2 05-01-2014 12:25 PM
How to order Towing Package slidellkid 2011 Dodge Ram Forum 8 07-03-2011 08:45 PM
How much would you charge? crob 5.7L V8 Specific Topics 4 04-27-2011 12:12 AM
!!how much would you charge?11 crob Dodge Ram General Discussion 5 04-21-2011 10:44 PM
How do you tell? Manogod Heating & Cooling 3 03-18-2011 06:15 PM
