United Radio
Old 09-20-2011, 06:05 PM
oilersfan2's Avatar
oilersfan2 oilersfan2 is offline
Vehicle: 2010 Dodge Ram Quad Cab
oilersfan2 is on a distinguished road
Perfect thanks for all the replies, sounds like it should be ok.
Old 06-06-2012, 03:32 PM
pathogan pathogan is offline
Color: Blue
pathogan is on a distinguished road
Default Towing 5th Wheel
I drive a 2010 SLT Crew Cab (5.7L & 3.55 gear) and am planning on buying a 5th wheel, which has a GTW of 6400 lbs with a GAWR of 8550 lbs, which I presume is the difference between bone empty and fully loaded. If fully loaded at 8550 lbs (max towing for my truck rated at 8500 lbs) that would bring GCWR to 14000 lbs - max according to Dodge. Will this truck do it? I know many will say buy a 3/4 T etc but I drive empty more than I pull a trailer so like the comfort & economy of the 1/2T. Also expect I will have to buy something like the sidewinder due to my short bed length. Thnx.
Old 06-06-2012, 07:13 PM
rainhater1 rainhater1 is offline
Vehicle: 2010 ram 1500 4x4 06 300 srt8
Trim Level: slt - big horn
Color: light graystone
Rep:116
rainhater1 will become famous soon enoughrainhater1 will become famous soon enough
Lets not forget the other side, stopping. Pulling is easy but stopping is another, make sure you have a good brake system. just like 4x4s dont stop better than 2wd. something a few people need to learn
Old 06-07-2012, 12:28 AM
ArmyofOne's Avatar
US Army Retired
Rep:1189
Loaded with fuel and gear, my boat weighs 7,350 give or take (500lbs of fuel-84 gallons-then another 500 of gear or so). I would not DREAM of even attempting it without Total Load Control™ Air Suspension Systems, and a brake upgrade from Clark at AutoAnything. TLC's patented system solves the RAM 1500 coil spring problem – smooth everyday ride can’t handle heavy loads or towing. TLC adds 5,000+ pounds of lift so your truck will always be level - and TLC™ improves steering, handling and braking too. TLC™ is a revolutionary patented air suspension that operates independent of the factory suspension and doesn’t interfere with the smooth factory ride. TLC uses 9" Goodyear® air springs - the largest on any full-size truck. But, if you want, a “sportier” feel, TLC can give it to you. TLC's air springs have at least 5 times the power of the “inside the coil air springs" that others offer 4th Gen RAM 1500 owners. TLC has a new model for RAM 2500 and 3500 trucks (2002-2012). This unit is super tough with 1/4" steel platforms that will level the heaviest loads, trailers and boats. Some competitors use 6" air springs. TLC's 9" air springs have at least 3 times the air volume and level heavy loads with only 20-30 psi. I've been a mechanic for about a decade now and I know about other air bag and bumper systems. There is no comparison to TLC. Until you get TLC, you've never experienced the full power of air bags or had Total Load Control.
Of course, TLC cannot increase GVWR or GCWR so please do not exceed the manufacturer's recommendation. All TLC systems are easy to install; fit single or dual exhaust and require no modifications. You can order with or without a quality Viair air compressor and gauge/switch panel (no air tank required for the TLC system). Custom production available for lifted trucks! Shipping for the 1500 unit is always free in the continental US, $40 to Canada, and $100 internationally. Shipping for the DGHD-2535 unit is based on your location because it’s a much heavier, larger unit (we currently ship from Visalia, CA). We have a limited time coupon good for $50 off your purchase until June 15. Please enter code: RAM50OFF at checkout.
Your Ram + TLC = Match made in heaven.
Feel free to send me an email at ArmyofOne2006@remove_this_part.gmail.com so we can discuss things further. Looking forward to pics of your rig and seeing you active in the community.
-Josh
Diesel Technician-PACCAR Inc.
Old 06-19-2012, 03:07 PM
Snap's Avatar
Snap Snap is offline
Vehicle: 2013 Ram 2500 CC 4x4
Rep:12
Snap is on a distinguished road
Good to see someone else towing a big Bayliner I'll be towing a 2011 Bayliner 245SB with my 1500. TLC here I come!
2013 Ram 2500 Cummins CC 4x4 Big Horn
2011 Bayliner 245SB
Old 06-22-2012, 01:27 PM
Snap's Avatar
Rep:12
Finally got her all hooked up.
2011 Bayliner 245SB
Old 08-23-2012, 06:29 PM
Boubou's Avatar
Boubou Boubou is offline
Vehicle: 2010 Dodge Ram QC 4X4 Hemi
Trim Level: 4X4 SLT Hemi
Color: Light greystone
Rep:54
Boubou will become famous soon enough
I tow a 5900 lbs empty (6800 lbs loaded, checked at scales) 5W. We towed from Kingston Ontario to Nova Scotia and back with no problem. He truck is SLT Quad Cab 1500 4X4 HEMI 3:55 with 20" tires ( I won't get those again!).
Only problem we have right now is leveling the 5W because the truck is too arn high. Working on this.
We have the timbrens.
Lots of hills in New Brunswick and no problem with power.
Old 08-23-2012, 07:11 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
I'll be the "Devil's Advocate" here, the "pin" weight of a 5th wheel is almost always 20 to 25% of the trailer weight, so the next question is, what is the "payload" of your truck? If the "pin" weight is as stated, it's either 1710 or 2137 lbs or something in between using 8550 lbs as the example as stated. I'm pretty sure the "payload" of your truck isn't any more than 1500 lbs.Now take that 1500 lbs and subtract your wife, your kids, your dog and whatever else you maybe put in the box of your truck. Now you are way past the payload of your truck hooked to your 5th wheel. That is why there are only a limited amount of 5th wheel trailers that can actually be pulled behind a 1/2 ton. If you figure it will pull it no problem, you are way into the "buffer zone" that your axles, suspension and brakes were designed for. That is why most are pulling "bumper pull" travel trailers with 1/2 ton trucks.
How to: Hood Insulation / Radiator Cover Graphic Designs 10ramisport Dodge Ram Knowledge Base 2 05-01-2014 01:25 PM
How to order Towing Package slidellkid 2011 Dodge Ram Forum 8 07-03-2011 09:45 PM
How much would you charge? crob 5.7L V8 Specific Topics 4 04-27-2011 01:12 AM
!!how much would you charge?11 crob Dodge Ram General Discussion 5 04-21-2011 11:44 PM
How do you tell? Manogod Heating & Cooling 3 03-18-2011 07:15 PM
