Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
tonneaucovered.com
Old 09-23-2011, 11:55 PM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
Thanks SNRUSNAK. Well first we have to find out if there is a Valve seat that drop. These 4.7 came with that problem and many have seen it after a overheating issue or failed valve lash. They sell mechanic scopes that are camera's that can go into the spark plug bore to see each cylinder. If that is not the cause that he dropped a Valve seat then go to the next step and check Exhaust Header Gasket. In some case I have heard people and seen people find a slight exhaust leak that sound like an engine knock. Next step is to remove the valve covers and inspect all the rocker arms for loose or stuck rocker arms. Some times you can for a brief moment have someone turn on the truck and you can hear closely for a knock which will sound loader with out the cover. DO a Compression Test for the last step to find if there's any cylinder compression change cause by a loose or stick adjuster. Beside that he might have to change them out but I would not recommend adding any washers to get a tighter valve adjustment since the 4.7 all ready have weak spots like you saw on my factory Cylinder Head Valve adjuster Bore Failure. Any questions hit me up on my profile IM.
Old 10-02-2011, 08:02 AM
Rep:12
What's the update on the problem foxhuntr?
Old 10-04-2011, 11:43 PM
Hartattack's Avatar
Hartattack Hartattack is offline
Vehicle: 2004 Dodge Ram 1500
Color: Atlantic Blue
Hartattack is on a distinguished road
Timing chain could be loose. I'm pretty sure I am going to have to change my tensioners, just haven't had the time to.
Old 10-07-2011, 03:50 PM
foxhuntr foxhuntr is offline
Vehicle: 2002 Dodge Ram
foxhuntr is on a distinguished road
sorry everyone i have been out of state and havent had the chance to write......i still have the ticking...i have tried everything short of having the heads torn off and dirring into it....
Old 10-30-2011, 03:23 PM
Vanquish's Avatar
Vanquish Vanquish is offline
Color: Smoke Grey
Vanquish is on a distinguished road
hey does anybody know where I can find a write up or more 411 about this lash adjustment/lifter problem. I have an 02 Ram w the 4.7 but i have a constant knocking instead of ticking. Had this problem when i had my trans am but it was a broken rod. I just need to know how to go about fixing it because i dont really have the money for a whole engine replcement. any suggestions?
Transmission Problem 07 Hemi 07Ram 5.7L V8 Specific Topics 14 03-14-2013 06:45 PM
First Dodge - First Ram - First Post - First Problem koolaidzx2 Newbie Checkin! 11 01-17-2011 01:10 AM
Headlight problem oscart47 Electrical 3 12-08-2010 12:48 AM
Door Ajar Light & Power Windows Problem. scottdutton Electrical 1 12-05-2010 05:54 PM
Yet another HID problem griffin407c Custom Dodge Ram Interior and Exterior Lighting 10 10-27-2009 04:37 PM
