from 20's to 17's for winter - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 09-19-2011, 10:59 AM
hdheritage hdheritage is offline
Vehicle: 2011 ram 1500
Trim Level: express
Color: bright white
hdheritage is on a distinguished road
Default from 20's to 17's for winter
Hey all: Quick question? Will pulling off my 20's for the winter and bought a set of 17's off Cl from a 2011. Will running the 17's without the TPMS have an adverse affect or just light up the warning lamp on my 2011? Please no flames. Thanks in advance. John
Old 09-19-2011, 11:06 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
It will just light up your dash indicator. Make sure the 17s fit clearance wise and dont stick out to far before you mount wheels on them if they arent off of a ram originally
2011 Big Horn 4x4 -SnowWhite-
Old 09-19-2011, 09:38 PM
Bighert3rd's Avatar
Bighert3rd Bighert3rd is offline
Vehicle: 2014 Ram 5.7L
Trim Level: Tradesman
Rep:60
Bighert3rd will become famous soon enough
Just out of curiosity, why would you want to pull off the 20s? They are crome clad wheels and not real...I'm pretty sure you'll be good to go for the winter. I had crome clad on my Expedition for many winters and it didn't change them at all.
Old 09-19-2011, 10:08 PM
jjride's Avatar
jjride jjride is offline
Vehicle: '14 Ram Sport
Trim Level: Sport C/C
Color: PS2
Rep:28
jjride is on a distinguished road
17" tires are cheaper than 20" .. plus the chrome cladding takes a beating with any extra gravel they put on the roads.. at least they do up where i live. You can pick up a set of 17's relatively cheap, then all you have to do is swap a full set of wheels and tires over from season to season.. instead of dismounting and remounting tires every winter/fall... but....
Everytime you get in the vehicle it'll tell you that you have no air in your tires, other than that you're fine.
Old 09-22-2011, 02:12 PM
954rrmike's Avatar
954rrmike 954rrmike is offline
Vehicle: 2014 Ram Sport
Trim Level: Sport Crew Cab
954rrmike is on a distinguished road
What size tires is everyone running on their winter 17's to replace factory 20's?
2014 Sport Crew Cab White,8 speed 392LSD,LineX bed liner, Mufflex DOD24M, 18" xd monsters with blizzaks, weather tech floor liners and mudflaps
Old 09-22-2011, 03:10 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Yeah it is common to do this....we used to swap wheels/tires in winters in PA as it was easier/cheaper than mounting a set of tires every season...
Sean
Old 09-22-2011, 07:06 PM
Rep:2954
In New England, people that could afford it, had a set of winter tires & rims & a set for summer
My grand parents had a winter car, a beater
& the good car for summer
I wore out my tires every season, so i just bought new rubber
We belonged to a Farmers Co-op & got them fairly cheap
Old 09-23-2011, 09:24 AM
brokenwrench66's Avatar
brokenwrench66 brokenwrench66 is offline
Vehicle: 2009 1500 SLT 4X4
Color: Stone White
Rep:81
brokenwrench66 will become famous soon enough
265/70/17's
are the stock Ram size and there are lots of winter tires to choose from in that size that are cheaper than 20's
Dual Exhaust, K&N drop in, TFP chrome mirror covers, TFP stainless steel door handle covers, molded splash guards, Leer cap
Old 09-26-2011, 07:53 PM
954rrmike's Avatar
After researching tire sizes it seems the 265 70 17 is about a inch shorter than the 20's. Is this going to look bad and change the speedometer drastically. A 285 70 17 is the same outside diameter as the 20's, wouldn't it be better to go with this size?
Old 09-29-2011, 12:12 PM
Color: Stone White
Rep:81
Your dealer can change you speedo for you (they can access a drop down list that allows them to pick a wide range of tire sizes for the truck).
Personally I like to run a narrower tire in the winter, not a wider one. A wider one will give you more floatation and less pounds per square inch of tire contact area on the road. Since a truck has a light rear end already, I want to give it as much bite as possible.
You'll also have more selection in the 265 size but if you find one you like in 285, then that's not an issue.
