Old 09-19-2011, 09:11 PM
89powerram's Avatar
89powerram 89powerram is offline
Vehicle: 2004 dodge ram 1500 hemi 4x4
Trim Level: Slt
89powerram is on a distinguished road
Default which trans
i have a 1989 dodge ram 4x4 and i need to know what trans it has it is automatic with 1st and 2nd gear on the column
-IF YOU CANT DODGE IT RAM IT!!!!
Old 09-20-2011, 09:15 PM
89powerram's Avatar
Trim Level: Slt
anybody..............
Old 09-20-2011, 09:58 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Your description doesn't make much sense. Let's try a different method. Does the truck have an O/D button in the dash panel? If not, you have a 3-speed 727. If yes, you have the 518 (3-speed with overdrive).
Old 09-20-2011, 10:26 PM
89powerram's Avatar
Trim Level: Slt
there is no o/d button that i can find thanks for the help but if there was an o/d were would it be
Old 09-21-2011, 04:22 PM
Rep:85
My '90 has it directly to the right of the big three gauge cluster, directly above the heater/air cond. controls. You can also look for the O/D solenoid on the transmission. On the driver side just behind the shifter linkage, there the safety neural start switch. It angles in and lays horizontally. If you have a 518, you'll have an overdrive solenoid connector that plugs in vertically. It is just a few inches from the neutral start switch, a little closer to the main body of the transmission, and a little further back from the neutral start switch. It's a 2 pin connector. Dodge was very casual in their introduction of new stuff, usually taking a year by year phase-in approach. I'm not sure they even offered the 4wd with the 518 before 1990.
Old 09-21-2011, 08:34 PM
89powerram's Avatar
Trim Level: Slt
it has the 727 and your right the 4wd trucks didnt have the 518 thanks for the help oh and btw what were the stock rear end ratios on these trucks
Old 09-21-2011, 09:16 PM
Rep:85
I have a 1990 FSM and the basic specs on these trucks went unchaged, in some instances, for over a decade so I doubt anything changed from '89 to '90. Most common was the 9 1/4 rear, which had 3.21 and 3.55, while the HD 9 1/4 had 3.55 and 3.90. A side note, the heavier Dana 60 had 4.10, Dana 70 had 4.56 and 4.88. The Danas were mostly in the W-series trucks.
Old 09-23-2011, 06:53 PM
89powerram's Avatar
Trim Level: Slt
how do i find out which one i have
Trans rebuild 94ram1500 5.2L V8 Specific Topics 4 04-07-2011 10:49 PM
$3,500+ in trans repairs,etc still no fix HELP! rcs4787 5.2L V8 Specific Topics 5 11-17-2010 02:48 PM
Possibly need new trans... IntenseDakota 5.9L V8 Specific Topics 5 09-27-2010 08:48 AM
Trans wont shift always in second donjuan7z Cummins Diesel Specific Topics 2 09-18-2009 11:44 PM
i want to do a trans conversion from auto to manual off road guy 5.9L V8 Specific Topics 1 12-16-2008 08:00 PM
