Old 09-19-2011, 09:27 PM
BgHrn BgHrn is offline
Vehicle: 2006 Dodge Ram
BgHrn is on a distinguished road
Default Front shock install...
I've got an 06' Ram 1500 Big Horn. I was wondering what is all involved, to replace the front shocks on it? Do I have to split either of the balljoints, tie-rods? Id just like to what Im getting into. Thanks!
06' Ram, molding!, In-channel visors, 3" Mag' SI/SO 18" long, Mag' y-pipe, 2" HBS Leveling kit/1" rear block ,DSP 91 tune, KN CAI kit, BFG 285/65r20 rubber.
Old 09-20-2011, 07:50 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
disconnect the upper ball joint, the tie rod end & remove the brake caliber. You're biggest problem could be the seized lower strut bolts. Had to use heat & an impact gun on mine.
It's a truck, not a cream puff
Old 09-20-2011, 10:25 PM
Ok, that doesn't sound too bad. What kind of struts did you install?
Old 09-21-2011, 07:09 PM
06 BigHorn's Avatar
Rep:153
I installed some Monroe Quick Struts little over a month ago. 2 days after installing them they started squeaking & rattling. So I'm sending them back under Monroes 90 day warranty. I bought Rancho Quick Lifts to replace them, but after 4 calls to rancho those are screwed up too. Seems I bought some old stock & rancho changed / improved the top mounts. So I'm currently waiting for the 2nd set of ranchos!
Old 09-21-2011, 08:55 PM
Dang, you've got bad luck too. I was thinking of going with Rancho's also.
Old 09-26-2011, 02:14 PM
age525's Avatar
age525 age525 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:91
age525 will become famous soon enough
I put on Bilstein 5100's and I'm happy with them. That lower strut bolt was a real pain in the ass though.
S&B Cold Air Intake, American Racing Headers, DB Performance Cat Back Exhaust, Recon LED Taillights, Bilstein 5100's, Toyo Open Country AT 2, Diablosport Predator, Recon Line of Fire, JL Audio 10W3 StealthBox, Alpine iDA-X305s Head Unit, Detroit TrueTrac
Front Camera Install Questions RootBeer Custom Dodge Ram Interior Modifications - Custom Audio / Video 16 02-03-2015 09:16 PM
How to set timing GodSpeed 4.7L PowerTech V8 Specific Topics 5 10-21-2014 01:06 PM
Trying to find info on my truck snrusnak 2010 Dodge Ram Forum 20 05-24-2011 09:02 PM
Anyone know how to take apart the stock cupholder SFA1500 Custom Dodge Ram Interior and Exterior Lighting 5 08-29-2010 10:34 PM
My 2nd Mod, TRX Skid Plates - An Easy Install Brute 2009 Dodge Ram Forum 4 03-02-2010 01:01 PM
