Fuse box help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Accessories - Dodge Ram Parts - Dodge Ram Performance - Registered Vendors! > Mopar Online Parts - Dodge Ram Accessories!
Diesel Forums!
Dodge Caliber
Mopar Online Parts - Dodge Ram Accessories! Suppliers of Genuine Dodge/Ram Parts and Accessories at wholesale prices. Shop with confidence as all repair parts orders are checked against the VIN provided to ensure 100% accuracy getting you the right part the first time. All items we sell are backed by a 1yr warranty. - Dodge Ram Accessories!
Place your Ad Here!
Old 09-19-2011, 08:33 PM
rusure rusure is offline
Vehicle: 2004 Ram
rusure is on a distinguished road
Default Fuse box help
Driving a 2004 Dodge Ram 2500 automatic. I've been searching for more information but can't find anything conclusive. I got a lamp out light on and simultaneously my headlight and tail light on the driver side stopped working. I know others said the lamp out light has come and gone but mine has remained on. I replaced a bulb that may have been bad and tested all the remaining tail lights on the passenger side and they all worked with no improvement. I was told a new fuse box (I believe it's actually called the Integrated Power Module) was needed but I'm looking to see if I should try any other options or what that part # is if that is what is needed. Thank you in advance for your help!
Old 09-20-2011, 03:59 PM
MATT137 MATT137 is offline
Vehicle: 2002 DODGE RAM 1500 5.9 V8 4x4
Trim Level: SPORT
MATT137 is on a distinguished road
I dont Have a part number for you but you might try to see if you have a bad conection to the feuse box first and if its good than mabe check the wires whare thay conect to another wire like a trailer plug if you have one. I had a revers light out and i replaced it and it still didnt work, turns out that it was a bad conection to the trailer plug. But that wont make the front and rear lamps go out at the same time. So do as above and check feuses and hope for the best. I hope this helps and it all works out for you
YOU WILL NOT BE SCORCHED WHEN YOU WALK THROUGH THE FIRE. AND THE FLAMES WILL NOT BURN YOU.Is:43;2
Old 09-21-2011, 09:21 AM
Vehicle: 2004 Ram
I thought the same thing but I'm not sure why both the headlight and tail light would go out at the same time from a wire issue. I'm not a mechanic though so I'm honestly not sure, I'll try to investigate them more thoroughly.
Where could I buy a replacement fuse box? CallMeClay Electrical 7 12-14-2011 03:57 PM
CB Power fsthawk Electrical 13 09-09-2011 06:01 AM
New Mirrors keep blowing fuse Bruno72 Electrical 2 06-28-2011 11:50 AM
Which fuse and relay to use??? Dieselkiss Electrical 2 03-10-2010 01:20 PM
Radio fuse causing SERIOUS battery drain anyone know? 04ram86 Electrical 4 09-01-2009 11:33 AM
